    Which Raspbian version to use for new clean (upgrade) install?
    6 Posts 2 Posters 792 Views 2 Watching
      jjd
      I had a working MagicMirror setup under Raspbian buster, but started having trouble with MMM-AlarmClock module streaming boston npr affiliate WBUR. It would keep dropping and stuttering (which it didn’t do before.)
      I figured I would start by upgrading the system to the latest software and have effectively borked my system now, so I’m going to start from scratch.
      Here’s my question: What version of Raspbian should I be using? Bookworm is the latest, but I’ve seen a bunch of posts indicating maybe it isn’t ready for prime time yet.
      I’d rather use the latest release. Is there any reason I shouldn’t be using Raspbian Bookworm for a MagicMirror installation?
        sdetweil @jjd
        @jjd you didn’t identify the device
        in my humble opinion
        pi0/02w legacy 32 bit bullseye
        pi3 legacy 32 bit bookworm
        pi4/5 64 bit bookworm
          jjd @sdetweil
          Thank you, @sdetweil, I appreciate your reply and your opinion.
          This is a Pi 3B, so I’ll start with legacy 32bit bookworm.
          –Jim–
            sdetweil @jjd
            @jjd use my script to install mm
              jjd @sdetweil
              @sdetweil I did use your script and it worked perfectly. Thank you for that!
                sdetweil @jjd
                @jjd awesome
