    MMM-Tronity
    14 Posts 3 Posters 3.3k Views 3 Watching
    • B
      bradley1982
      Hi All,
      has anyone got this module to work.
      i keep getting Initialising MMM-Tronity
      any ideas
      many thanks as always
      BKeyportB S 2 Replies Last reply Reply Quote 0
      • B
        bradley1982 @bradley1982
        @bradley1982 got it working guys. I had turn the map feature to false (true) and that seems to have worked!
        thanks for all your help.
        Cheers
        Paul
        S BKeyportB 2 Replies Last reply Reply Quote 2
        • BKeyportB
          BKeyport Module Developer @bradley1982
          @bradley1982
          Let’s do some basic checks.
          When you cloned the module, did you go to the module directory and run npm install ?
          If not, do that now, and report back.
          Did you get the API keys installed in your config, per the readme?
          There may be a dependency missing from the core that it uses, I’m invoking @sdetweil to take a quick look see, and if so, instruct you how to install it.
          the documentation is very poor, so really, I can’t do much more, and I doubt anyone else can, the module is 2 years old at this point, and may just be zombieware.
          Good luck!
            sdetweil @bradley1982
            @bradley1982 there should be messages output from this module as part of magicmirror startup.
            If you use pm2!to auto launch mm, then
            pm2 logs —lines=50
            Will show them. You may need to increase 50 to more
            • B
              bradley1982 @sdetweil
              @sdetweil thanks guys I will try and revert!!
              • B
                @bradley1982
                0|MagicMir | [2024-08-12 20:34:01.170] [LOG]   Socket notification received GET_CAR_DATA
                0|MagicMir | [2024-08-12 20:34:01.173] [LOG]   No auth token!
                0|MagicMir | [2024-08-12 20:34:01.175] [LOG]   Authenticating via url https://api.tronity.tech/authentication
                0|MagicMir | [2024-08-12 20:34:01.176] [LOG]   Using client ID X
                0|MagicMir | [2024-08-12 20:34:01.178] [LOG]   and client secret x
                0|MagicMir | [2024-08-12 20:34:01.180] [LOG]   Completed auth token request
                0|MagicMir | [2024-08-12 20:34:01.765] [LOG]   Response status code 401
                0|MagicMir | [2024-08-12 20:34:01.766] [LOG]   401 - Unauthorized
                0|MagicMir | [2024-08-12 20:37:03.024] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                0|MagicMirror  | [2024-08-12 20:39:01.170] [LOG]   Socket notification received GET_CAR_DATA
                0|MagicMirror  | [2024-08-12 20:39:01.173] [LOG]   No auth token!
                0|MagicMirror  | [2024-08-12 20:39:01.174] [LOG]   Authenticating via url https://api.tronity.tech/authentication
                0|MagicMirror  | [2024-08-12 20:39:01.175] [LOG]   Using client ID x
                0|MagicMirror  | [2024-08-12 20:39:01.176] [LOG]   and client secret x
                0|MagicMirror  | [2024-08-12 20:39:01.181] [LOG]   Completed auth token request
                0|MagicMirror  | [2024-08-12 20:39:03.136] [LOG]   Response status code 401
                0|MagicMirror  | [2024-08-12 20:39:03.138] [LOG]   401 - Unauthorized
                  @bradley1982 didn’t like the authentication info you provided
                  • BKeyportB
                    @sdetweil @bradley1982 If google’s translation is even half good from german, the API is available through their login - there’s no documentation outside of the account system.
                    As such, I’d recommend reviewing their steps to get API key/Auth token from there, and do that - it appears that’s what’s missing.
                      sdetweil @BKeyport
                      @BKeyport doc says
                      • BKeyportB
                        @sdetweil I know what the plugin states, I’m saying the tronity website isn’t providing documentation outside the login system. ;)
                        • B
                          bradley1982
                          Thanks for looking at this guys, presume it is just not working?
                          • B
                            Cheers
                            Paul
                              @bradley1982 cool, thx for the feedback
                              • BKeyportB
                                @bradley1982 so, just for clarification, the missing API was the mapbox, and disabling it worked?
                                Glad it’s fixed.
                                  sdetweil @BKeyport
                                  @BKeyport and the doc says that
