    Fork Mode
    11 Posts 2 Posters 1.9k Views 2 Watching
    • D
      davidgagne
      Can anyone help me understand why my .pm2/pm2.log file is filled with the below errors?
      2024-08-03T18:30:09: PM2 log: App [MagicMirror:1] online
      2024-08-03T18:30:15: PM2 log: App [MagicMirror:1] exited with code [1] via signal [SIGINT]
      2024-08-03T18:30:15: PM2 log: App [MagicMirror:1] starting in -fork mode-
      2024-08-03T18:30:15: PM2 log: App [MagicMirror:1] online
      2024-08-03T18:30:20: PM2 log: App [MagicMirror:1] exited with code [1] via signal [SIGINT]
      2024-08-03T18:30:20: PM2 log: App [MagicMirror:1] starting in -fork mode-
        sdetweil @davidgagne
        @davidgagne well you have two apps defined
        MagicMirror and pm2
        So do
        pm2 delete 0
        pm2 delete 1
        pm2 save -f
        Then run my fixuppm2 script, from
          @davidgagne does npm start work?
          If not, pm2 is doing npm start and it is failing
          Pm2s JOB is to start the app AND keep it running.
          So if it fails or is stopped outside pm2, then you will see the exited and pm restart it
          • D
            davidgagne @sdetweil
            @sdetweil Yes. I think something is wrong with pm2 itself, because (a) calling the standard pm2 start MagicMirror will appear to work, but it does not actually launch the MagicMirror. This is the output it yields:
            ~/MagicMirror/modules $ pm2 start MagicMirror
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 1 ])
            [PM2] [MagicMirror](1) ✓
            [PM2] Process successfully started
            │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
            │ 1  │ MagicMirror    │ default     │ 2.28.0  │ fork    │ 2816     │ 1s     │ 57   │ online    │ 0%       │ 29.0mb   │ dvg      │ disabled │
            │ 0  │ pm2            │ default     │ 2.28.0  │ fork    │ N/A      │ 0      │ 0    │ stopped   │ 0%       │ 0b       │ dvg      │ enabled  │
            And (b) it shows pm2 as stopped which doesn’t make any sense. I thought pm2 was supposed to always be running.
            Calling /installers/mm.sh will launch the MagicMirror, but then I am stuck with it reporting everything back to the ssh Terminal window and I can’t so anything else until/unless I ctrl-z it, which is annoying.
              MagicMirror and pm2
              So do
              pm2 delete 0
              pm2 delete 1
              pm2 save -f
              • D
                @sdetweil Awesome! That seemed to do the trick. Thanks!
                  @davidgagne said in Fork Mode:
                  and a learning thing
                  on Windows you can use
                  cd %HOME%\MagicMirror
                  rem had to make a mm.cmd or mm.bat
                  detach installers\mm.cmd
                  to spin a job off in the background
                  on linux, you end the command with &
                  to do the same thing
                  # only for  example, could have used the complete path
                  cd ~/MagicMirror
                  installers/mm.sh &
                  # or
                  npm start &
                  • D
                    @sdetweil Oh, nice. That’s a good tip. Thanks!
                    • D
                      @sdetweil said in Fork Mode:
                      installers/mm.sh &
                      That doesn’t seem to work:
                      ~/MagicMirror $ installers/mm.sh &
                      [1] 11788
                      > magicmirror@2.28.0 start
                      > ./run-start.sh $1
                      [2024-08-04 16:01:09.618] [LOG] Starting MagicMirror: v2.28.0
                      [2024-08-04 16:01:10.764] [LOG] Loading config ...
                      [2024-08-04 16:01:10.845] [LOG] config template file not exists, no envsubst
                      [2024-08-04 16:01:17.539] [LOG] Loading module helpers ...
                      [2024-08-04 16:01:17.705] [LOG] No helper found for module: alert.
                      [2024-08-04 16:01:19.196] [LOG] Initializing new module helper ...
                      [2024-08-04 16:01:19.283] [LOG] Module helper loaded: updatenotification
                      [2024-08-04 16:01:19.535] [LOG] No helper found for module: clock.
                      [2024-08-04 16:01:20.029] [LOG] Initializing new module helper ...
                      [2024-08-04 16:01:20.278] [LOG] Module helper loaded: mmm-systemtemperature
                      [2024-08-04 16:01:20.396] [LOG] No helper found for module: weather.
                      [2024-08-04 16:01:20.554] [LOG] No helper found for module: weather.
                      [2024-08-04 16:01:27.632] [LOG] Initializing new module helper ...
                      [2024-08-04 16:01:27.767] [LOG] Module helper loaded: MMM-ThemeParkWaitTimes
                      [2024-08-04 16:01:30.552] [LOG] Initializing new module helper ...
                      [2024-08-04 16:01:30.603] [LOG] Module helper loaded: MMM-birthdays
                      [2024-08-04 16:01:30.714] [LOG] No helper found for module: MMM-CloneWarsQuotes.
                      [2024-08-04 16:01:30.761] [LOG] Initializing new module helper ...
                      [2024-08-04 16:01:30.854] [LOG] Module helper loaded: MMM-ThemeParkWaitTimes
                      [2024-08-04 16:01:31.469] [LOG] Initializing new module helper ...
                      [2024-08-04 16:01:31.526] [LOG] Module helper loaded: MMM-ImagesPhotos
                      [2024-08-04 16:01:31.561] [LOG] All module helpers loaded.
                      [2024-08-04 16:01:32.866] [LOG] Starting server on port 8080 ...
                      [2024-08-04 16:01:33.567] [WARN]  You're using a full whitelist configuration to allow for all IPs
                      [2024-08-04 16:01:35.645] [LOG] Server started ...
                      It is still returning all the reporting to Terminal.
                        @davidgagne yes, as the starting shell is still open, output is spooled there,
                        BUT you can exit the window AND it will stay running… the output will be lost…
                        (thats the value of pm2 spawning… it captures the output)
                        if you get it running in the background, without pm2, then two ways to kill it
                        reboot
                        or run a kill script like this
                        ps -ef | grep MagicMirror  | awk '{print $2}'| xargs sudo kill -9
                        for info , the steps
                        list the processes and their program path
                        find the ones with MagicMirror
                        print out just the process number
                        sudo kill -9 the process number
                        • D
                          @sdetweil Oh. So just close that Terminal window and ssh into it again, you mean?
                            @davidgagne yes
