    Please commit your changes or stash them before you merge?
    17 Posts 3 Posters 10.2k Views 3 Watching
    • BKeyportB Offline
      @sdetweil Don’t NPM install touch the package.json - or is it just package-lock?
      Either way, @jefftse can just delete package-lock.json for that error.
      S J 2 Replies Last reply Reply Quote 0
        sdetweil @BKeyport
        @BKeyport npm does not change package.json
          jefftse @sdetweil
          jeff@raspberrypi:~/MagicMirror $ git diff package.json
          diff --git a/package.json b/package.json
          index 7b80b4e…aa80952 100644
          — a/package.json
          +++ b/package.json
          @@ -58,6 +58,7 @@
          “ajv”: “^8.17.1”,
          “ansis”: “^3.3.2”,
          “console-stamp”: “^3.1.2”,
          •           "electron-version": "^2.0.1",
                      "envsub": "^4.1.0",
                      "eslint": "^9.11.1",
                      "express": "^4.21.0",
          @@ -66,13 +67,17 @@
          “helmet”: “^7.1.0”,
          “html-to-text”: “^9.0.5”,
          “iconv-lite”: “^0.6.3”,
          •           "luxon": "^3.5.0",
                      "module-alias": "^2.2.3",
                      "moment": "^2.30.1",
                      "node-ical": "0.18.0",
          •           "onoff": "^6.0.3",
                      "pm2": "^5.4.2",
          •           "rss-parser": "^3.13.0",
                      "socket.io": "^4.8.0",
                      "suncalc": "^1.9.0",
          •           "systeminformation": "^5.23.5"
          •           "systeminformation": "^5.23.5",
          •           "wiring-pi": "^2.2.1"
              "devDependencies": {
                      "@eslint/js": "^9.11.1",
            jefftse @BKeyport
            @BKeyport
            jeff@raspberrypi:~/MagicMirror $ rm package-lock.json
            jeff@raspberrypi:~/MagicMirror $ git pull && npm run install-mm
            Updating 94c3c69…c24de64
            error: Your local changes to the following files would be overwritten by merge:
            package.json
            Please commit your changes or stash them before you merge.
            Aborting
              sdetweil @jefftse
              @jefftse
              git checkout package.json
              git pull
              if that is successful
              npm run mm-install
              but watch out, then sudo may have messed things uo
                jefftse @sdetweil
                jeff@raspberrypi:~/MagicMirror $ npm run mm-install
                npm ERR! Missing script: “mm-install”
                npm ERR!
                npm ERR! Did you mean one of these?
                npm ERR! npm install # Install a package
                npm ERR! npm uninstall # Remove a package
                npm ERR!
                npm ERR! To see a list of scripts, run:
                npm ERR! npm run
                npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_14_57_938Z-debug-0.log
                  sdetweil @jefftse
                  @jefftse nano package.json
                  version should be 2.30.0
                  "name": "magicmirror",
                  	"version": "2.30.0"
                    jefftse @sdetweil
                    i’m confused. it is showing “2.30.0”
                      sdetweil @jefftse
                      @jefftse and further down
                      "scripts": {
                      		"config:check": "node js/check_config.js",
                      		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                      		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                      		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                      		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                      doah… my mistake…
                      npm run install-mm
                      J 3 Replies Last reply Reply Quote 0
                        jefftse @sdetweil
                        That’s exactly what I have
