    Mirror not starting after update
    33 Posts 4 Posters 9.6k Views 4 Watching
    • C Offline
      chrisfr1976
      Hello,
      after the latest update my Mirror does not start. I’ve used the update script from sdetweil
      /MagicMirror_scripts
      I’ve used this:
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      Now I get this error message when it starts:
      0|mm  | > magicmirror@2.29.0 start
      0|mm  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|mm  | sh: 1: ./node_modules/.bin/electron: not found
      When using npm install manually I get this:
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.29.0
      npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.29.0
      npm ERR! notsup Required: {"node":">=20.9.0 <21 || 22"}
      npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v21.7.3"}
      npm ERR! A complete log of this run can be found in: /home/chris/.npm/_logs/2024-10-01T18_39_19_616Z-debug-0.log
      I don’t know. Everythis was fine before the update.
      Chris.
      Regards, Chris.
      • X Offline
        xIExodusIx @sdetweil
        So it’s up and running with MM 2.29.
        I think I will never touch it again, only make OS updates/upgrades and nothing else.
          sdetweil @chrisfr1976
          @chrisfr1976 can you open an issue and post the ~/MagicMirror/installers/upgrade.log
          in the short term do
          node -v
          and then try
          npm install electron@31.6.0
            MarcLandis Module Developer @chrisfr1976
            @chrisfr1976 said in Mirror not starting after update:
            npm ERR! notsup Required: {“node”:“>=20.9.0 <21 || 22”}
            npm ERR! notsup Actual: {“npm”:“10.5.0”,“node”:“v21.7.3”}
            You are using an unsupported nodejs version: 21.x
            MM needs either 20.9.0 or any 22.x
              sdetweil @MarcLandis
              @MarcLandis and i just checked 20.9.0 or over
              ill have to look at that
              • C Offline
                chrisfr1976 @sdetweil
                @sdetweil here is my upgrade.log:
                Upgrade started - Di Okt  1 19:33:02 CEST 2024
                system is Linux MagicPi 6.1.21-v7l+ #1642 SMP Mon Apr 3 17:22:30 BST 2023 armv7l GNU/Linux
                user requested to apply changes
                doing test run = false
                the os is PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)" NAME="Raspbian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                Node currently installed. Checking version number.
                Minimum Node version: v20.9.0
                Installed Node version: v21.7.3
                Check current Node installation ...
                No Node.js upgrade necessary.
                Check current NPM installation ...
                NPM currently installed. Checking version number.
                Minimum npm version: V10.1.0
                Installed npm version: V10.5.0
                No npm upgrade necessary.
                saving custom.css
                remote name = origin
                upgrading from version 2.28.0 to 2.29.0
                fetching latest revisions
                git fetch rc=0
                current branch = master
                On branch master
                Your branch is behind 'origin/master' by 1 commit, and can be fast-forwarded.
                  (use "git pull" to update your local branch)
                Untracked files:
                  (use "git add <file>..." to include in what will be committed)
                	core
                	js/main.backup.js
                nothing added to commit but untracked files present (use "git add" to track)
                no files different from github version
                test merge result rc='' , if empty, no conflicts
                executing merge, apply specified
                merge result rc= 0
                 Updating 53fc814f..94c3c699 Fast-forward  .eslintignore
                    2 -  .eslintrc.json
                   93 -  .github/CONTRIBUTING.md
                    2 +-  .github/workflows/automated-tests.yaml
                    2 +-  .../workflows/{depsreview.yaml => dep-review.yaml}
                    2 +  ...{electronRebuild.yaml => electron-rebuild.yaml}
                    6 +-  .github/workflows/enforce-pullrequest-rules.yaml
                    4 +-  .gitignore
                    3 +  .prettierignore
                    2 +-  CHANGELOG.md
                   77 +-  Collaboration.md
                   50 +-  README.md
                    4 +-  cspell.config.json
                  227 +  eslint.config.mjs
                  121 +  fonts/package-lock.json
                   18 +-  fonts/package.json
                    4 +-  index.html
                    1 +  installers/mm.sh
                    4 -  js/app.js
