    MMM-ShellyPV
    4 Posts 2 Posters 904 Views 2 Watching
    • C Offline
      chrisfr1976
      Hello,
      After creating my first Shelly MMM module, I knew it was time for an upgrade. I wanted something with a more polished, visually appealing look than a basic table. Introducing my new module:
      ShellyPV
      Example:
      ShellyPV
      This module can also more or less replace the MMM-ShellyStatusTable. If a device is switched on or off it is dynamic displayed in the list.
      Bild Text
      Give it a try and give me Star ;)
      Cheers,
      Chris.
      Regards, Chris.
      C 1 Reply Last reply Reply Quote 2
      • C Offline
        chrisfr1976 @chrisfr1976
        I’ve fixed an issue, when the power gets a negative value if the solar panel are producing. I couldn’t test this last night g
        Now it should be even better than before.
        BR Chris
        Regards, Chris.
          SuVo @chrisfr1976
          @chrisfr1976
          On my MagicMirror MMM-ShellyStatusTable is working.
          But MMM-ShellyPV only shows a ring, no data, no table.
          Is it correct to add the config under module: “MMM-ShellyStatusTable” as you have written?
          • C Offline
            chrisfr1976 @SuVo
            @SuVo If you want to run both modules in parallel mode you need of course each module separate: So MMM-ShellyStatusTable and MMM-ShellyPV is needed in the modules folder and config.js file.
            You might discover some error messages during startup. The node_helper.js is nearly the same. But the errors causes no trouble.
            But I’ve just updated the whole module. I wanted to integrate the table in the MMM-ShellyPV module. See the modifications here: ShellyPVUpdate
            I think you’ll like it.
            Regards, Chris.
