    Version 2.30.0 Calendar fix for clipping broadcast events
    67 Posts 10 Posters 46.8k Views 10 Watching
      sdetweil @MDWEBB
      @MDWEBB said in Version 2.30.0 Calendar fix for clipping broadcast events:
      _fix_clipping
      you need to be on _fix_clipping
      do
      git switch _fix_clipping
      if you get package-lock.json would be overwritten
      do
      rm package-lock.json
      the do the switch again
      and then
      npm run install-mm
      B M 2 Replies Last reply Reply Quote 1
        bruces2 @sdetweil
        update worked for me…
          MDWEBB @sdetweil
          @sdetweil Hi Sam,
          Performed checks and changes as requested ensured i was on _fix_clipping then ran the install and still am not getting the events data. See log of each step below. Also included updated config file just in case. Sorry to pester just really like the module.
          mdwebb@raspberrypi:~/MagicMirror $ git switch _fix_clipping
          M	css/main.css
          Already on '_fix_clipping'
          mdwebb@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
          npm run install-mm
          > magicmirror@2.31.0-develop install-mm
          > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
          > magicmirror@2.31.0-develop postinstall
          > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          > magicmirror@2.31.0-develop install-vendor
          > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          up to date in 1s
          > magicmirror@2.31.0-develop install-fonts
          > echo "Installing fonts ...
          > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          up to date in 1s
          > magicmirror@2.31.0-develop prepare
          > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
          no husky installed.
          up to date in 9s
          mdwebb@raspberrypi:~/MagicMirror $ npm start
          > magicmirror@2.31.0-develop start
          > npm run start:x11
          > magicmirror@2.31.0-develop start:x11
          [2025-01-08 19:56:04.602] [LOG]   Starting MagicMirror: v2.31.0-develop
          [2025-01-08 19:56:04.630] [LOG]   Loading config ...
          [2025-01-08 19:56:04.632] [LOG]   config template file not exists, no envsubst
          [2025-01-08 19:56:05.150] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
          [2025-01-08 19:56:05.263] [INFO]  Your configuration file doesn't contain syntax errors :)
          [2025-01-08 19:56:05.264] [INFO]  Checking modules structure configuration ...
          [2025-01-08 19:56:05.380] [ERROR] This module configuration contains errors:
          {}must have required property 'module'
          [2025-01-08 19:56:05.382] [WARN]  No module name found for this configuration:
          [2025-01-08 19:56:05.383] [WARN]  No module name found for this configuration:
          [2025-01-08 19:56:05.384] [LOG]   Loading module helpers ...
          [2025-01-08 19:56:05.391] [LOG]   Initializing new module helper ...
          [2025-01-08 19:56:05.392] [LOG]   Module helper loaded: updatenotification
          [2025-01-08 19:56:05.393] [LOG]   No helper found for module: clock.
          [2025-01-08 19:56:05.527] [LOG]   Initializing new module helper ...
          [2025-01-08 19:56:05.527] [LOG]   Module helper loaded: calendar
          [2025-01-08 19:56:05.529] [LOG]   No helper found for module: MMM-CalendarExt3.
          [2025-01-08 19:56:05.726] [LOG]   Initializing new module helper ...
          [2025-01-08 19:56:05.727] [LOG]   Module helper loaded: MMM-ImagesPhotos
          [2025-01-08 19:56:05.743] [LOG]   Initializing new module helper ...
          [2025-01-08 19:56:05.744] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
          [2025-01-08 19:56:05.744] [LOG]   All module helpers loaded.
          [2025-01-08 19:56:05.754] [LOG]   Starting server on port 8080 ...
          [2025-01-08 19:56:06.763] [LOG]   Server started ...
          [2025-01-08 19:56:06.764] [LOG]   Connecting socket for: updatenotification
          [2025-01-08 19:56:06.766] [LOG]   Starting module helper: updatenotification
          [2025-01-08 19:56:06.767] [LOG]   Connecting socket for: calendar
          [2025-01-08 19:56:06.768] [LOG]   Starting node helper for: calendar
          [2025-01-08 19:56:06.769] [LOG]   Connecting socket for: MMM-ImagesPhotos
          [2025-01-08 19:56:06.771] [LOG]   Starting node helper for: MMM-ImagesPhotos
          [2025-01-08 19:56:06.772] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
          [2025-01-08 19:56:06.777] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
          [2025-01-08 19:56:06.778] [LOG]   Sockets connected & modules started ...
          [2025-01-08 19:56:07.134] [LOG]   Launching application.