                   29 +-  js/check_config.js
                  104 +-  js/class.js
                   21 +-  js/defaults.js
                    8 +-  js/electron.js
                   50 +-  js/loader.js
                   34 +-  js/main.js
                   22 +-  js/module.js
                   29 +-  js/node_helper.js
                   24 +-  js/server.js
                   12 +-  js/server_functions.js
                   46 +-  js/translator.js
                    6 +-  js/utils.js
                   41 +-  modules/default/calendar/calendar.js
                   38 +-  modules/default/calendar/debug.js
                    3 +-  modules/default/compliments/compliments.js
                  100 +-  modules/default/defaultmodules.js
                    3 +-  .../default/updatenotification/update_helper.js
                   19 +-  modules/default/weather/providers/envcanada.js
                  342 +-  modules/default/weather/providers/openmeteo.js
                   10 +-  .../default/weather/providers/openweathermap.js
                   48 +-  modules/default/weather/providers/pirateweather.js
                   10 +-  modules/default/weather/providers/smhi.js
                   11 +-  modules/default/weather/providers/ukmetoffice.js
                   39 +-  .../weather/providers/ukmetofficedatahub.js
                   64 +-  modules/default/weather/providers/weatherbit.js
                   10 +-  modules/default/weather/providers/weatherflow.js
                   10 +-  modules/default/weather/providers/weathergov.js
                   38 +-  modules/default/weather/providers/yr.js
                   17 +-  modules/default/weather/weather.js
                   13 +-  modules/default/weather/weatherutils.js
                   36 +-  package-lock.json
                 4724 ++++++++++----------  package.json
                   51 +-  splashscreen/MagicMirror.plymouth
                    8 -  splashscreen/MagicMirror.script
                   53 -  splashscreen/splash.png
                  Bin 37062 -> 0 bytes  splashscreen/splash_halt.png
                  Bin 22304 -> 0 bytes  tests/configs/customregions.js
                   23 +  .../modules/calendar/exdate_la_at_midnight_dst.js
                    3 +-  .../modules/calendar/exdate_la_at_midnight_std.js
                    3 +-  .../modules/calendar/exdate_la_before_midnight.js
                    3 +-  .../modules/calendar/exdate_syd_at_midnight_dst.js
                    3 +-  .../modules/calendar/exdate_syd_at_midnight_std.js
                    3 +-  .../modules/calendar/exdate_syd_before_midnight.js
                    3 +-  .../configs/modules/calendar/long-fullday-event.js
                    3 +-  .../modules/calendar/single-fullday-event.js
                    3 +-  .../modules/calendar/sliceMultiDayEvents.js
                   30 +  .../modules/compliments/compliments_cron_entry.js
                   18 +  .../compliments/compliments_e2e_cron_entry.js
                   18 +  tests/e2e/animateCSS_spec.js
                    2 +-  tests/e2e/custom_module_regions_spec.js
                   30 +  tests/e2e/helpers/global-setup.js
                   57 +-  tests/e2e/modules/calendar_spec.js
                   11 -  tests/e2e/modules/compliments_spec.js
                   11 +  tests/e2e/modules/newsfeed_spec.js
                   31 +-  tests/e2e/modules/weather_hourly_spec.js
                    4 +-  tests/e2e/modules_display_spec.js
                    2 +-  tests/e2e/serveronly_spec.js
                    2 +-  tests/electron/modules/calendar_spec.js
                  123 +-  tests/electron/modules/compliments_spec.js
                   36 +  tests/mocks/sliceMultiDayEvents.ics
                   58 +  tests/unit/functions/server_functions_spec.js
                    6 +-  .../modules/default/weather/weather_utils_spec.js
                    2 +-  vendor/package-lock.json
                   36 +-  vendor/package.json
                    3 +-  vendor/vendor.js
                    3 +-  84 files changed, 4147 insertions(+), 3078 deletions(-)  delete mode 100644 .eslintignore  delete mode 100644 .eslintrc.json  rename .github/workflows/{depsreview.yaml => dep-review.yaml} (90%)  rename .github/workflows/{electronRebuild.yaml => electron-rebuild.yaml} (77%)
                create mode 100644 cspell.config.json
                create mode 100644 eslint.config.mjs  delete mode 100755 installers/mm.sh  delete mode 100644 splashscreen/MagicMirror.plymouth  delete mode 100644 splashscreen/MagicMirror.script  delete mode 100644 splashscreen/splash.png  delete mode 100644 splashscreen/splash_halt.png
                create mode 100644 tests/configs/customregions.js
                create mode 100644 tests/configs/modules/calendar/sliceMultiDayEvents.js
                create mode 100644 tests/configs/modules/compliments/compliments_cron_entry.js
