    MagicMirror Install Script Message
    3 Posts 2 Posters 616 Views 2 Watching
    • plainbrokeP
      plainbroke
      Sam,
      I got this message when installing MM with your script.
      (node:8435) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
      Approximately 83 times, as close as I could get a count on them.
      Is it anything I need to worry about.
      • plainbrokeP
        plainbroke @sdetweil
        Thanks for the update.
          sdetweil @plainbroke
          @plainbroke no its a bug in npm, no harm done
          plainbrokeP 1 Reply Last reply Reply Quote 0
          • plainbrokeP
            • plainbrokeP plainbroke has marked this topic as solved on
