    MMM-GoogleAssistant error when trying to get reponse?
    7 Posts 4 Posters 1.2k Views 4 Watching
      sillen
      Hi everyone, I’m having a problem with the MMM-GoogleAssistant module. Whenever I say something, it gets stuck on loading for about 30 seconds and then gives the following error at the end of the log:
      0|mm  | [2024-11-05 15:51:26.173] [LOG]   [DETECTOR] [RULES] Detected: jarvis from: Porcupine
      0|mm  | [2024-11-05 15:51:26.187] [LOG]   [GA] [ACTIVATE_ASSISTANT] QUERY: {
      0|mm  |   type: 'MIC',
      0|mm  |   key: null,
      0|mm  |   lang: 'en-US',
      0|mm  |   status: 'standby',
      0|mm  |   chime: true
      0|mm  | }
      0|mm  | [2024-11-05 15:51:26.190] [LOG]   [GA] [ASSISTANT] Used project_id: plenary-justice-369222
      0|mm  | [2024-11-05 15:51:26.192] [LOG]   [GA] [ASSISTANT] deviceModelId is: plenary-justice-369222-bugsounet_GA
      0|mm  | [2024-11-05 15:51:26.194] [LOG]   [GA] [ASSISTANT] deviceId is MMM-GoogleAssistant
      0|mm  | [2024-11-05 15:51:26.338] [LOG]   [GA] [MP3] ~ MP3 FILE CREATING: /home/pi/MagicMirror/modules/MMM-GoogleAssistant/tmp/lastResponse.mp3
      0|mm  | [2024-11-05 15:51:26.381] [LOG]   [GA] [ASSISTANT] MIC:RECORDING START.
      0|mm  | [2024-11-05 15:51:26.431] [LOG]   [GA] [LPCM16] Start listening: 1 channels - use: arecord - device: default - sample rate: 16000
      0|mm  | [2024-11-05 15:51:28.863] [LOG]   [GA] [ASSISTANT] CONVERSATION:TRANSCRIPTION { transcription: 'pil', done: false }
      0|mm  | [2024-11-05 15:51:28.873] [LOG]   [GA] [ASSISTANT] CONVERSATION:TRANSCRIPTION { transcription: 'pilot', done: false }
      0|mm  | [2024-11-05 15:51:29.217] [LOG]   [GA] [ASSISTANT] CONVERSATION:TRANSCRIPTION { transcription: 'pill', done: false }
      0|mm  | [2024-11-05 15:51:29.221] [LOG]   [GA] [ASSISTANT] CONVERSATION:TRANSCRIPTION { transcription: 'pilot', done: false }
      0|mm  | [2024-11-05 15:51:29.225] [LOG]   [GA] [ASSISTANT] CONVERSATION:END_OF_UTTERANCE
      0|mm  | [2024-11-05 15:51:29.225] [LOG]   [GA] [ASSISTANT] MIC:RECORDING_END
      0|mm  | [2024-11-05 15:51:29.230] [LOG]   [GA] [ASSISTANT] CONVERSATION:TRANSCRIPTION { transcription: 'pilot', done: true }
      0|mm  | [2024-11-05 15:51:29.257] [LOG]   [GA] [LPCM16] Stop listening
      0|mm  | [2024-11-05 15:51:29.895] [LOG]   [GA] [ASSISTANT] CONVERSATION:AUDIO 1600
      0|mm  | [2024-11-05 15:51:29.900] [LOG]   [GA] [ASSISTANT] CONVERSATION:AUDIO 1600
      0|mm  | [2024-11-05 15:51:29.908] [LOG]   [GA] [ASSISTANT] CONVERSATION:AUDIO 1600
      0|mm  | [2024-11-05 15:51:29.912] [LOG]   [GA] [ASSISTANT] CONVERSATION:AUDIO 1600
      0|mm  | [2024-11-05 15:51:29.915] [LOG]   [GA] [ASSISTANT] CONVERSATION:AUDIO 1600
      0|mm  | [2024-11-05 15:51:29.918] [LOG]   [GA] [ASSISTANT] CONVERSATION:AUDIO 1600
      0|mm  | [2024-11-05 15:51:29.922] [LOG]   [GA] [ASSISTANT] CONVERSATION:AUDIO 1600
      0|mm  | [2024-11-05 15:51:29.926] [LOG]   [GA] [ASSISTANT] CONVERSATION:AUDIO 1600
      0|mm  | [2024-11-05 15:51:29.930] [LOG]   [GA] [ASSISTANT] CONVERSATION:AUDIO 1600
      0|mm  | [2024-11-05 15:51:29.936] [LOG]   [GA] [ASSISTANT] CONVERSATION:AUDIO 960
      0|mm  | [2024-11-05 15:51:29.952] [LOG]   [GA] [ASSISTANT] CONVERSATION:RESPONSE
      0|mm  | [2024-11-05 15:51:40.011] [LOG]   MMM-VoiceCompanion: Still listening for wake word...