                create mode 100644 tests/configs/modules/compliments/compliments_e2e_cron_entry.js
                create mode 100644 tests/e2e/custom_module_regions_spec.js
                create mode 100644 tests/mocks/sliceMultiDayEvents.ics
                processor architecture is armv7l
                updating MagicMirror runtime, please wait
                npm ERR! A complete log of this run can be found in: /home/chris/.npm/_logs/2024-10-01T17_33_19_444Z-debug-0.log
                npm install completed - Di Okt  1 19:33:27 CEST 2024 on base
                Checking for modules with removed libraries
                downloading dumpactivemodules script
                updating dependencies for active modules with package.json files
                	processing for module MMM-Carousel please wait
                up to date, audited 1 package in 2s
                found 0 vulnerabilities
                	processing complete for module MMM-Carousel
                	processing for module MMM-weconnectid please wait
                	processing complete for module MMM-weconnectid
                	processing for module MMM-BackgroundSlideshow please wait
                added 12 packages, and audited 13 packages in 12s
                3 packages are looking for funding
                  run `npm fund` for details
                	processing complete for module MMM-BackgroundSlideshow
                	processing for module mmm-systemtemperature please wait
                added 1 package, and audited 2 packages in 6s
                	processing complete for module mmm-systemtemperature
                	processing for module MMM-pihole-stats please wait
                	processing complete for module MMM-pihole-stats
                	processing for module MMM-NINA please wait
                	processing complete for module MMM-NINA
                	processing for module MMM-Traffic please wait
                added 5 packages, and audited 6 packages in 6s
                	processing complete for module MMM-Traffic
                	processing for module MMM-NowPlayingOnSpotify please wait
                npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                added 131 packages, and audited 694 packages in 1m
                12 packages are looking for funding
                63 vulnerabilities (2 low, 22 moderate, 31 high, 8 critical)
                To address issues that do not require attention, run:
                  npm audit fix
                To address all issues (including breaking changes), run:
                  npm audit fix --force
                Run `npm audit` for details.
                	processing complete for module MMM-NowPlayingOnSpotify
                	processing for module MMM-DWD-Pollen please wait
                added 47 packages, and audited 48 packages in 3s
                2 moderate severity vulnerabilities
                Some issues need review, and may require choosing
                a different dependency.
                	processing complete for module MMM-DWD-Pollen
                	processing for module MMM-SmartWebDisplay please wait
                added 108 packages, and audited 109 packages in 5s
                14 packages are looking for funding
                	processing complete for module MMM-SmartWebDisplay
                	processing for module MMM-CalendarExt3 please wait
                > mmm-calendarext3@1.8.0 postinstall
                > git submodule update --init --recursive
                up to date, audited 1 package in 870ms
                	processing complete for module MMM-CalendarExt3
                	processing for module MMM-MovieListings please wait
                	processing complete for module MMM-MovieListings
                	processing for module MMM-GoogleMapsTraffic please wait
                added 5 packages, and audited 6 packages in 2s
                	processing complete for module MMM-GoogleMapsTraffic
                	processing for module MMM-EmbedURL please wait
                npm WARN deprecated @iconify/iconify@3.1.1: no longer maintained, switch to modern iconify-icon web component
                added 2 packages, and audited 3 packages in 3s
                1 package is looking for funding
                	processing complete for module MMM-EmbedURL
                	processing for module MMM-ImagesPhotos please wait
                added 70 packages, and audited 71 packages in 4s
                13 packages are looking for funding
                	processing complete for module MMM-ImagesPhotos
                restoring custom.css
                removing git alias
                Upgrade ended - Di Okt  1 19:36:05 CEST 2024
                Regards, Chris.
                  @chrisfr1976 need to upgrade nodejs to v22.???
