    I can't for the love of god understand what's wrong with my config
    12 Posts 3 Posters 6.5k Views 3 Watching
    • B
      bougle
      Re: Sync private iCloud calendar with MagicMirror
      I followed this tutorial and was able to install and add everything as instructed (not without any issues but yes). I added the .ics file links to the calendar module in the config file but it just shows that there are no events.
      I am relatively new to this and have no clue what am I doing wrong. I am able to discover and sync vdirsyncer. I do not get any errors. Could someone please help me out here?
      I have attached my config file.
      let config = {
              address: "localhost",   // Address to listen on, can be:
              port: 8080,
              basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],  // Set [] to allow all IP addresses
              useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
              httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
              httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
              language: "en",
              locale: "en-US",
              timeFormat: 24,
              units: "metric",
                              module: "alert",
                              module: "updatenotification",
                              position: "top_bar"
                              module: "clock",
                              position: "top_left"
                                      broadcastPastEvents: true, // <= IMPORTANT to see past events
                                           url: "http://localhost:8080/modules/calendars/D8CC2057-AD72-45D1-9AC7-942E8C2A5DD1.ics",
                                           name: "errinerungen", // <-- specify calendar name
                                           color: "skyblue", // <-- if you don't want to get color, just remove this line.
                                           broadcastPastEvents: true, // <-- need to broadcast past events
                                           maximalNumberOfDays: 30, // <-- how old events would be broadcasted
                                           maximumEntries: 100, // <-- assign enough number to prevent truncating new events by old events.
                                           symbol: 'camera', // <-- when you want to display simbol. If you don't want, just set as `symbol:[],`
                                                      symbol: "calendar-check",
                                                      url: "http://localhost:8080/modules/calendars/9F91CE4D-8088-4518-9239-C4FCC3DA0EC4.ics",
                                                      color: "red"
                                                      url: "http://localhost:8080/modules/calendars/1AAA8AEA-457E-487D-92E2-3060BF33C468.ics",
                                                      color: "purple"
                              module: "MMM-CalendarExt3Agenda",
                               header: "My Agenda",
                                 instanceId: "basicCalendar",
                                 locale: 'en-US',
                                 firstDayOfWeek: 1,
                                 startDayIndex: -1,
                                              endDayIndex: 10,
                                 calendarSet: ['errinerungen', 'privat', 'arbeit'],
                              module: "compliments",
                              position: "lower_third"
                              module: "weather",
                                      weatherProvider: "openmeteo",
                                      type: "current",
                                      lat: 52.2659,
                                      lon: 10.5267
                              module: "weather",
                              header: "Weather Forecast",
                                      type: "forecast",
                                      lat: 52.2659,
                                      lon: 10.5267
                              module: "newsfeed",
                              position: "bottom_bar",
                                     feeds: [
                                                      title: "New York Times",
                                                      url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                      showSourceTitle: true,
                                      showPublishDate: true,
                                      broadcastNewsFeeds: true,
                                      broadcastNewsUpdates: true
      vdirsyncer discover
      pi@raspberrypi:~ $ vdirsyncer discover
      Discovering collections for pair iCloud_to_MagicMirror
      Mirror:
        - "1AAA8AEA-457E-487D-92E2-3060BF33C468"
        - "9F91CE4D-8088-4518-9239-C4FCC3DA0EC4"
        - "D8CC2057-AD72-45D1-9AC7-942E8C2A5DD1"
      iCloud:
        - "1AAA8AEA-457E-487D-92E2-3060BF33C468" ("Arbeit")
        - "D8CC2057-AD72-45D1-9AC7-942E8C2A5DD1" ("Erinnerungen")
        - "9F91CE4D-8088-4518-9239-C4FCC3DA0EC4" ("Privat")
      Saved for iCloud_to_MagicMirror: collections = ["9F91CE4D-8088-4518-9239-C4FCC3DA0EC4", "D8CC2057-AD72-45D1-9AC7-942E8C2A5DD1", "1AAA8AEA-457E-487D-92E2-3060BF33C468"]
      vdirsyncer sync
      pi@raspberrypi:~ $ vdirsyncer sync
      Syncing iCloud_to_MagicMirror/9F91CE4D-8088-4518-9239-C4FCC3DA0EC4
      Syncing iCloud_to_MagicMirror/D8CC2057-AD72-45D1-9AC7-942E8C2A5DD1
      Syncing iCloud_to_MagicMirror/1AAA8AEA-457E-487D-92E2-3060BF33C468
      S C 3 Replies Last reply
        sdetweil @bougle
        @bougle if you edit the synced ics file, are there events present?
        ics is just a text file
          sdetweil @bougle
          @bougle said in I can't for the love of god understand what's wrong with my config:
          is the synced ics IN the modules folder tree??
          you had to MAKE that calendars folder, right?
          it MUST be in the MagicMirror folder tree to use localhost:8080
          B 1 Reply Last reply
          • C
            chrisfr1976 @bougle
            @bougle
            Try
            let config = {address: "0.0.0.0", …….
            And
            url: "http://0.0.0.0:8080/modules/calendars……..
            Worked for me.
            Br Chris
            Regards, Chris.
            S B 2 Replies Last reply
              sdetweil @chrisfr1976
              @chrisfr1976 technically you shouldn’t need this
              “0.0.0.0” means listen on all active network interfaces (wifi and ethernet) without having to specify their addresses ( which would be impossible to do for multiple interfaces)
              the http://0.0.0.0:8080 makes no sense to me , unless they coded in a hack to say keep looking for whatever interface works. although localhost does that same thing
              the other thing “0.0.0.0” does is allow incoming requests from outside this system, where localhost restricts incoming request to ONLY apps on this same system
              • B
                bougle @sdetweil
                @sdetweil Thank you for your reply.
                Yes I do already have all the three .ics files in
                ~/MagicMirror/modules/calendars
                • B
                  bougle @chrisfr1976
                  @chrisfr1976 Thanks for the suggestion. I will try it out today and report back.
                    sdetweil @bougle
                    @bougle ok, next, can you look at the output of npm start and see the message
                    broadcasting xxx events for calendar —url----
                    for each url?
                      @bougle make any progress?
                      • B
                        bougle @sdetweil
                        Sorry for the late reply. Super swamped because of university.
                        here is the log:
                        [2024-11-09 10:34:54.714] [INFO]  Checking git for module: MMM-CalendarExt3Agenda
                        [2024-11-09 10:34:55.000] [INFO]  Calendar-Fetcher: Broadcasting 0 events from http://0.0.0.0:8080/modules/calendars/9F91CE4D-8088-4518-9239-C4FCC3DA0EC4.ics.
                        [2024-11-09 10:34:55.041] [INFO]  Calendar-Fetcher: Broadcasting 0 events from http://0.0.0.0:8080/modules/calendars/D8CC2057-AD72-45D1-9AC7-942E8C2A5DD1.ics.
                        [2024-11-09 10:34:55.055] [INFO]  Calendar-Fetcher: Broadcasting 0 events from http://0.0.0.0:8080/modules/calendars/1AAA8AEA-457E-487D-92E2-3060BF33C468.ics.
                        It shows that there are 0 events. And btw, the .ics files are completely empty.
                        • B
                          bougle
                          UPDATE!!
                          Today, I re-ran
                          vdirsyncer discover
                          vdirsyncer sync
                          And was able to sync with the calendar and it works!! I am not exactly sure why but I did perform a iCloud sync too earlier.
                          Thanks @chrisfr1976 and @sdetweil for your help:)
                          Reply Quote 1
                            sdetweil @bougle
                            @bougle awesome, glad you got it!
                            Reply Quote 1
