    MMM-ShellyStatusTable
    1 Posts 1 Posters 775 Views 2 Watching
    • C Offline
      chrisfr1976
      Hello,
      finally I finished my first MM-module. I was struggling with the existing shelly modules so I decided to create a new one which uses only the cloud-api in order to be independent from the device itself.
      The MMM-ShellyStatusTable module displays the switch status and power consumption of multiple Shelly devices in a table on the MagicMirror², including a total consumption sum. It regularly updates the data via the Shelly Cloud API Gen 1 and Gen 2+. So it should be independed from the devices in your smart home.
      It is currently hard to say if every device is considered correctly. I have the following devices and it works:
      • Shelly Plug / PlugS
      • Shelly Plus Plug S
      • Shelly Plus 1 PM
      Currently no translation is available. It will follow in the next days. But it is not hard to fix by your own, I hope.
      I’m not really a module developer but ChatGPT finally fixed it :-)
      Please try and give me a feedback if you discover some problems. Maybe I can help, but I’m no sure at all :laugh:
      Regards, Chris.
