    MM2 screen goes black after a couple of hours.
    6 Posts 3 Posters 1.6k Views 4 Watching
    • R
      reilley
      Hello,
      I’m on v2.28.0 , running on an RPi 3 model B rev 1.2 running Bullseye v11.
      The screen saver is not activated on the Raspberry Pi and I don’t use screen blanking modules. I do use MMM-Wallpaper since sky setup is not a mirror. For some reason after a couple of hours, the MM screen will go black but I can see the mouse pointer. I can hit CTRL-Q and exit MM2 and then restart it, but it’s inconvenient to do that.
      Has anyone else seen this issue and if so, how did you resolve it? I’m not seeing any error messages upon exit of the application.
      S E 2 Replies Last reply
        sdetweil @reilley
        @reilley can u tell me what other modules you use?
        easy list from the commandline
        grep module:  ~/MagicMirror/config/config.js | uniq | sort -h
        R 1 Reply Last reply
        • E
          Eli @reilley
          @reilley
          I See this happen also on my mirror from time to time.
          I have not verified it, but to me it seems a memory issue.
          I faced it often when loading many background pictures in short intervals. I changed my interval to a longer period and also resized some images.
          That helped a lot.
          • R
            reilley @sdetweil
            @sdetweil said in MM2 screen goes black after a couple of hours.:
            Hi Sam! Sorry for the delay but I don’t get alerts from this board for some reason.
            To answer your question, I use these modules:
            Alert
            Calendar
            Clock
            MMM-CalendarExt3
            MMM-GoogleCalendar
            MMM-Rain-Map (currently commented out)
            MMM-SmartWebDisplay
            MMM-Wallpaper
            Newsfeed
            Update notification
            Weather
            • R
              reilley @Eli
              @Eli said in MM2 screen goes black after a couple of hours.:
              @reilley
              That helped a lot.
              Hi Eli! I increased the time from every minute to every two minutes to see how that works out. I haven’t tried resizing the files but that sounds like a great idea.
              Thanks!
              Terry
                sdetweil @reilley
                @reilley I had a bug in one of MY modules that allocated space for an image, but didn’t release it, and eventually the browser died. black screen
                took me a year to find it as it appeared random…
                random was how many images it actually displayed, depending on how many times it was active… (when the mirror went to sleep it stopped processing and resumed on wakeup… so every time I went down the hall it would wake up again… )
                but I haven’t seen that problem with any of the modules you listed
