    MMM-EmbedURL with MMM-Pages - Website reload....
    11 Posts 3 Posters 3.6k Views 3 Watching
    • BKeyportB
      BKeyport Module Developer
      I have MMM-pages (@sdetweil 's version) and MMM-EmbedURL (@wishmaster270) - working together on my system. Evertthing is great, EXCEPT this code below.
      What happens is that the website at my docker is loading, then it stops itself and reloads - blanking the screen area for 2-3 seconds while it thinks about it. Unfortunately, even though it’s a docker container and I have “Full control” – it is a very rudimentary program - and the web API is weak at best (Thus the turning off of the time stamp, etc)
      What’s going on here? Is there anything I can do to keep it from blanking and restarting (I think when it’s hidden it’s paused?)
      If it helps, the page is this program -> https://www.clearskyinstitute.com/ham/HamClock/ - you can look around for suggestions.
      Thanks.
          		module: "MMM-pages",
              			["page1"],
              			["page2"],
              			["page3"],
            			animationTime: 2000,
            			rotationTime: 10000,
      			module: "MMM-EmbedURL",
      			classes: "page2",
      				updateInterval: 3600,
      				animationSpeed: 0,
      				appendTimestamp: false,
      				embed: [
      					"http://docker.local:8081/live.html",
      (any malformed JS above is a paste error, it is correct in code)
      • wishmaster270W
        wishmaster270 Module Developer @sdetweil
        Hi Sam,
        you are right. But i do not want the content to be fixed as some users want the content to be recreated after the configured interval.
        I just released a new version 0.0.8 of the module which introduces a updateDomOnShow option. If the option is set to false the module uses the old html elements after a resume. Maybe this fixes the issue.
          sdetweil @BKeyport
          @BKeyport embedurl doesn’t support the show/hide functions so it COULD be loading at the time it is shown
          It should pause while hidden, resume when shown
          How long does the page take to load?
          • BKeyportB
            It shows, then resets, takes 2-3 seconds to show back up, then runs normally. The problem is that it’s just annoying to have it flash in and then blank, then come up and run.
              sdetweil @BKeyport
              @BKeyport not sure @wishmaster270 got any ideas?
              Looks like you are creating new elements on each getDom(). the resume () will cause a getDom() which will cause the page reload in the new iframe object
              • wishmaster270W
                @sdetweil Hi, the module calls the updateDom function every time it gets resumed in the current implementation.
                I am not sure if I can implemt a block option to skip the update dom but reset the timer for the regular updates.
                  sdetweil @wishmaster270
                  @wishmaster270 you could make the content you return fixed …
                  getDom(){
                      if(!this.already_created){
                         build content
                         this.already_created=new content
                      return this.already_created
                  I do this in a few modules to reduce/eliminate the flash
                  nothing says you HAVE to CREATE the content on each getDom()
                  just have to return something
                  so minor change… no logic change
                  • wishmaster270W
                    Hi Sam,
                      @wishmaster270 thanks… I didn’t know if the iframe would reload itself on show
                      @BKeyport give this a try
                      • BKeyportB
                        Tom, is it updateDomOnShow or updateDomOnResume ?
                        Documentation shows the latter.
                        • BKeyportB
                          BKeyport Module Developer @BKeyport
                          I put them both in, and that fixed it - thanks, Tom.
                          wishmaster270W 1 Reply Last reply Reply Quote 1
                          • wishmaster270W
                            wishmaster270 Module Developer @BKeyport
                            @BKeyport Sorry, to one I’m the documentation is the correct one.
                            Great to hear it is working.
