    MMM-WunderGround - Display hourly only?
    11 Posts 2 Posters 10.0k Views 2 Watching
    • C Offline
      Camelblack
      Hi is it possible to only display hourly forecasts and hide daily?
      I saw there was a fade option, but I was unable to hide the daily forecast.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Camelblack
        @Camelblack vertical or horizontal layout?
        • C Offline
          Camelblack @strawberry 3.141
          @strawberry-3.141 preferably horizontal. Is there a way to fully hide days from vertical (not just fade them) ?
          I see the minimum value on days is 1.
          fcdaycount	How many days of forecast to return. Specified by config.js
          Possible values: 1 - 10
          Default value: 7 (7 days)
          This value is optional. By default the wunderground module will return 7 days.
            @Camelblack custom.css
            .MMM-WunderGround table.small:nth-of-type(3),
            .MMM-WunderGround hr.hrDivider:nth-of-type(3) {
                display:none;
            C 1 Reply Last reply Reply Quote 1
            • C Offline
              @strawberry-3.141 Thank you very much!
              Unfortunately it seems that I didn’t implement it correctly.
               * Magic Mirror                                      *
               * Custom CSS                                        *
               * By Michael Teeuw http://michaelteeuw.nl           *
               * MIT Licensed.                                     *
               * Add any custom CSS below.                         *
               * Changes to this files will be ignored by GIT. *
               body {
                  display:none;
              Isn’t this how it supposed to look in custom.css?
                @Camelblack no remove body {
                • C Offline
                  @strawberry-3.141
                   * Magic Mirror                                      *
                   * Custom CSS                                        *
                   * MIT Licensed.                                     *
                      display:none;
                  It looks like this now, but the mirror is still displaying 4 days, do I need to change any other files than custom.css?
                    @Camelblack can you share your config
                    • C Offline
                      @strawberry-3.141 Sure:)
                          module: 'MMM-WunderGround',
                          position: 'top_right',
                              apikey: 'XXXXXXXX', // private; don't share!
                              pws: 'XXXX', //XXXX
                              hourly: '1',
                              fctext: '1',
                              fcdaycount: "3",
                              fcdaystart: "0",
                              hourlyinterval: "4",
                              hourlycount: "4",
                              alerttime: 10000,
                              alerttruncatestring: "english:",
                          roundTmpDecs: 1,
                          UseCardinals: 0,
                          layout: "vertical",
                          sysstat: 0
                        @Camelblack that explains it you’re using vertical, last time i asked you said you want to use horizontal
                        • C Offline
                          @strawberry-3.141 lol… I changed it after posting and forgot about it. Sorry for that. It works perfectly now :)
