    Changing table cell in calendar module using custom.css
    11 Posts 2 Posters 1.7k Views 2 Watching
      sdetweil @evroom
      @evroom you cannot add or change a classname string
      class=“foo”
      to add “bar” class too
      class =“foo bar”
      but you CAN change the behavior of the other classes to match what adding another class could do
      OR , you could add the styles to the ELEMENTS you WOULD have added the bar class to…
      just_have_to_select_them {
      styles
      as an example of a complex selector in my MMM-Config, I want to hide an element on a library generated element
      .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item%201"] {
        display: none;
      this is
      elements with the possibly-hidden-tab class
      its second child div
      its immed child div
      its immed child div
      its immed child div
      its immed child ul
      its immed only child li
      with an a element containing a rel attribute value of “Item 1”
      (spaces have to be encoded, but for clarity I left it out here)
