    Version 2.30.0 Calendar fix for clipping broadcast events
    67 Posts 10 Posters 47.0k Views 10 Watching
      sdetweil @angeliKITTYx
      @angeliKITTYx you missed a step
      cd ~/MagicMirror
      npm run install-mm
        sdetweil @MDWEBB
        @MDWEBB ok, you didn’t switch to the new branch
        git switch _fix_clipping
          angeliKITTYx @sdetweil
          @sdetweil Okay, I got MM to launch, but now other modules are broken and the calendar is still a mess. 3 of 7 are showing, and “all day” events are starting at 5AM and go into the next day. The command window says it’s populating x number of events from all 7 calendars, but they’re not showing up.
          screenshot every event here is an “all day” event, and 4 of the calendars aren’t showing.
          @raspberrypi:~/MagicMirror $ npm run start
          > magicmirror@2.31.0-develop start
          > npm run start:x11
          > magicmirror@2.31.0-develop start:x11
          [2025-01-11 13:22:17.187] [LOG]   Starting MagicMirror: v2.31.0-develop
          [2025-01-11 13:22:17.225] [LOG]   Loading config ...
          [2025-01-11 13:22:17.228] [LOG]   config template file not exists, no envsubst
          [2025-01-11 13:22:17.817] [INFO]  Checking config file /home/burgess/MagicMirror/config/config.js ...
          [2025-01-11 13:22:17.921] [INFO]  Your configuration file doesn't contain syntax errors :)
          [2025-01-11 13:22:17.923] [INFO]  Checking modules structure configuration ...
          [2025-01-11 13:22:18.059] [INFO]  Your modules structure configuration doesn't contain errors :)
          [2025-01-11 13:22:18.063] [LOG]   Loading module helpers ...
          [2025-01-11 13:22:18.064] [LOG]   No helper found for module: alert.
          [2025-01-11 13:22:18.076] [LOG]   Initializing new module helper ...
          [2025-01-11 13:22:18.077] [LOG]   Module helper loaded: updatenotification
          [2025-01-11 13:22:18.079] [LOG]   No helper found for module: clock.
          [2025-01-11 13:22:18.080] [LOG]   No helper found for module: weather.
          [2025-01-11 13:22:18.090] [LOG]   Initializing new module helper ...
          [2025-01-11 13:22:18.091] [LOG]   Module helper loaded: MMM-OnThisDayWikiApi
          [2025-01-11 13:22:18.255] [LOG]   Initializing new module helper ...
          [2025-01-11 13:22:18.256] [LOG]   Module helper loaded: calendar
          [2025-01-11 13:22:18.257] [LOG]   No helper found for module: MMM-CalendarExt3.
          [2025-01-11 13:22:18.628] [LOG]   Initializing new module helper ...
          [2025-01-11 13:22:18.628] [LOG]   Module helper loaded: MMM-GooglePhotos
          [2025-01-11 13:22:18.631] [ERROR] Error when loading MMM-GoogleTasks: Cannot find module 'googleapis'
          Require stack:
          - /home/burgess/MagicMirror/modules/MMM-GoogleTasks/node_helper.js
          - /home/burgess/MagicMirror/js/app.js
          - /home/burgess/MagicMirror/js/electron.js
          [2025-01-11 13:22:18.632] [LOG]   All module helpers loaded.
          [2025-01-11 13:22:18.641] [LOG]   Starting server on port 8080 ...
          [2025-01-11 13:22:19.595] [LOG]   Server started ...
          [2025-01-11 13:22:19.597] [LOG]   Connecting socket for: updatenotification
          [2025-01-11 13:22:19.598] [LOG]   Starting module helper: updatenotification
          [2025-01-11 13:22:19.599] [LOG]   Connecting socket for: MMM-OnThisDayWikiApi
          [2025-01-11 13:22:19.600] [LOG]   Started node_helper.js for MMM-OnThisDayWikiApi.
          [2025-01-11 13:22:19.601] [LOG]   Connecting socket for: calendar
          [2025-01-11 13:22:19.603] [LOG]   Starting node helper for: calendar
          [2025-01-11 13:22:19.604] [LOG]   Connecting socket for: MMM-GooglePhotos
          [2025-01-11 13:22:19.607] [LOG]   Sockets connected & modules started ...
          [2025-01-11 13:22:19.983] [LOG]   Launching application.
