    Please commit your changes or stash them before you merge?
    17 Posts 3 Posters 11.4k Views 3 Watching
      sdetweil @jefftse
      @jefftse
      1.NEVER use sudo when doing anything w MagicMirror files
      what is changed in package.json!
      git diff package.json
      BKeyportB J 2 Replies Last reply
      • BKeyportB
        @sdetweil Don’t NPM install touch the package.json - or is it just package-lock?
        Either way, @jefftse can just delete package-lock.json for that error.
        S J 2 Replies Last reply
          sdetweil @BKeyport
          @BKeyport npm does not change package.json
            jefftse @sdetweil
            jeff@raspberrypi:~/MagicMirror $ git diff package.json
            diff --git a/package.json b/package.json
            index 7b80b4e…aa80952 100644
            — a/package.json
            +++ b/package.json
            @@ -58,6 +58,7 @@
            “ajv”: “^8.17.1”,
            “ansis”: “^3.3.2”,
            “console-stamp”: “^3.1.2”,
            •           "electron-version": "^2.0.1",
                        "envsub": "^4.1.0",
                        "eslint": "^9.11.1",
                        "express": "^4.21.0",
            @@ -66,13 +67,17 @@
            “helmet”: “^7.1.0”,
            “html-to-text”: “^9.0.5”,
            “iconv-lite”: “^0.6.3”,
            •           "luxon": "^3.5.0",
                        "module-alias": "^2.2.3",
                        "moment": "^2.30.1",
                        "node-ical": "0.18.0",
            •           "onoff": "^6.0.3",
                        "pm2": "^5.4.2",
            •           "rss-parser": "^3.13.0",
                        "socket.io": "^4.8.0",
                        "suncalc": "^1.9.0",
            •           "systeminformation": "^5.23.5"
            •           "systeminformation": "^5.23.5",
            •           "wiring-pi": "^2.2.1"
                "devDependencies": {
                        "@eslint/js": "^9.11.1",
              jefftse @BKeyport
              @BKeyport
              jeff@raspberrypi:~/MagicMirror $ rm package-lock.json
              jeff@raspberrypi:~/MagicMirror $ git pull && npm run install-mm
              Updating 94c3c69…c24de64
              error: Your local changes to the following files would be overwritten by merge:
              package.json
              Please commit your changes or stash them before you merge.
              Aborting
                sdetweil @jefftse
                @jefftse
                git checkout package.json
                git pull
                if that is successful
                npm run mm-install
                but watch out, then sudo may have messed things uo
                J 1 Reply Last reply
                  jefftse @sdetweil
                  jeff@raspberrypi:~/MagicMirror $ npm run mm-install
                  npm ERR! Missing script: “mm-install”
                  npm ERR!
                  npm ERR! Did you mean one of these?
                  npm ERR! npm install # Install a package
                  npm ERR! npm uninstall # Remove a package
                  npm ERR!
                  npm ERR! To see a list of scripts, run:
                  npm ERR! npm run
                  npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_14_57_938Z-debug-0.log
                    sdetweil @jefftse
                    @jefftse nano package.json
                    version should be 2.30.0
                    "name": "magicmirror",
                    	"version": "2.30.0"
                      jefftse @sdetweil
                      i’m confused. it is showing “2.30.0”
                        sdetweil @jefftse
                        @jefftse and further down
                        "scripts": {
                        		"config:check": "node js/check_config.js",
                        		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                        		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                        		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                        		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                        doah… my mistake…
                        npm run install-mm
                        J 3 Replies Last reply
                          jefftse @sdetweil
                          That’s exactly what I have
                            jefftse @sdetweil
                            jeff@raspberrypi:~/MagicMirror $ git checkout package.json
                            Updated 0 paths from the index
                              jefftse @sdetweil
                              Already up to date.
                              magicmirror@2.30.0 install-mm
                              npm ERR! code EBADENGINE
                              npm ERR! engine Unsupported engine
                              npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.30.0
                              npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.30.0
                              npm ERR! notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
                              npm ERR! notsup Actual: {“npm”:“10.1.0”,“node”:“v20.9.0”}
                              npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_52_04_066Z-debug-0.log
                                sdetweil @jefftse
                                @jefftse ok short path
                                sudo npm install n -g
                                sudo n 20.18.1
                                npm run install-mm
                                  jefftse @sdetweil
                                  I think that did the trick
                                    sdetweil @jefftse
                                    @jefftse ok!!!