          [2025-01-08 19:56:08.242] [INFO]  System information:
          ### SYSTEM:   manufacturer: ; model: ; virtual: false
          ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
          ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
          ### OTHER:    timeZone: Australia/Melbourne; ELECTRON_ENABLE_GPU: undefined
          [2957:0108/195608.659832:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.660229:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.660540:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.660650:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.660812:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.660910:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.661069:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.661161:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.661311:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.661411:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.661563:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.661654:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.661802:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.661894:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.663097:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.663239:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.663417:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.663539:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.663700:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.663793:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.663943:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.664034:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.664181:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.664271:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.664418:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.664510:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2957:0108/195608.664658:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
          [2957:0108/195608.664748:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
          [2025-01-08 19:56:09.808] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics - Interval: 3600000
          [2025-01-08 19:56:09.886] [LOG]   Config based debug=module_6_MMM-ImagesPhotos
          [2025-01-08 19:56:09.894] [INFO]  updatenotification: Updater Class Loaded!
          [2025-01-08 19:56:09.895] [INFO]  updatenotification: Checking PM2 using...
          [2025-01-08 19:56:09.895] [INFO]  updatenotification: [PM2] You are not using pm2
          [2025-01-08 19:56:09.896] [INFO]  Checking git for module: MMM-CalendarExt3
          [2025-01-08 19:56:09.919] [INFO]  Checking git for module: MMM-ImagesPhotos
          [2025-01-08 19:56:09.939] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
          [2025-01-08 19:56:09.970] [INFO]  Checking git for module: MagicMirror
          [2025-01-08 19:56:16.687] [INFO]  Calendar-Fetcher: Broadcasting 951 events from https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics.
          [2025-01-08 19:56:24.651] [LOG]   Shutting down server...
          [2025-01-08 19:56:24.653] [LOG]   Stopping module helper: updatenotification
          [2025-01-08 19:56:24.656] [LOG]   Stopping module helper: calendar
          [2025-01-08 19:56:24.657] [LOG]   Stopping module helper: MMM-ImagesPhotos
          [2025-01-08 19:56:24.658] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
          [2025-01-08 19:56:24.659] [LOG]   Node_helpers stopped ...
          let config = {
          	address: "localhost",	// Address to listen on, can be:
          	port: 8080,
          	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
          	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
          	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
          	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
          	language: "en",
          	locale: "en-US",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "Webb's",
          			//position: "top_left",
          						symbol: "calendar-check",
          						url: "https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/public/basic.ics"
              broadcastPastEvents: true, // <= IMPORTANT to see past events
                  url: "https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics",
                  name: "us_holiday", // <= RECOMMENDED to assign name
                  color: "red", // <= RECOMMENDED to assign color
                  defaultSymbolClassName: "",
            module: "MMM-CalendarExt3",
            position: "bottom_bar",
            title: "",
              mode: "week",
              instanceId: "basicCalendar",
              locale: 'en-US',
              maxEventLines: 6,
              firstDayOfWeek: 0,
              calendarSet: [],
              weekIndex: 0,
              weeksInView: 4,
              eventHeight: '15px',
              useMarquee: true,
              eventTransformer: (ev)=> {
            if (ev.title.search('DINNER') > -1) ev.symbol	 = ['fluent-color:food-28']
            if (ev.title.search('Arnold') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
            if (ev.title.search('Gus') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
            if (ev.title.search('Dogs') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
            if (ev.title.search('dogs') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
            if (ev.title.search('Marcus') > -1) ev.symbol	 = ['noto:pretzel']
            if (ev.title.search('Pretzel') > -1) ev.symbol	 = ['noto:pretzel']
            if (ev.title.search('Recycle Bin') > -1) ev.symbol	 = ['game-icons:soda-bottle']
            if (ev.title.search('Green Waste bins') > -1) ev.symbol	 = ['streamline-emojis:leaf-fluttering-in-wind']
