    Installation Problems
    8 Posts 2 Posters 899 Views 2 Watching
      davidgagne
      I’m attempting (again) to get MM working well on a Pi Zero W.
      After flashing the card with the Legacy 32-bit OS, I connected via ssh and executed bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)" and this was the result:
      Updating packages ...
      [        <=>        ]Installing helper tools ...
      Check current Node installation ...
      Node.js is not installed.
      Installing Node.js ...
      Node.js installation Done! version=v20.9.0
      Check current NPM installation ...
      NPM currently installed. Checking version number.
      Minimum npm version: V10.1.0
      Installed npm version: V10.1.0
      No npm upgrade necessary.
      Cloning MagicMirror ...
      Cloning into 'MagicMirror'...
      remote: Enumerating objects: 399, done.
      remote: Counting objects: 100% (399/399), done.
      remote: Compressing objects: 100% (314/314), done.
      remote: Total 399 (delta 78), reused 185 (delta 70), pack-reused 0 (from 0)
      Receiving objects: 100% (399/399), 457.00 KiB | 797.00 KiB/s, done.
      Resolving deltas: 100% (78/78), done.
      Cloning MagicMirror Done!
      Installing dependencies ...
      (node:8329) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
      (Use `node --trace-warnings ...` to show where the warning was created)
      npm notice
      npm notice New minor version of npm available! 10.1.0 -> 10.8.3
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.8.3
      npm notice Run npm install -g npm@10.8.3 to update!
      npm notice
      npm ERR! code ETIMEDOUT
      npm ERR! errno ETIMEDOUT
      npm ERR! network request to https://registry.npmjs.org/ignore failed, reason:
      npm ERR! network This is a problem related to network connectivity.
      npm ERR! network In most cases you are behind a proxy or have bad network settings.
      npm ERR! network
      npm ERR! network If you are behind a proxy, please make sure that the
      npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
      npm ERR! A complete log of this run can be found in: /home/dvg/.npm/_logs/2024-09-28T18_28_59_417Z-debug-0.log
      I have a blazing fast internet connection at home, and am not behind any sort of proxy or firewall.
      Any thoughts on how to resolve? And what’s with all the MaxListenersExceededWarning warnings?
        davidgagne @sdetweil
        @sdetweil I gave up. I think that MM is simply too demanding to run well on the older Pi Zero W devices. Even after dozens and dozens of attempts, and finally getting it to install perfectly and running, on a blazing fast WiFi connection (close to the signal), multiple modules repeatedly fail and don’t restart on their own, until eventually the MM software itself locks and doesn’t restart.
        At this point I’m going to simply abandon these efforts and wait until I can grab a 3 or 4; I’ll put the Zero to good use doing something else soon.
        Thanks for all your help.
          sdetweil @davidgagne
          @davidgagne timeout is a network problem. do you have a pihole server on your network? others experiencing similar problems have reported that cause.
            @davidgagne the maxlisteners problem is a bug in npm we can’t suppress
              @sdetweil No, I am not running a pihole or any other service or hardware which would cause a network delay, and the device is fairly close to the WiFi router. There’s no reason I can imagine for a network timeout.
                @davidgagne i have never experienced timeout on my pi0w
                  @davidgagne did you make any progress?
                      @davidgagne understood… its tough for sure on the older hardware