          [93585:0111/132221.707589:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.707977:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.708192:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.708280:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.708416:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.708498:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.708623:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.708695:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.708813:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.708894:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.709014:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.709087:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.709205:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.709278:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.710430:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.710527:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.710657:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.710755:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.710925:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.711002:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.711120:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.711194:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.711311:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.711381:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.711495:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.711566:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93585:0111/132221.711682:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93585:0111/132221.711753:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2025-01-11 13:22:22.891] [INFO]  System information:
          ### SYSTEM:   manufacturer: ; model: ; virtual: false
          ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.31+rpt-rpi-v8
          ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2:
          ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
          [2025-01-11 13:22:24.539] [LOG]   MMM-OnThisDayWikiApi node helper received a socket notification: ONTHISDAY_FETCH - Payload: [object Object]
          [2025-01-11 13:22:24.541] [LOG]   https://api.wikimedia.org/feed/v1/wikipedia/en/onthisday/selected/01/11
          [2025-01-11 13:22:24.645] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics - Interval: 100000
          [2025-01-11 13:22:24.651] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics - Interval: 100000
          [2025-01-11 13:22:24.654] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics - Interval: 100000
          [2025-01-11 13:22:24.657] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics - Interval: 100000
          [2025-01-11 13:22:24.660] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics - Interval: 100000
          [2025-01-11 13:22:24.663] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics - Interval: 100000
          [2025-01-11 13:22:24.670] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics - Interval: 100000
          [2025-01-11 13:22:25.240] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
          [2025-01-11 13:22:25.359] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
          [2025-01-11 13:22:25.482] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
          [2025-01-11 13:22:26.506] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
          [2025-01-11 13:22:26.716] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
          [2025-01-11 13:22:26.881] [LOG]   OnThisDay-Fetcher: Broadcasting 17 items.
          [2025-01-11 13:22:27.087] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
          [2025-01-11 13:22:30.191] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
          [2025-01-11 13:24:05.593] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
          [2025-01-11 13:24:05.647] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
          [2025-01-11 13:24:05.878] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
          [2025-01-11 13:24:07.544] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
          [2025-01-11 13:24:07.870] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
          [2025-01-11 13:24:07.981] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
          [2025-01-11 13:24:14.258] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
          [2025-01-11 13:25:46.035] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
          [2025-01-11 13:25:46.181] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
          [2025-01-11 13:25:46.337] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
          [2025-01-11 13:25:48.631] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
          [2025-01-11 13:25:48.952] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
          [2025-01-11 13:25:49.061] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
          [2025-01-11 13:25:58.216] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
          [2025-01-11 13:27:26.321] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
          [2025-01-11 13:27:26.473] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
          [2025-01-11 13:27:26.572] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
          [2025-01-11 13:27:29.648] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
          [2025-01-11 13:27:29.976] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
          [2025-01-11 13:27:30.093] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
          [2025-01-11 13:27:42.234] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
          [2025-01-11 13:28:49.689] [LOG]   Shutting down server...
          [2025-01-11 13:28:49.690] [LOG]   Stopping module helper: updatenotification
          [2025-01-11 13:28:49.690] [LOG]   Stopping module helper: MMM-OnThisDayWikiApi
          [2025-01-11 13:28:49.691] [LOG]   Stopping module helper: calendar
          [2025-01-11 13:28:49.691] [LOG]   Node_helpers stopped ...
          burgess@raspberrypi:~/MagicMirror $ npm run start
          > npm run start:x11
          [2025-01-11 13:33:21.858] [LOG]   Starting MagicMirror: v2.31.0-develop
          [2025-01-11 13:33:21.895] [LOG]   Loading config ...
          [2025-01-11 13:33:21.898] [LOG]   config template file not exists, no envsubst
          [2025-01-11 13:33:22.431] [INFO]  Checking config file /home/burgess/MagicMirror/config/config.js ...
          [2025-01-11 13:33:22.540] [INFO]  Your configuration file doesn't contain syntax errors :)
          [2025-01-11 13:33:22.541] [INFO]  Checking modules structure configuration ...
          [2025-01-11 13:33:22.671] [INFO]  Your modules structure configuration doesn't contain errors :)
          [2025-01-11 13:33:22.674] [LOG]   Loading module helpers ...
          [2025-01-11 13:33:22.675] [LOG]   No helper found for module: alert.
          [2025-01-11 13:33:22.683] [LOG]   Initializing new module helper ...
          [2025-01-11 13:33:22.684] [LOG]   Module helper loaded: updatenotification
          [2025-01-11 13:33:22.685] [LOG]   No helper found for module: clock.
          [2025-01-11 13:33:22.686] [LOG]   No helper found for module: weather.
          [2025-01-11 13:33:22.691] [LOG]   Initializing new module helper ...
          [2025-01-11 13:33:22.692] [LOG]   Module helper loaded: MMM-OnThisDayWikiApi
          [2025-01-11 13:33:22.837] [LOG]   Initializing new module helper ...
          [2025-01-11 13:33:22.837] [LOG]   Module helper loaded: calendar
          [2025-01-11 13:33:22.839] [LOG]   No helper found for module: MMM-CalendarExt3.