            if (ev.title.search('Cleaning Day') > -1) ev.symbol	 = ['openmoji:broom']
            if (ev.title.search('Swimming') > -1) ev.symbol	 = ['fxemoji:swimming']
            if (ev.title.search('Phils') > -1) ev.symbol	 = ['twemoji:baby-angel-light-skin-tone']
            if (ev.title.search('Phyllis') > -1) ev.symbol	 = ['twemoji:baby-angel-light-skin-tone']
            if (ev.title.search('Birthday') > -1) ev.symbol	 = ['emojione:birthday-cake']
            if (ev.title.search('birthday') > -1) ev.symbol	 = ['emojione:birthday-cake']
            if (ev.title.search('Hugo') > -1) ev.symbol	 = ['cryptocurrency-color:hight']
            if (ev.title.search('Maggie') > -1) ev.symbol	 = ['cryptocurrency-color:xmy']
            if (ev.title.search('Lucas') > -1) ev.symbol	 = ['openmoji:man-judge-light-skin-tone']
            if (ev.title.search('Hudge') > -1) ev.symbol	 = ['twemoji:gemini']
            if (ev.title.search('Danielle') > -1) ev.symbol	 = ['twemoji:gemini']
            return ev
          			module: "weather",
          			disabled: true,
          				weatherProvider: "openmeteo",
          				type: "current",
          				lat: 40.776676,
          				lon: -73.971321
          			module: "weather",
          			disabled: true,
          			header: "Weather Forecast",
          				type: "forecast",
          				lat: 40.776676,
          				lon: -73.971321
           module: "MMM-ImagesPhotos",
           position: "top_center",
            opacity: 0.9,
            animationSpeed: 1000,
            updateInterval: 5000,
            maxHeight: "500px",
            maxWidth:"500px",
            sequential: false  // process the image list randomly
                module: "MMM-OpenWeatherMapForecast",
                header: "Weather",
                classes: "default everyone",
                  apikey: "cfb4187b9743b212915c5438d685f778",
                  latitude: "-38.314560",
                  longitude: "146.419373",
                  iconset: "4c",
                  concise: false,
                  forecastLayout: "table",
                  showDailyForecast: true,
                  maxDailiesToShow: 5,
                  showHourlyForecast: false,
                  showWind: false
          			module: "newsfeed",
          			disabled: true,
          				feeds: [
          						title: "New York Times",
          						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
            djkleric @sdetweil
            @sdetweil Thank you, after a few things I was able to get it working. I was not able to get it to work on the rp 3b but was able to get it working on the rp5. Appreciate you.
              sdetweil @MDWEBB
                	header: "Webb's",
              this creates an empty module, why you got the
              @MDWEBB said in [Version 2\.30\.0 Calendar fix for clipping broadcast events](/post/122771):
              errors
              what do you mean not working on pi 3?
                MDWEBB @sdetweil
                @sdetweil thanks removing this module has cleared the error on boot however still not having any lucky with events broadcasting for CalendarExt3
                > npm run start:x11
                [2025-01-09 08:18:52.543] [LOG]   Starting MagicMirror: v2.31.0-develop
                [2025-01-09 08:18:52.572] [LOG]   Loading config ...
                [2025-01-09 08:18:52.575] [LOG]   config template file not exists, no envsubst
                [2025-01-09 08:18:53.097] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
                [2025-01-09 08:18:53.206] [INFO]  Your configuration file doesn't contain syntax errors :)
                [2025-01-09 08:18:53.208] [INFO]  Checking modules structure configuration ...
                [2025-01-09 08:18:53.324] [INFO]  Your modules structure configuration doesn't contain errors :)
                [2025-01-09 08:18:53.327] [LOG]   Loading module helpers ...
                [2025-01-09 08:18:53.329] [LOG]   No helper found for module: alert.
                [2025-01-09 08:18:53.336] [LOG]   Initializing new module helper ...
                [2025-01-09 08:18:53.337] [LOG]   Module helper loaded: updatenotification
                [2025-01-09 08:18:53.338] [LOG]   No helper found for module: clock.
                [2025-01-09 08:18:53.474] [LOG]   Initializing new module helper ...
                [2025-01-09 08:18:53.474] [LOG]   Module helper loaded: calendar
                [2025-01-09 08:18:53.476] [LOG]   No helper found for module: MMM-CalendarExt3.
                [2025-01-09 08:18:53.674] [LOG]   Initializing new module helper ...
                [2025-01-09 08:18:53.675] [LOG]   Module helper loaded: MMM-ImagesPhotos
                [2025-01-09 08:18:53.693] [LOG]   Initializing new module helper ...
                [2025-01-09 08:18:53.694] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                [2025-01-09 08:18:53.694] [LOG]   All module helpers loaded.
                [2025-01-09 08:18:53.704] [LOG]   Starting server on port 8080 ...
                [2025-01-09 08:18:54.652] [LOG]   Server started ...
                [2025-01-09 08:18:54.653] [LOG]   Connecting socket for: updatenotification
                [2025-01-09 08:18:54.655] [LOG]   Starting module helper: updatenotification
                [2025-01-09 08:18:54.656] [LOG]   Connecting socket for: calendar
                [2025-01-09 08:18:54.657] [LOG]   Starting node helper for: calendar
                [2025-01-09 08:18:54.658] [LOG]   Connecting socket for: MMM-ImagesPhotos
                [2025-01-09 08:18:54.659] [LOG]   Starting node helper for: MMM-ImagesPhotos
                [2025-01-09 08:18:54.660] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                [2025-01-09 08:18:54.661] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
                [2025-01-09 08:18:54.662] [LOG]   Sockets connected & modules started ...
