    Module error after updating - MMM-Pir: Pir Error detected: EINVAL: invalid argument, write
    9 Posts 4 Posters 2.0k Views 4 Watching
      Jazz
      I’m running on a Raspberry Pi 4…
      jazz@magicmirror:~ $ cat /sys/firmware/devicetree/base/model;echo
      Raspberry Pi 4 Model B Rev 1.5
      Please note that my account is a member of the gpio group…
      jazz@magicmirror:~ $ groups
      jazz adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi
      I’ve had a magic mirror up for several months now. Due to the recent reports of problems being discovered with OpenSSH, I decided to do a full system update (that is, I did a ‘sudo apt update’ followed by a ‘sudo apt full-upgrade’) of the system. Note that i’m running raspbian 12…
      jazz@magicmirror:~ $ cat /etc/os-release|grep -e NAME -e VERSION
      PRETTY_NAME="Raspbian GNU/Linux 12 (bookworm)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="12"
      VERSION="12 (bookworm)"
      VERSION_CODENAME=bookworm
      I then updated the magic mirror software (‘git pull && npm run install-mm’). I then updated my modules, including MMM-Pir (https://github.com/bugsounet/MMM-Pir) via ‘npm run update’ and ‘npm run rebuild’. Everything proceeded as expected, but afterwards when I restarted, I was presented with an error in the notifications section of the magic mirror display saying “MMM-Pir: Pir Error detected: EINVAL: invalid argument, write”.
      Note that i’ve made no changes to the wiring of the PIR sensor or to the module configuration, which looks like…
          module: 'MMM-Pir',
          position: 'top_left',
              debug: false,
              delay: 2 * 60 * 1000,
              mode: 10,
              displayCounter: false,
              displayBar: false,
              displayStyle: "Text",
              displayLastPresence: true,
              lastPresenceTimeFormat: "LL H:mm",
              pir_mode: 0,
              pir_gpio: 17,
              pir_reverseValue: false,
              mode6_gpio: 20,
              mode6_clearGpioValue: true,
              xrandrForceRotation: "normal",
              wrandrForceRotation: "normal",
              wrandrForceMode: "1920x1080",
              touchMode: 0
      Note that if I do a ‘pm2 logs magic-mirror’, here are some of the last entries in /home/jazz/.pm2/logs/magic-mirror-error.log…
      0|magic-mi | [4347:0702/141938.410247:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      0|magic-mi | [4347:0702/141938.410629:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|magic-mi | [2024-07-02 14:19:40.939] [ERROR] [MMM-Pir] [LIB] [PIR] Error: EINVAL: invalid argument, write
      0|magic-mi | /home/jazz/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      Anyone have any ideas on how to resolve the issue? I’ve tried changing the module ‘mode’ values to 9 and 2, but 10 seems to be the right value for my raspberry pi.
      Regards,
      Jazz
      bugsounetB 1 Reply Last reply Reply Quote 0
      • bugsounetB Offline
        bugsounet Banned @Jazz
        @Jazz said in Module error after updating - MMM-Pir: Pir Error detected: EINVAL: invalid argument, write:
        pir_mode: 0,
        Sorry, I have forget to update ReadMe for this error
        Generally happen with x64 system (Rpi 4 and Rpi 5)
        Available pir_mode:
        pir_mode: 0 - use onoff library (For Raspberry Pi 3b+ and 4)
        pir_mode: 1 - use python script with RPI.GPIO library (For Raspberry Pi 3b+ and 4)
        pir_mode: 2 - use python script with gpiozero library (For Raspberry Pi 5, not tested on other Raspberry Pi)
        So, Can you try pir_mode: 1, or pir_mode: 2,
        J bugsounetB 2 Replies Last reply Reply Quote 0
          Jazz @bugsounet
          @bugsounet Changing pir_ mode from 0 to 1 has fixed the problem :)
          Thanks for your help.
          Regards,
          Jazz
          • J Jazz has marked this topic as solved on
            bugsounet Banned @bugsounet
            ReadMe Updated
            • L Offline
              Laca44
              Hi everyone,
              I just can’t get it to work guys. Please help.
              GPIO setup:
              VIN - Pin2
              OUT - Pin6
              GND - Pin11
              Configuration:
              module: ‘MMM-Pir’,
              position: ‘top_left’,
              debug: false,
              delay: 1 * 30 * 1000,
              mode: 1,
              displayCounter: true,
              displayBar: true,
              displayStyle: “SemiCircle”,
              lastPresenceTimeFormat: “LL H:mm”,
              xrandrForceRotation: “normal”,
              wrandrForceRotation: “normal”,
              touchMode: 2,
              pir_gpio: 17,
              pir_mode: 1,
              I have been playing around with all variations and have tested 3 sensors. Not sure what I’m missing.
              Thank you for your support!
                sdetweil @Laca44
                @Laca44 does it work outside
                MagicMirror?
                there are python scripts to test operation.
                google search
                python pir sensor test
                • L Offline
                  Laca44 @sdetweil
                  @sdetweil said in Module error after updating - MMM-Pir: Pir Error detected: EINVAL: invalid argument, write:
                  I’m a newbie and this helped a lot! Thank you!
                    sdetweil @Laca44
                    @Laca44 were you able to solve the problem?
                    • L Offline
                      Laca44 @sdetweil
                      @sdetweil Yes it helped in resolving the issue. I still need to understand what troubleshooting actually helped.
