Please commit your changes or stash them before you merge?
17 Posts 3 Posters 8.2k Views 3 Watching
    jefftse
    I tried to update my mirror tonight but i’m getting this.
    jeff@raspberrypi:~/MagicMirror $ sudo git pull && npm run install-mm
    Updating 94c3c69…c24de64
    error: Your local changes to the following files would be overwritten by merge:
    package-lock.json
    package.json
    Please commit your changes or stash them before you merge.
    Aborting
    please advise
    S 1 Reply Last reply Jan 3, 2025, 3:41 AM Reply Quote 0
    • S Away
      sdetweil @jefftse
      @jefftse ok short path
      sudo npm install n -g
      sudo n 20.18.1
      npm run install-mm
      J 1 Reply Last reply Jan 3, 2025, 9:14 PM Reply Quote 0
      • S Away
        sdetweil @jefftse
        @jefftse
        1.NEVER use sudo when doing anything w MagicMirror files
        what is changed in package.json!
        git diff package.json
        B J 2 Replies Last reply Jan 3, 2025, 3:43 AM Reply Quote 0
          @sdetweil Don’t NPM install touch the package.json - or is it just package-lock?
          Either way, @jefftse can just delete package-lock.json for that error.
          S J 2 Replies Last reply Jan 3, 2025, 3:45 AM Reply Quote 0
          • S Away
            sdetweil @BKeyport
            @BKeyport npm does not change package.json
              jefftse @sdetweil
              jeff@raspberrypi:~/MagicMirror $ git diff package.json
              diff --git a/package.json b/package.json
              index 7b80b4e…aa80952 100644
              — a/package.json
              +++ b/package.json
              @@ -58,6 +58,7 @@
              “ajv”: “^8.17.1”,
              “ansis”: “^3.3.2”,
              “console-stamp”: “^3.1.2”,
              •           "electron-version": "^2.0.1",
                          "envsub": "^4.1.0",
                          "eslint": "^9.11.1",
                          "express": "^4.21.0",
              @@ -66,13 +67,17 @@
              “helmet”: “^7.1.0”,
              “html-to-text”: “^9.0.5”,
              “iconv-lite”: “^0.6.3”,
              •           "luxon": "^3.5.0",
                          "module-alias": "^2.2.3",
                          "moment": "^2.30.1",
                          "node-ical": "0.18.0",
              •           "onoff": "^6.0.3",
                          "pm2": "^5.4.2",
              •           "rss-parser": "^3.13.0",
                          "socket.io": "^4.8.0",
                          "suncalc": "^1.9.0",
              •           "systeminformation": "^5.23.5"
              •           "systeminformation": "^5.23.5",
              •           "wiring-pi": "^2.2.1"
                  "devDependencies": {
                          "@eslint/js": "^9.11.1",
                jefftse @BKeyport
                @BKeyport
                jeff@raspberrypi:~/MagicMirror $ rm package-lock.json
                jeff@raspberrypi:~/MagicMirror $ git pull && npm run install-mm
                package.json
                Aborting
                S 1 Reply Last reply Jan 3, 2025, 12:37 PM Reply Quote 0
                • S Away
                  sdetweil @jefftse
                  @jefftse
                  git checkout package.json
                  git pull
                  if that is successful
                  npm run mm-install
                  but watch out, then sudo may have messed things uo
                  J 1 Reply Last reply Jan 3, 2025, 4:15 PM Reply Quote 0
                    jefftse @sdetweil
                    jeff@raspberrypi:~/MagicMirror $ npm run mm-install
                    npm ERR! Missing script: “mm-install”
                    npm ERR!
                    npm ERR! Did you mean one of these?
                    npm ERR! npm install # Install a package
                    npm ERR! npm uninstall # Remove a package
                    npm ERR!
                    npm ERR! To see a list of scripts, run:
                    npm ERR! npm run
                    npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_14_57_938Z-debug-0.log
                    S 1 Reply Last reply Jan 3, 2025, 4:22 PM Reply Quote 0
                    • S Away
                      sdetweil @jefftse
                      @jefftse nano package.json
                      version should be 2.30.0
                      "name": "magicmirror",
                      	"version": "2.30.0"
                      J 1 Reply Last reply Jan 3, 2025, 4:38 PM Reply Quote 0
                        jefftse @sdetweil
                        i’m confused. it is showing “2.30.0”
                        S 1 Reply Last reply Jan 3, 2025, 4:39 PM Reply Quote 0