                [2025-01-09 08:18:55.059] [LOG]   Launching application.
                [2025-01-09 08:18:56.218] [INFO]  System information:
                [5307:0109/081856.487945:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.488320:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.488591:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.488693:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.488880:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.488963:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.489136:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.489218:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.489384:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.489472:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.489641:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.489720:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.489884:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.489962:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.491709:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.491833:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.492011:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.492121:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.492294:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.492377:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.492540:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.492619:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.492789:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.492880:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.493063:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.493142:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [5307:0109/081856.493306:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                [5307:0109/081856.493385:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                [2025-01-09 08:18:57.750] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics - Interval: 3600000
                [2025-01-09 08:18:57.799] [LOG]   Config based debug=module_7_MMM-ImagesPhotos
                [2025-01-09 08:18:57.807] [INFO]  updatenotification: Updater Class Loaded!
                [2025-01-09 08:18:57.808] [INFO]  updatenotification: Checking PM2 using...
                [2025-01-09 08:18:57.809] [INFO]  updatenotification: [PM2] You are not using pm2
                [2025-01-09 08:18:57.811] [INFO]  Checking git for module: MMM-CalendarExt3
                [2025-01-09 08:18:57.834] [INFO]  Checking git for module: MMM-ImagesPhotos
                [2025-01-09 08:18:57.857] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                [2025-01-09 08:18:57.889] [INFO]  Checking git for module: MagicMirror
                [2025-01-09 08:19:03.894] [INFO]  Calendar-Fetcher: Broadcasting 953 events from https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics.
                [2025-01-09 08:19:15.083] [LOG]   Shutting down server...
                [2025-01-09 08:19:15.084] [LOG]   Stopping module helper: updatenotification
                [2025-01-09 08:19:15.085] [LOG]   Stopping module helper: calendar
                [2025-01-09 08:19:15.086] [LOG]   Stopping module helper: MMM-ImagesPhotos
                [2025-01-09 08:19:15.087] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
                [2025-01-09 08:19:15.090] [LOG]   Node_helpers stopped ...
                  sdetweil @MDWEBB
                  @MDWEBB says it broadcast over 900 events
                  there is an Ext3 function for seeing all the events, maybe check there to see if its called, dont see why not
                    MDWEBB @sdetweil
                    @sdetweil Thanks for all the help i was able to get it working. Removed the extra module and then it was actually only bringing events in after the first refresh interval of the module, which was odd as it usually brought them in upon start up but is operating fine now.
                      sdetweil @MDWEBB
                      @MDWEBB i think this is a timing thing
                      you could try changing these two config parameters
                      waitFetch and refreshInterval
                        angeliKITTYx
                        @sdetweil i ran the commands in your post, but now everything is totally broken…
                        This is the beginning of what it gives me. I can’t even launch MM now. Do you know what I can do?
                        burgess@raspberrypi:~/MagicMirror $ git fetch origin pull/3679/head:_fix_clipping
                        burgess@raspberrypi:~/MagicMirror $ git switch _fix_clipping
                        Switched to branch '_fix_clipping'
                        burgess@raspberrypi:~/MagicMirror $ npm run start
                        > npm run start:x11
                        App threw an error during load
                        Error: Cannot find module 'ansis'
                        Require stack:
                        - /home/burgess/MagicMirror/js/logger.js
                        - /home/burgess/MagicMirror/js/app.js
                        - /home/burgess/MagicMirror/js/electron.js
                        - /home/burgess/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                            at node:internal/modules/cjs/loader:1084:15
                            at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
                            at Module._resolveFilename (/home/burgess/MagicMirror/node_modules/module-alias/index.js:49:29)
                            at node:internal/modules/cjs/loader:929:27
                            at Function._load (node:electron/js2c/asar_bundle:2:13327)
                            at Module.require (node:internal/modules/cjs/loader:1150:19)
                            at require (node:internal/modules/cjs/helpers:121:18)
                            at /home/burgess/MagicMirror/js/logger.js:5:19
                            at Object.<anonymous> (/home/burgess/MagicMirror/js/logger.js:46:2)
                            at Module._compile (node:internal/modules/cjs/loader:1271:14)
                            at Object..js (node:internal/modules/cjs/loader:1326:10)
                            at Module.load (node:internal/modules/cjs/loader:1126:32)
                            at node:internal/modules/cjs/loader:967:12
                        A JavaScript error occurred in the main process
                        Uncaught Exception:
                        Require stack:
                        [21857:0111/103910.674526:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.675123:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.675382:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.675579:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.675720:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.675973:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.676145:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.677266:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.677469:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.677676:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.677856:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.677993:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.678216:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [21857:0111/103910.678351:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                          sdetweil @angeliKITTYx
                          @angeliKITTYx you missed a step
                          npm run install-mm
                            sdetweil @MDWEBB
                            @MDWEBB ok, you didn’t switch to the new branch
                              angeliKITTYx @sdetweil
                              @sdetweil Okay, I got MM to launch, but now other modules are broken and the calendar is still a mess. 3 of 7 are showing, and “all day” events are starting at 5AM and go into the next day. The command window says it’s populating x number of events from all 7 calendars, but they’re not showing up.
