    Please commit your changes or stash them before you merge?
    17 Posts 3 Posters 10.1k Views 3 Watching
      sdetweil @jefftse
      @jefftse and further down
      "scripts": {
      		"config:check": "node js/check_config.js",
      		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
      		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
      		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
      		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
      doah… my mistake…
      npm run install-mm
      J 3 Replies Last reply Reply Quote 0
        jefftse @sdetweil
        That’s exactly what I have
          jefftse @sdetweil
          jeff@raspberrypi:~/MagicMirror $ git checkout package.json
          Updated 0 paths from the index
            jefftse @sdetweil
            jeff@raspberrypi:~/MagicMirror $ git pull && npm run install-mm
            Already up to date.
            magicmirror@2.30.0 install-mm
            npm ERR! code EBADENGINE
            npm ERR! engine Unsupported engine
            npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.30.0
            npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.30.0
            npm ERR! notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
            npm ERR! notsup Actual: {“npm”:“10.1.0”,“node”:“v20.9.0”}
            npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_52_04_066Z-debug-0.log
              sdetweil @jefftse
              @jefftse ok short path
              sudo npm install n -g
              sudo n 20.18.1
              cd ~/MagicMirror
              npm run install-mm
                jefftse @sdetweil
                I think that did the trick
                  sdetweil @jefftse
                  @jefftse ok!!!