      0|mm  | [2024-11-05 15:51:40.013] [LOG]   MMM-VoiceCompanion: Still listening for wake word...
      0|mm  | [2024-11-05 15:52:10.018] [LOG]   MMM-VoiceCompanion: Still listening for wake word...
      0|mm  | [2024-11-05 15:52:28.864] [LOG]   [GA] [MP3] MP3 FILE CREATED 15360 bytes
      0|mm  | [2024-11-05 15:52:28.865] [LOG]   [GA] [ASSISTANT] CONVERSATION_ERROR: Error: 13 INTERNAL: Received RST_STREAM with code 2 (Internal server error)
      0|mm  | [2024-11-05 15:52:28.868] [LOG]   [GA] [ASSISTANT] CONVERSATION_ALL_RESPONSES_RECEIVED
      0|mm  | [2024-11-05 15:52:28.869] [LOG]   [GA] [ASSISTANT] CONVERSATION_END:COMPLETED
      0|mm  | [2024-11-05 15:52:28.870] [LOG]   [GA] [ASSISTANT] CONVERSATION_PP:RESPONSE_AUDIO_PROCESSED
      0|mm  | [2024-11-05 15:52:28.871] [LOG]   [GA] [MP3] Try to close but MP3 not created !
      0|mm  | [2024-11-05 15:52:28.874] [LOG]   [GA] [ACTIVATE_ASSISTANT] RESULT {
      0|mm  |   error: {
      0|mm  |     error: 'CONVERSATION_ERROR',
      0|mm  |     message: 'Error: 13 INTERNAL: Received RST_STREAM with code 2 (Internal server error)',
      0|mm  |     audio: false
      0|mm  |   },
      0|mm  |   action: null,
      0|mm  |   text: null,
      0|mm  |   screen: null,
      0|mm  |   audio: {
      0|mm  |     path: '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/tmp/lastResponse.mp3',
      0|mm  |     uri: 'tmp/lastResponse.mp3'
      0|mm  |   },
      0|mm  |   transcription: { transcription: 'pilot', done: true },
      0|mm  |   continue: false,
      0|mm  |   volume: null,
      0|mm  |   lastQuery: {
      0|mm  |     type: 'MIC',
      0|mm  |     key: null,
      0|mm  |     chime: true
      0|mm  |   }
      0|mm  | }
      0|mm  | [2024-11-05 15:52:28.934] [LOG]   [DETECTOR] [RULES] Start listening. 1 Models
      This issue is strange since I hadn’t encountered it before, but recently, it’s been happening every single time. I tried updating and reinstalling MMM-GoogleAssistant and followed the latest steps in the wiki. If anyone has insights into why this RST_STREAM Error might be occurring, I’d really appreciate your help!
        sillen
        i found how too login too bugsonet forum it was all just very unfamiliar but now i found it so i will be moving my question there. but if anyone has any tips on this please dont hesitate too reply.
        bugsounetB A 2 Replies Last reply
        • bugsounetB
          bugsounet Banned @sillen
          Hi, i think it’s related to grpc library.
          I planed to release MMM-GoogleAssistant v8.x in few days. It should fix. (I will update this library)
            sillen @bugsounet
            @bugsounet ahh okay. Thank you for your hard work and keep it up.
            • L
              lucallmon
              It looks like all of the google apps and APIs are not working. My gmail, mycommute, and calendar are all not working.
                sillen @lucallmon
                @lucallmon oh okay thats interesting. didnt know that
                • A
                  atwist @sillen
                  @sillen can you tell me where the forum is? I can’t find it anywhere.
