    Not updating at midnight...
    24 Posts 3 Posters 2.9k Views 3 Watching
      sdetweil @MMRIZE
      @MMRIZE one thing
      You can’t clear the timer if it has triggered, as the timer has expired. The handle is no longer valid
      • BKeyportB Offline
        @MMRIZE @sdetweil
        the reporter posted this to my github:
        I am not a javascript expert, but have some experience in C++ and
        microcontroller programming.
        I have had some problems with other MagicMirror calendar modules not
        updating the day properly and they also seem to implement workarounds and
        have issues with the DOM updating.
        I did a little looking into this and it seems there must be some generic
        issue with the MagicMirror software allowing modules to implement timers
        and date/time functions in realtime.
        And Sam - I was telling you that it previously was working and works outside of the MM ecosystem - or at least sets it up to work. that’s what got me pissed off - I had done a slew of debugging and it got down to “have you turned off and on again”
        There’s lots of issues I’ve been having - most of them being internal MM functions, that I tend to work around by native JS code and using remote access via the Web server.
        For example: Logging. Don’t seem to work for me. Gotta log via console, so I pull up the web server and Edge’s dev tools.
          sdetweil @BKeyport
          @BKeyport logging
          There are two logs
          Node_helper goes to npm start console
          Modulename.js goes to the browser log
          There are a couple modules that will send the browser log records to the console
          MMM-Logging, mmrize has an updated version, so do I.
          I don’t know why it worked before, or why it’s not working now.
          We added some checking for valid position names, instead of crashing
          We added async to some mm functions, but
          Timeout and interval are js functions.
          Only way to debug the browser side is to use the developer window debugger (sources tab)
            sdetweil @BKeyport
            @BKeyport I’d be interested in the functions that you are having trouble with, as there are very few.
            • BKeyportB Offline
              I think I got it figured out - Based on research elsewhere - if I’m correct: start: function() is only called upon load, correct?
              ASSUMING that’s the case, this seems to work better:
              start: function () {
                  function scheduleMidnightUpdate() {
                      const now = new Date();
                      const nextMidnight = new Date(now);
                      // Set the time to midnight
                      nextMidnight.setHours(24, 0, 0, 0);
                      // Calculate the time remaining until the next midnight
                      const timeUntilMidnight = nextMidnight - now;
                      // Schedule the updateDom method to be called at midnight
                      setTimeout(() => {
                          this.updateDom();
                          // Reschedule the update for the next midnight
                          scheduleMidnightUpdate.call(this);
                      }, timeUntilMidnight);
                  // Call the function to start the first schedule
              Now, This seems to work on testing - but it will fail in testing if I change the clock after starting MM.
              Is there anyway y’all can see to improve this, or am I good?
                MMRIZE @BKeyport
                @BKeyport
                Your DOM might not be rendered yet on “start” imo. I think manipulating DOM after “DOM_OBJECT_CREATED” notification would be safer.
                  sdetweil @MMRIZE
                  @MMRIZE
                  Yes the documented flow is, as I recall on my phone,
                  Init
                  Getstyles
                  Getscripts
                  GetTemplates
                  Start
                  Notification received
                  AllModulesStarted
                  DOMobjectsCreated
                  getDOM
                  • BKeyportB Offline
                    @sdetweil @MMRIZE so, should I move the initial call somewhere else?
                      sdetweil @BKeyport
                      @BKeyport after the notification
                      From the doc
                      DOM_OBJECTS_CREATED - All dom objects are created. The system is now ready to perform visual changes.
                      • BKeyportB Offline
                        @sdetweil said in Not updating at midnight...:
                                setTimeout(() => {
                                    this.updateDom();
                            notificationReceived: function (notification, payload, sender) {
                                if (notification === 'CALENDAR_EVENTS') {
                                    this.storedEvents = JSON.parse(JSON.stringify(payload))
                                    this.updateDom();
                                } else if (notification === 'DOM_OBJECTS_CREATED') {
                        This is the only source I see in the docs of that - a notification. Is that correct?
                        Thanks for the patience after the double misunderstanding.
                        • 2 / 3
