    Please commit your changes or stash them before you merge?
    17 Posts 3 Posters 11.4k Views 3 Watching
      jefftse @sdetweil
      jeff@raspberrypi:~/MagicMirror $ git diff package.json
      diff --git a/package.json b/package.json
      index 7b80b4e…aa80952 100644
      — a/package.json
      +++ b/package.json
      @@ -58,6 +58,7 @@
      “ajv”: “^8.17.1”,
      “ansis”: “^3.3.2”,
      “console-stamp”: “^3.1.2”,
      •           "electron-version": "^2.0.1",
                  "envsub": "^4.1.0",
                  "eslint": "^9.11.1",
                  "express": "^4.21.0",
      @@ -66,13 +67,17 @@
      “helmet”: “^7.1.0”,
      “html-to-text”: “^9.0.5”,
      “iconv-lite”: “^0.6.3”,
      •           "luxon": "^3.5.0",
                  "module-alias": "^2.2.3",
                  "moment": "^2.30.1",
                  "node-ical": "0.18.0",
      •           "onoff": "^6.0.3",
                  "pm2": "^5.4.2",
      •           "rss-parser": "^3.13.0",
                  "socket.io": "^4.8.0",
                  "suncalc": "^1.9.0",
      •           "systeminformation": "^5.23.5"
      •           "systeminformation": "^5.23.5",
      •           "wiring-pi": "^2.2.1"
          "devDependencies": {
                  "@eslint/js": "^9.11.1",
        jefftse @BKeyport
        @BKeyport
        jeff@raspberrypi:~/MagicMirror $ rm package-lock.json
        jeff@raspberrypi:~/MagicMirror $ git pull && npm run install-mm
        Updating 94c3c69…c24de64
        error: Your local changes to the following files would be overwritten by merge:
        package.json
        Please commit your changes or stash them before you merge.
        Aborting
          sdetweil @jefftse
          @jefftse
          git checkout package.json
          git pull
          if that is successful
          npm run mm-install
          but watch out, then sudo may have messed things uo
          J 1 Reply Last reply
            jefftse @sdetweil
            jeff@raspberrypi:~/MagicMirror $ npm run mm-install
            npm ERR! Missing script: “mm-install”
            npm ERR!
            npm ERR! Did you mean one of these?
            npm ERR! npm install # Install a package
            npm ERR! npm uninstall # Remove a package
            npm ERR!
            npm ERR! To see a list of scripts, run:
            npm ERR! npm run
            npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_14_57_938Z-debug-0.log
              sdetweil @jefftse
              @jefftse nano package.json
              version should be 2.30.0
              "name": "magicmirror",
              	"version": "2.30.0"
                jefftse @sdetweil
                i’m confused. it is showing “2.30.0”
                  sdetweil @jefftse
                  @jefftse and further down
                  "scripts": {
                  		"config:check": "node js/check_config.js",
                  		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                  		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                  		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                  		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                  doah… my mistake…
                  npm run install-mm
                  J 3 Replies Last reply
                    jefftse @sdetweil
                    That’s exactly what I have
                      jefftse @sdetweil
                      jeff@raspberrypi:~/MagicMirror $ git checkout package.json
                      Updated 0 paths from the index
                        jefftse @sdetweil
                        Already up to date.
                        magicmirror@2.30.0 install-mm
                        npm ERR! code EBADENGINE
                        npm ERR! engine Unsupported engine
                        npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.30.0
                        npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.30.0
                        npm ERR! notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
                        npm ERR! notsup Actual: {“npm”:“10.1.0”,“node”:“v20.9.0”}
                        npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_52_04_066Z-debug-0.log
                          sdetweil @jefftse
                          @jefftse ok short path
                          sudo npm install n -g
                          sudo n 20.18.1
                          npm run install-mm
                            jefftse @sdetweil
                            I think that did the trick
                              sdetweil @jefftse
                              @jefftse ok!!!