          [2025-01-11 13:33:23.047] [LOG]   Initializing new module helper ...
          [2025-01-11 13:33:23.047] [LOG]   Module helper loaded: MMM-GooglePhotos
          [2025-01-11 13:33:23.049] [ERROR] Error when loading MMM-GoogleTasks: Cannot find module 'googleapis'
          Require stack:
          [2025-01-11 13:33:23.050] [LOG]   All module helpers loaded.
          [2025-01-11 13:33:23.060] [LOG]   Starting server on port 8080 ...
          [2025-01-11 13:33:24.093] [LOG]   Server started ...
          [2025-01-11 13:33:24.095] [LOG]   Connecting socket for: updatenotification
          [2025-01-11 13:33:24.097] [LOG]   Starting module helper: updatenotification
          [2025-01-11 13:33:24.098] [LOG]   Connecting socket for: MMM-OnThisDayWikiApi
          [2025-01-11 13:33:24.099] [LOG]   Started node_helper.js for MMM-OnThisDayWikiApi.
          [2025-01-11 13:33:24.100] [LOG]   Connecting socket for: calendar
          [2025-01-11 13:33:24.102] [LOG]   Starting node helper for: calendar
          [2025-01-11 13:33:24.103] [LOG]   Connecting socket for: MMM-GooglePhotos
          [2025-01-11 13:33:24.105] [LOG]   Sockets connected & modules started ...
          [2025-01-11 13:33:24.460] [LOG]   Launching application.
          [2025-01-11 13:33:25.918] [INFO]  System information:
          ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
          [93838:0111/133325.993897:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.994339:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.994652:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.994820:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.995048:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.995175:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.995380:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.995501:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.995702:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.995827:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.996014:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.996128:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.996323:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.996435:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.997768:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.997947:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.998173:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.998331:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.998552:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.998671:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.998903:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.999041:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.999233:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.999339:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.999524:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.999633:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [93838:0111/133325.999822:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [93838:0111/133325.999936:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2025-01-11 13:33:27.852] [LOG]   MMM-OnThisDayWikiApi node helper received a socket notification: ONTHISDAY_FETCH - Payload: [object Object]
          [2025-01-11 13:33:27.853] [LOG]   https://api.wikimedia.org/feed/v1/wikipedia/en/onthisday/selected/01/11
          [2025-01-11 13:33:27.930] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics - Interval: 100000
          [2025-01-11 13:33:27.939] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics - Interval: 100000
          [2025-01-11 13:33:27.946] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics - Interval: 100000
          [2025-01-11 13:33:27.951] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics - Interval: 100000
          [2025-01-11 13:33:27.954] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics - Interval: 100000
          [2025-01-11 13:33:27.956] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics - Interval: 100000
          [2025-01-11 13:33:27.959] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics - Interval: 100000
          [2025-01-11 13:33:28.317] [LOG]   OnThisDay-Fetcher: Broadcasting 17 items.
          [2025-01-11 13:33:28.772] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
          [2025-01-11 13:33:28.996] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
          [2025-01-11 13:33:30.577] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
          [2025-01-11 13:33:30.690] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
          [2025-01-11 13:33:30.814] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
          [2025-01-11 13:33:30.938] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
          [2025-01-11 13:33:33.617] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
          [2025-01-11 13:35:09.183] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
          [2025-01-11 13:35:09.444] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
          [2025-01-11 13:35:11.698] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
          [2025-01-11 13:35:11.765] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
          [2025-01-11 13:35:11.973] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
          [2025-01-11 13:35:12.072] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
          [2025-01-11 13:35:17.541] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
          [2025-01-11 13:35:56.202] [LOG]   Shutting down server...
          [2025-01-11 13:35:56.204] [LOG]   Stopping module helper: updatenotification
          [2025-01-11 13:35:56.204] [LOG]   Stopping module helper: MMM-OnThisDayWikiApi
          [2025-01-11 13:35:56.204] [LOG]   Stopping module helper: calendar
          [2025-01-11 13:35:56.205] [LOG]   Node_helpers stopped ...
            @angeliKITTYx said in Version 2.30.0 Calendar fix for clipping broadcast events:
            MMM-GoogleTasks: Cannot find module ‘googleapis’
            this sounds like a module install problem
            go to the MMM-GoogleTasks module folder and do npm install
              @sdetweil the install command went through properly, but I’m still getting the same results when I launch MM.
                @angeliKITTYx there are events broadcast over almost 2 minutes. I think Ext3 tries to hold off updating exactly when events arrive
                there is a properties on Ext3
                waitFetch 5000 (ms) waiting the fetching of last calendar to prevent flickering view by too frequent fetching.
                refreshInterval 1800000 (ms) refresh view by force if you need it.