                  then run npm run install-mm
                  i will fix my script in the morning as i am occupied w grandchildren rest of today
                  • C Offline
                    Now I have:
                    node -v
                    v22.9.0
                    And when starting with pm2 I get 2 errors. Fist is directly im PM2:
                    chris@MagicPi:~ $ pm2 start mm
                    (node:3915) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
                    (Use `node --trace-deprecation ...` to show where the warning was created)
                    [PM2] Applying action restartProcessId on app [mm](ids: [ 0 ])
                    [PM2] [mm](0) ✓
                    [PM2] Process successfully started
                    │ id │ name              │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                    │ 1  │ Display_Drehen    │ default     │ N/A     │ fork    │ 3913     │ 2s     │ 26   │ online    │ 0%       │ 1.8mb    │ chris    │ disabled │
                    │ 0  │ mm                │ default     │ N/A     │ fork    │ 3922     │ 0s     │ 1    │ online    │ 0%       │ 1.8mb    │ chris    │ disabled │
                    Second with “pm2 log mm”:
                    0|mm  | App threw an error during load
                    0|mm  | Error: Cannot find module 'logger'
                    0|mm  | Require stack:
                    0|mm  | - /home/chris/MagicMirror/js/app.js
                    0|mm  | - /home/chris/MagicMirror/js/electron.js
                    0|mm  |     at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
                    0|mm  |     at s._resolveFilename (node:electron/js2c/browser_init:2:121498)
                    0|mm  |     at Module._resolveFilename (/home/chris/MagicMirror/node_modules/module-alias/index.js:49:29)
                    0|mm  |     at Module._load (node:internal/modules/cjs/loader:1058:27)
                    0|mm  |     at c._load (node:electron/js2c/node_init:2:17025)
                    0|mm  |     at Module.require (node:internal/modules/cjs/loader:1318:19)
                    0|mm  |     at require (node:internal/modules/helpers:179:18)
                    0|mm  |     at Object.<anonymous> (/home/chris/MagicMirror/js/app.js:7:13)
                    0|mm  |     at Module._compile (node:internal/modules/cjs/loader:1484:14)
                    0|mm  |     at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                    0|mm  |     at Module.load (node:internal/modules/cjs/loader:1295:32)
                    0|mm  |     at Module._load (node:internal/modules/cjs/loader:1111:12)
                    0|mm  |     at Object.<anonymous> (/home/chris/MagicMirror/js/electron.js:4:14)
                    0|mm  | A JavaScript error occurred in the main process
                    0|mm  | Uncaught Exception:
                    0|mm  | [4076:1001/220004.817112:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.817605:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.817935:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.818158:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.818461:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.818629:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.818957:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.819176:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.819569:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.819796:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.820180:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.820424:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.820811:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.821043:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                    0|mm  | [4076:1001/220004.821511:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                    and so on…
                    Regards, Chris.
                      @chrisfr1976
                      Error: Cannot find module ‘logger’
                      you have to do
                      npm run install-mm ( in the MagicMirror folder)
                      after updating nodejs
                      S X 2 Replies Last reply Reply Quote 0
                        @chrisfr1976 I have just updated the upgrade script to check for node V21 and if found, upgrade to 22.9
                        • C Offline
                          @sdetweil I did the npm run install-mm already. Still the same error.
                          I have a copy of my SD Card. I could start from last version again only with the update script. Maybe this helps.
                          Chris.
                          Regards, Chris.
                            @chrisfr1976 its been reported that the upgrade script doesn’t restore the installers/MagicMirror.sh we took out of the MagicMirror repo and put in my repo
                            pm2 info 0
                            will list out the details of the managed app. it will list the program started
                            S C 2 Replies Last reply Reply Quote 0
                              I have fixed the upgrade script to save/restore the installers folder and mm.sh
                              • X Offline
                                how can I update nodejs?
                                I have:
                                nodejs -v
                                v18.19.0
                                and
                                node -v
                                v20.9.0
                                npm install nodejs@latest
                                does not change my nodejs version.
                                  sdetweil @xIExodusIx
                                  @xIExodusIx what OS are you on?
                                  lsb_release -a
                                  and
                                  uname -a
                                  will show
                                  did you use my upgrade script? it will upgrade node too
                                  • X Offline
                                    Raspberry Pi 4
                                    OS = bookworm 64bit
                                      @xIExodusIx did you use my upgrade script?
                                        @chrisfr1976 can you show me the output of thew npm run install-mm
                                        do it this way (from the MM folder of course)
                                        cd ~/MagicMirror
                                        npm run install-mm >somefile.txt 2>&1
                                        then when it finishes all the output is in somefile.txt
                                        X 1 Reply Last reply Reply Quote 0
                                        • X Offline
                                          lsb_release -a shows:
                                          No LSB modules are available.
                                          Distributor ID: Debian
                                          Description: Debian GNU/Linux 12 (bookworm)
                                          Release: 12
                                          Codename: bookworm
                                          uname -a shows:
                                          Linux MirrorPi 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt2 (2024-10-01) aarch64 GNU/Linux
                                          yes I used your upgrade-script with apply and also with force.
                                          pm2 start MagicMirror will start the MM but it won’t show up!
                                          npm start results in following errors:
                                          [41163:1002/155017.678545:ERROR:ozone_platform_x11.cc(245)] Missing X server or $DISPLAY
                                          [41163:1002/155017.688550:ERROR:env.cc(258)] The platform failed to initialize. Exiting.
                                          /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                            @xIExodusIx before this morning, my upgrade script had a bug
                                            do
                                            cd ~/MagicMirror
                                            ls installers
                                            that should fail (not found)
                                            then do
                                            mkdir installers
                                            curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/mm.sh >installers/mm.sh
                                            chmod +x installers/mm.sh
                                              @xIExodusIx also, if you do
                                              cd ~/MagicMirror
                                              npm start
                                              does MM come up?
