    problem with my MagicMirror kiosk client
    4 Posts 2 Posters 856 Views 2 Watching
    • D
      dnj0104
      Hello Folks
      I got a little problem not directly with MM but in the same area its Xorg/xserver/xinit that makes me a bit confused,
      I got the following setup - server runs MM -> client (raspberry pi) runs raspbian os(bookworm) with chromium in kiosk mode-> client
      connected to computer screeen behind glass.
      A couple a days ago I pulled the power plug from the client, after a while I inserted the poweplug again and the problem started
      I have tried several things, remove and reinstalled xorg , changed user group, tried to remove xorg.conf but I couldnt find it.
      now I could need some help, is it possible to solve my problem without wipe the sdcard and start over ?
      and here is the xorg log :
      X.Org X Server 1.21.1.7
      X Protocol Version 11, Revision 0
      [    28.228] Current Operating System: Linux MMclient 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt3 (2024-10-08) aarch64
      [    28.229] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1080 bcm2708_fb.fbheight=1920 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5852fd22-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=SE
      [    28.272] xorg-server 2:21.1.7-3+rpt3+deb12u8 (https://www.debian.org/support)
      [    28.278] Current version of pixman: 0.42.2
      [    28.298] 	Before reporting problems, check http://wiki.x.org
      	to make sure that you have the latest version.
      [    28.298] Markers: (--) probed, (**) from config file, (==) default setting,
      	(++) from command line, (!!) notice, (II) informational,
      	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
      [    28.333] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Nov 24 10:27:31 2024
      [    28.344] (==) Using config directory: "/etc/X11/xorg.conf.d"
      [    28.355] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
      [    28.365] (==) ServerLayout "ServerLayout0"
      [    28.365] (==) No screen section available. Using defaults.
      [    28.365] (**) |-->Screen "Default Screen Section" (0)
      [    28.365] (**) |   |-->Monitor "<default monitor>"
      [    28.366] (==) No device specified for screen "Default Screen Section".
      	Using the first device section listed.
      [    28.366] (**) |   |-->Device "kms"
      [    28.366] (==) No monitor specified for screen "Default Screen Section".
      	Using a default monitor configuration.
      [    28.367] (**) Option "BlankTime" "0"
      [    28.367] (**) Option "StandbyTime" "0"
      [    28.367] (**) Option "SuspendTime" "0"
      [    28.367] (**) Option "OffTime" "0"
      [    28.367] (**) Option "Debug" "dmabuf_capable"
      [    28.367] (==) Automatically adding devices
      [    28.367] (==) Automatically enabling devices
      [    28.367] (==) Automatically adding GPU devices
      [    28.367] (==) Automatically binding GPU devices
      [    28.375] (==) Max clients allowed: 256, resource mask: 0x1fffff
      [    28.390] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
      [    28.390] 	Entry deleted from font path.
      [    28.400] (==) FontPath set to:
      	/usr/share/fonts/X11/misc,
      	/usr/share/fonts/X11/100dpi/:unscaled,
      	/usr/share/fonts/X11/75dpi/:unscaled,
      	/usr/share/fonts/X11/Type1,
      	/usr/share/fonts/X11/100dpi,
      	/usr/share/fonts/X11/75dpi,
      	built-ins
      [    28.400] (==) ModulePath set to "/usr/lib/xorg/modules"
      [    28.400] (**) Extension "DPMS" is disabled
      [    28.401] (II) The server relies on udev to provide the list of input devices.
      	If no devices become available, reconfigure udev or disable AutoAddDevices.
      [    28.401] (II) Loader magic: 0x558c0a0ef0
      [    28.401] (II) Module ABI versions:
      [    28.401] 	X.Org ANSI C Emulation: 0.4
      [    28.401] 	X.Org Video Driver: 25.2
      [    28.401] 	X.Org XInput driver : 24.4
      [    28.401] 	X.Org Server Extension : 10.0
      [    28.403] (++) using VT number 1
      [    28.403] (--) controlling tty is VT number 1, auto-enabling KeepTty
      [    28.411] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
      [    28.412] (II) no primary bus or device found
      [    28.412] (II) LoadModule: "glx"
      [    28.419] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
      [    28.506] (II) Module glx: vendor="X.Org Foundation"
      [    28.506] 	compiled for 1.21.1.7, module version = 1.0.0
      [    28.506] 	ABI class: X.Org Server Extension, version 10.0
      [    28.506] (II) LoadModule: "modesetting"
      [    28.508] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
      [    28.537] (II) Module modesetting: vendor="X.Org Foundation"
      [    28.537] 	compiled for 1.21.1.7, module version = 1.21.1
      [    28.537] 	Module class: X.Org Video Driver
      [    28.537] 	ABI class: X.Org Video Driver, version 25.2
      [    28.537] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
      [    28.538] (WW) Falling back to old probe method for modesetting
      [    28.538] (EE) open /dev/dri/card0: No such file or directory
      [    28.538] (EE) No devices detected.
      [    28.538] (EE)
      Fatal server error:
      [    28.538] (EE) no screens found(EE)
      [    28.538] (EE)
      Please consult the The X.Org Foundation support
      	 at http://wiki.x.org
       for help.
      [    28.538] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
      [    28.538] (EE)
      [    28.664] (EE) Server terminated with error (1). Closing log file.
        sdetweil @dnj0104
        @dnj0104 said in problem with my MagicMirror kiosk client:
        [ 28.355] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
        [ 28.365] (==) ServerLayout “ServerLayout0”
        [ 28.365] () |–>Screen “Default Screen Section” (0)
        [ 28.365] (
        ) | |–>Monitor “”
        [ 28.366] (==) No device specified for screen “Default Screen Section”.
        [ 28.366] (**) | |–>Device “kms”
        [ 28.366] (==) No monitor specified for screen “Default Screen Section”.
        my guess is the sd card is damaged
          sdetweil @dnj0104
          @dnj0104 sorry to ask this, but you DO have a backup of the card, right? I know
          • D
            dnj0104 @sdetweil
            Hey!
            Thanks for answering, and no I have not a backup of client SDcard,
            BUT trust me, I will have that in the future… but I have backup of my shell scripts, so it feels pretty ok anyways.
