    Please commit your changes or stash them before you merge?
    17 Posts 3 Posters 11.2k Views 3 Watching
      sdetweil @jefftse
      @jefftse
      git checkout package.json
      git pull
      if that is successful
      npm run mm-install
      but watch out, then sudo may have messed things uo
        jefftse @sdetweil
        jeff@raspberrypi:~/MagicMirror $ npm run mm-install
        npm ERR! Missing script: “mm-install”
        npm ERR!
        npm ERR! Did you mean one of these?
        npm ERR! npm install # Install a package
        npm ERR! npm uninstall # Remove a package
        npm ERR!
        npm ERR! To see a list of scripts, run:
        npm ERR! npm run
        npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_14_57_938Z-debug-0.log
          sdetweil @jefftse
          @jefftse nano package.json
          version should be 2.30.0
          "name": "magicmirror",
          	"version": "2.30.0"
            jefftse @sdetweil
            i’m confused. it is showing “2.30.0”
              sdetweil @jefftse
              @jefftse and further down
              "scripts": {
              		"config:check": "node js/check_config.js",
              		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
              		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
              		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
              		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
              doah… my mistake…
              npm run install-mm
              J 3 Replies Last reply Reply Quote 0
                jefftse @sdetweil
                That’s exactly what I have
                  jefftse @sdetweil
                  jeff@raspberrypi:~/MagicMirror $ git checkout package.json
                  Updated 0 paths from the index
                    jefftse @sdetweil
                    jeff@raspberrypi:~/MagicMirror $ git pull && npm run install-mm
                    Already up to date.
                    magicmirror@2.30.0 install-mm
                    npm ERR! code EBADENGINE
                    npm ERR! engine Unsupported engine
                    npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.30.0
                    npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.30.0
                    npm ERR! notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
                    npm ERR! notsup Actual: {“npm”:“10.1.0”,“node”:“v20.9.0”}
                    npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_52_04_066Z-debug-0.log
                      sdetweil @jefftse
                      @jefftse ok short path
                      sudo npm install n -g
                      sudo n 20.18.1
                      npm run install-mm
                        jefftse @sdetweil
                        I think that did the trick
                          sdetweil @jefftse
                          @jefftse ok!!!
