calendar - wrong repeating count when using sliceMultiDayEvents
17 Posts 2 Posters 652 Views 2 Watching
  • S Away
    sdetweil @MarcLandis
    @MarcLandis the fix was accepted and merged
    S 1 Reply Last reply Sep 17, 2024, 9:19 PM Reply Quote 1
    • S Away
      @MarcLandis you could test it now by
      https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current
      remember to do (to get release level dependencies)
      npm run install-mm
      assuming the config in this MM is set correctly for sliceMultiDayEvents
      M 1 Reply Last reply Sep 20, 2024, 3:59 PM Reply Quote 0
        MarcLandis @sdetweil
        @sdetweil I was on a business trip the last days.
        I noticed that multi fullday events will be shown one day in the past:
        This is from today (20. Sep)
        I don’t have the config to show past days enables.
        S 1 Reply Last reply Sep 20, 2024, 6:54 PM Reply Quote 0
        • S Away
          @MarcLandis hm, same calendar entries ?
          is this on the edited calendar.js or the develop branch?
          im on a trip til tuesday
          M 1 Reply Last reply Sep 24, 2024, 8:14 AM Reply Quote 0
            @sdetweil I am going to debug this. The ics was slightly modified, when I noticed the bug.
            M S 2 Replies Last reply Sep 24, 2024, 9:46 AM Reply Quote 0
              MarcLandis @MarcLandis
              @sdetweil I found the reason and created a pull request
              • S Away
                @MarcLandis I pushed a new branch
                here is an UPDATED test version of the fixes for all kinds of calendar date problems.
                NOTE: the changed branch name
                NOTE: this used the node-cal@0.19.0 library UNCHANGED
                best to make a new folder and git clone there
                git clone https://github.com/sdetweil/MagicMirror
                cd MagicMirror
                git checkout fixcaldates2 // <------ note this is a changed branch name
                npm run install-mm
                copy your config.js and custom.css from the prior folder
                and the non-default modules you have installed…
                this ONLY changes the default calendar
                but DOES ship an updated node-ical library too
                if you need to fall back, just rename the folders around again so that
                your original is called MagicMirror
                all the testcases for node-ical and MagicMirror execute successfully.
                the ‘BIG’ change here is to get the local NON-TZ dates for the
                rrule.between()
                all the checking and conversion code is commented out or not used
                the node-ical fixes are for excluded dates (exdate) values being adjusted for DST/STD time… waiting to submit that PR
                one fix in calendar.js for checking if a past date was too far back,
                but it never checked to see IF the event date was in the past… (before today) so it chopped off too many
                and one change in calendarfetcher.js to put out a better diagnostic message of the parsed data… (exdate was excluded cause JSON stringify couldn’t convert the complex structure)
                I added the tests you all have documented
                please re-pull and checkout the new branch (I deleted the old branch)
                and npm run install-mm again
