    Please commit your changes or stash them before you merge?
    17 Posts 3 Posters 9.9k Views 3 Watching
      jefftse
      I tried to update my mirror tonight but i’m getting this.
      jeff@raspberrypi:~/MagicMirror $ sudo git pull && npm run install-mm
      Updating 94c3c69…c24de64
      error: Your local changes to the following files would be overwritten by merge:
      package-lock.json
      package.json
      Please commit your changes or stash them before you merge.
      Aborting
      please advise
        sdetweil @jefftse
        @jefftse ok short path
        sudo npm install n -g
        sudo n 20.18.1
        npm run install-mm
          sdetweil @jefftse
          @jefftse
          1.NEVER use sudo when doing anything w MagicMirror files
          what is changed in package.json!
          git diff package.json
          BKeyportB J 2 Replies Last reply Reply Quote 0
          • BKeyportB Offline
            @sdetweil Don’t NPM install touch the package.json - or is it just package-lock?
            Either way, @jefftse can just delete package-lock.json for that error.
            S J 2 Replies Last reply Reply Quote 0
              sdetweil @BKeyport
              @BKeyport npm does not change package.json
                jefftse @sdetweil
                jeff@raspberrypi:~/MagicMirror $ git diff package.json
                diff --git a/package.json b/package.json
                index 7b80b4e…aa80952 100644
                — a/package.json
                +++ b/package.json
                @@ -58,6 +58,7 @@
                “ajv”: “^8.17.1”,
                “ansis”: “^3.3.2”,
                “console-stamp”: “^3.1.2”,
                •           "electron-version": "^2.0.1",
                            "envsub": "^4.1.0",
                            "eslint": "^9.11.1",
                            "express": "^4.21.0",
                @@ -66,13 +67,17 @@
                “helmet”: “^7.1.0”,
                “html-to-text”: “^9.0.5”,
                “iconv-lite”: “^0.6.3”,
                •           "luxon": "^3.5.0",
                            "module-alias": "^2.2.3",
                            "moment": "^2.30.1",
                            "node-ical": "0.18.0",
                •           "onoff": "^6.0.3",
                            "pm2": "^5.4.2",
                •           "rss-parser": "^3.13.0",
                            "socket.io": "^4.8.0",
                            "suncalc": "^1.9.0",
                •           "systeminformation": "^5.23.5"
                •           "systeminformation": "^5.23.5",
                •           "wiring-pi": "^2.2.1"
                    "devDependencies": {
                            "@eslint/js": "^9.11.1",
                  jefftse @BKeyport
                  @BKeyport
                  jeff@raspberrypi:~/MagicMirror $ rm package-lock.json
                  jeff@raspberrypi:~/MagicMirror $ git pull && npm run install-mm
                  package.json
                  Aborting
                    sdetweil @jefftse
                    @jefftse
                    git checkout package.json
                    git pull
                    if that is successful
                    npm run mm-install
                    but watch out, then sudo may have messed things uo
                      jefftse @sdetweil
                      jeff@raspberrypi:~/MagicMirror $ npm run mm-install
                      npm ERR! Missing script: “mm-install”
                      npm ERR!
                      npm ERR! Did you mean one of these?
                      npm ERR! npm install # Install a package
                      npm ERR! npm uninstall # Remove a package
                      npm ERR!
                      npm ERR! To see a list of scripts, run:
                      npm ERR! npm run
                      npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_14_57_938Z-debug-0.log
                        sdetweil @jefftse
                        @jefftse nano package.json
                        version should be 2.30.0
                        "name": "magicmirror",
                        	"version": "2.30.0"
                          jefftse @sdetweil
                          i’m confused. it is showing “2.30.0”
