    MMM-WunderGround - Display hourly only?
    11 Posts 2 Posters 9.3k Views 2 Watching
      Camelblack @strawberry 3.141
      @strawberry-3.141 preferably horizontal. Is there a way to fully hide days from vertical (not just fade them) ?
      I see the minimum value on days is 1.
      fcdaycount	How many days of forecast to return. Specified by config.js
      Possible values: 1 - 10
      Default value: 7 (7 days)
      This value is optional. By default the wunderground module will return 7 days.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Camelblack
        @Camelblack custom.css
        .MMM-WunderGround table.small:nth-of-type(3),
        .MMM-WunderGround hr.hrDivider:nth-of-type(3) {
            display:none;
          @strawberry-3.141 Thank you very much!
          Unfortunately it seems that I didn’t implement it correctly.
           * Magic Mirror                                      *
           * Custom CSS                                        *
           * By Michael Teeuw http://michaelteeuw.nl           *
           * MIT Licensed.                                     *
           * Add any custom CSS below.                         *
           * Changes to this files will be ignored by GIT. *
           body {
              display:none;
          Isn’t this how it supposed to look in custom.css?
            @Camelblack no remove body {
              @strawberry-3.141
               * Magic Mirror                                      *
               * Custom CSS                                        *
               * MIT Licensed.                                     *
                  display:none;
              It looks like this now, but the mirror is still displaying 4 days, do I need to change any other files than custom.css?
                @Camelblack can you share your config
                  @strawberry-3.141 Sure:)
                      module: 'MMM-WunderGround',
                      position: 'top_right',
                          apikey: 'XXXXXXXX', // private; don't share!
                          pws: 'XXXX', //XXXX
                          hourly: '1',
                          fctext: '1',
                          fcdaycount: "3",
                          fcdaystart: "0",
                          hourlyinterval: "4",
                          hourlycount: "4",
                          alerttime: 10000,
                          alerttruncatestring: "english:",
                      roundTmpDecs: 1,
                      UseCardinals: 0,
                      layout: "vertical",
                      sysstat: 0
                    @Camelblack that explains it you’re using vertical, last time i asked you said you want to use horizontal
                      @strawberry-3.141 lol… I changed it after posting and forgot about it. Sorry for that. It works perfectly now :)