                  @angeliKITTYx can you go to the MMM-GoogleTasks module folder and do
                  ls node_modules/googleapis
                  it should display something
                  then
                  rm-rf node_modules
                  npm install
                    @angeliKITTYx ok, the module has a problem
                    it didn’t document NEEDING that library (it has no package.json file)
                    so do the general fix for missing dependencies
                    see here for the steps
                    https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later?page=1
                      @sdetweil that link fixed the module, thank you! Now just the issue of the calendar. Here’s my config file - did I add those parameters correctly? My Ext3 refreshinterval used to be 105000. Once I changed that and added the fetch, the “all day” events are still showing wrong and I’m down to 2 of 7 calendars showing.
                      			header: "Family Calendar",
                      			hiddenOnStartup: "true",
                      				broadcastPastEvents: true,
                      				displaySymbol: false,
                      				showEnd: false,
                      				fetchInterval: 100000,
                      						url: "https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics",
                      						color: "mediumpurple"
                      						url: "https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics",
                      						color: "darkgrey"
                      						url: "https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics",
                      						color: "cyan"
                      						url: "https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics",
                      						color: "black"
                      						url: "https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics",
                      						color: "palevioletred"
                      						url: "https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics",
                      						color: "blue"
                      						url: "https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics",
                      						color: "green"
                      			module: "MMM-CalendarExt3",
                      			position: "bottom_bar",
                      					mode: "week",
                      					useSymbol: false,
                      					showMore: true,
                      					refreshInterval: "1800000",
                      					waitFetch: "5000",
                      					weekIndex: "0",
                      					instanceId: "basicCalendar",
                      					fontSize: "22px",
                      					maxEventLines: 5,
                      					firstDayOfWeek: 7,
                      					calendarSet: ['family_cal', 'alecwork_cal', 'alec_cal', 'days_off', 'birthdays', 'Recycling', 'Trash'],
                        @angeliKITTYx i think the refreshInterval you set is 30 minutes
                        just for grins , try
                         3*60*1000
                        as your initial load is under that
                          @sdetweil I changed the Ext3 parameter to refreshInterval: “3601000”, and it still looks the same. Do I need to let it sit for an hour to refresh?
                            @angeliKITTYx I don’t know… I suggested trying shorter (quick) to prove the cals arrived…
                              @sdetweil I’m confused then…i was just using the values you provided. Do I need to go back to my refresh of 1.75min? Do I keep the fetch value at 5000?
                              S A 2 Replies Last reply Reply Quote 0
                                @angeliKITTYx dang forum… they removed the * I fixed the post
                                3*60*100
                                3 minutes, * 60 seconds * 1000 ms
                                  angeliKITTYx @angeliKITTYx
                                  @sdetweil I put the refresh interval back down to 100500, and the calendar refreshed. The 3rd calendar showed back up, but they’re all displaying at 5AM and going into the following day even though everything is an “all day” event in my Google calendar. It looks the same as the screenshot I shared earlier.
                                    @angeliKITTYx sounds like your system timezone is incorrect
                                    everything is based off the timezone
                                      @sdetweil how do I change the timezone in MM? This issue only came up once I did the fix clipping commands on this thread. And what about all the calendars that aren’t showing?
                                      I also just noticed my weather module stopped working too.
                                        @angeliKITTYx timezone, from desktop, click the calendar top right
                                        change timezone under calendar
                                        i don’t know in ext3 cals, not my module… but I use multi cals with it every day and don’t see this
                                        ext3 is done all in browser
                                        so maybe open the developer window (ctrl-shift-i) and select the console tab
                                        and out a unique part of the module name in the filter field, ext3 for this
                                          @sdetweil my raspberry pi desktop has the correct timezone, my Google calendars are all set right, and the clock module is showing the right time. Would ext3 have a different time zone set?
                                            @angeliKITTYx
                                            i do not know
                                            for debug purposes
                                            edit config.js and add
                                            ,"DEBUG"
                                            to the logLevel parms at the top
                                            stop (if using pm2, pm2 stop all)
                                            and MANUALLY start MM like this
                                            cd ~/MagicMirror
                                            npm start >somefile.txt 2>&1
                                            wait til some time, and then ctrl-c on the command prompt where u did the manual start
                                            edit the config.js back to remove the debug parm
                                            the file will be large with all the calendars being processed
                                            you can’t upload that here, and I would normally ask to email it to me.
                                            I don’t know if email will take that large a file… you can try… my same userid as here at gmail
                                            because the FULL urls of the calendars are shown in the log, I don’t want that posted in clear text anywhere…
                                            I suggest uploading somewhere and emailing or direct message me the url
                                            I did extensive work on the calendar to fix these problems on this release.
                                            so I am very interested in the problem
                                            you can look thru the file, its just text and you will see the timezone reported as it processes calendar events.
                                            • 2 / 4
