MMM-WunderGround - Display hourly only?
11 Posts 2 Posters 9.0k Views 2 Watching
    Camelblack
    Hi is it possible to only display hourly forecasts and hide daily?
    I saw there was a fade option, but I was unable to hide the daily forecast.
    S 1 Reply Last reply Feb 28, 2017, 10:11 PM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @Camelblack
      @Camelblack vertical or horizontal layout?
      C 1 Reply Last reply Feb 28, 2017, 10:19 PM Reply Quote 0
        Camelblack @strawberry 3.141
        @strawberry-3.141 preferably horizontal. Is there a way to fully hide days from vertical (not just fade them) ?
        I see the minimum value on days is 1.
        fcdaycount	How many days of forecast to return. Specified by config.js
        Possible values: 1 - 10
        Default value: 7 (7 days)
        This value is optional. By default the wunderground module will return 7 days.
        S 1 Reply Last reply Feb 28, 2017, 10:31 PM Reply Quote 0
          @Camelblack custom.css
          .MMM-WunderGround table.small:nth-of-type(3),
          .MMM-WunderGround hr.hrDivider:nth-of-type(3) {
              display:none;
          C 1 Reply Last reply Mar 7, 2017, 7:50 PM Reply Quote 1
            @strawberry-3.141 Thank you very much!
            Unfortunately it seems that I didn’t implement it correctly.
             * Magic Mirror                                      *
             * Custom CSS                                        *
             * By Michael Teeuw http://michaelteeuw.nl           *
             * MIT Licensed.                                     *
             * Add any custom CSS below.                         *
             * Changes to this files will be ignored by GIT. *
             body {
                display:none;
            Isn’t this how it supposed to look in custom.css?
            S 1 Reply Last reply Mar 7, 2017, 8:51 PM Reply Quote 0
              @Camelblack no remove body {
              C 1 Reply Last reply Mar 7, 2017, 9:23 PM Reply Quote 0
                @strawberry-3.141
                 * Magic Mirror                                      *
                 * Custom CSS                                        *
                 * MIT Licensed.                                     *
                    display:none;
                It looks like this now, but the mirror is still displaying 4 days, do I need to change any other files than custom.css?
                S 1 Reply Last reply Mar 7, 2017, 9:31 PM Reply Quote 0
                  @Camelblack can you share your config
                  C 1 Reply Last reply Mar 7, 2017, 10:08 PM Reply Quote 0
                    @strawberry-3.141 Sure:)
                        module: 'MMM-WunderGround',
                        position: 'top_right',
                            apikey: 'XXXXXXXX', // private; don't share!
                            pws: 'XXXX', //XXXX
                            hourly: '1',
                            fctext: '1',
                            fcdaycount: "3",
                            fcdaystart: "0",
                            hourlyinterval: "4",
                            hourlycount: "4",
                            alerttime: 10000,
                            alerttruncatestring: "english:",
                        roundTmpDecs: 1,
                        UseCardinals: 0,
                        layout: "vertical",
                        sysstat: 0
                    S 1 Reply Last reply Mar 8, 2017, 10:48 AM Reply Quote 0
                      @Camelblack that explains it you’re using vertical, last time i asked you said you want to use horizontal
                      C 1 Reply Last reply Mar 8, 2017, 9:06 PM Reply Quote 0
