    MMM-PublicTransportBerlin: "HCI Core: Invalid client version"
    5 Posts 3 Posters 879 Views 3 Watching
    • kaiK Offline
      kai
      Hi there,
      I did the last update of the MMM-PublicTransportBerlin module.
      When I start my magic mirror there now is an error message saying
      Fehler beim Abrufen der Daten:
      Das könnte heißen, dass VBB-
      Daten gerade nicht verfügbar sind.
      (in english something like:
      Error when retrieving the data:
      'HCI Core: Invalid client version'
      This could mean that VBB
      data is currently not available.
      I run magic mirror version 2.27 - maybe it’s too old for the latest version of MMM-PublicTransportBerlin?
      Is it somehow possible to reinstall the previous version of MMM-PublicTransportBerlin?
      Any hints appreciated.
      Thank you very much.
      May the code be with you
      -kai
      • F Offline
        ferby09 @kai
        @kai As they are taking their time to update the module, you may do it manually.
        Just edit the file
        modules/MMM-PublicTransportBerlin/node_modules/hafas-client/p/bvg/base.json
        in your MagicMirror directory and apply these changes:
        link text
        Red lines are original lines in the file that have to be deleted and green lines are the new lines.
        That’s all.
        When you update the module in the future you may need to do
        git stash
        before doing the update.
        kaiK 1 Reply Last reply Reply Quote 0
          sdetweil @kai
          @kai see this issue in the module
          https://github.com/deg0nz/MMM-PublicTransportBerlin/issues/225
          • kaiK Offline
            kai @sdetweil
            @sdetweil Thanks a lot!
            So I will wait for the fix of the hafas-client.
            • kaiK kai has marked this topic as solved on
            • F Offline
              ferby09 @kai
              Just edit the file
              link text
              That’s all.
              git stash
              • kaiK Offline
                kai @ferby09
                @ferby09 Cool, thank you very much!
                Now I can see the timetables again.