                              screenshot every event here is an “all day” event, and 4 of the calendars aren’t showing.
                              > npm run start:x11
                              [2025-01-11 13:22:17.187] [LOG]   Starting MagicMirror: v2.31.0-develop
                              [2025-01-11 13:22:17.225] [LOG]   Loading config ...
                              [2025-01-11 13:22:17.228] [LOG]   config template file not exists, no envsubst
                              [2025-01-11 13:22:17.817] [INFO]  Checking config file /home/burgess/MagicMirror/config/config.js ...
                              [2025-01-11 13:22:17.921] [INFO]  Your configuration file doesn't contain syntax errors :)
                              [2025-01-11 13:22:17.923] [INFO]  Checking modules structure configuration ...
                              [2025-01-11 13:22:18.059] [INFO]  Your modules structure configuration doesn't contain errors :)
                              [2025-01-11 13:22:18.063] [LOG]   Loading module helpers ...
                              [2025-01-11 13:22:18.064] [LOG]   No helper found for module: alert.
                              [2025-01-11 13:22:18.076] [LOG]   Initializing new module helper ...
                              [2025-01-11 13:22:18.077] [LOG]   Module helper loaded: updatenotification
                              [2025-01-11 13:22:18.079] [LOG]   No helper found for module: clock.
                              [2025-01-11 13:22:18.080] [LOG]   No helper found for module: weather.
                              [2025-01-11 13:22:18.090] [LOG]   Initializing new module helper ...
                              [2025-01-11 13:22:18.091] [LOG]   Module helper loaded: MMM-OnThisDayWikiApi
                              [2025-01-11 13:22:18.255] [LOG]   Initializing new module helper ...
                              [2025-01-11 13:22:18.256] [LOG]   Module helper loaded: calendar
                              [2025-01-11 13:22:18.257] [LOG]   No helper found for module: MMM-CalendarExt3.
                              [2025-01-11 13:22:18.628] [LOG]   Initializing new module helper ...
                              [2025-01-11 13:22:18.628] [LOG]   Module helper loaded: MMM-GooglePhotos
                              [2025-01-11 13:22:18.631] [ERROR] Error when loading MMM-GoogleTasks: Cannot find module 'googleapis'
                              Require stack:
                              - /home/burgess/MagicMirror/modules/MMM-GoogleTasks/node_helper.js
                              [2025-01-11 13:22:18.632] [LOG]   All module helpers loaded.
                              [2025-01-11 13:22:18.641] [LOG]   Starting server on port 8080 ...
                              [2025-01-11 13:22:19.595] [LOG]   Server started ...
                              [2025-01-11 13:22:19.597] [LOG]   Connecting socket for: updatenotification
                              [2025-01-11 13:22:19.598] [LOG]   Starting module helper: updatenotification
                              [2025-01-11 13:22:19.599] [LOG]   Connecting socket for: MMM-OnThisDayWikiApi
                              [2025-01-11 13:22:19.600] [LOG]   Started node_helper.js for MMM-OnThisDayWikiApi.
                              [2025-01-11 13:22:19.601] [LOG]   Connecting socket for: calendar
                              [2025-01-11 13:22:19.603] [LOG]   Starting node helper for: calendar
                              [2025-01-11 13:22:19.604] [LOG]   Connecting socket for: MMM-GooglePhotos
                              [2025-01-11 13:22:19.607] [LOG]   Sockets connected & modules started ...
                              [2025-01-11 13:22:19.983] [LOG]   Launching application.
                              [93585:0111/132221.707589:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.707977:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.708192:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.708280:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.708416:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.708498:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.708623:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.708695:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.708813:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.708894:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.709014:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.709087:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.709205:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.709278:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.710430:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.710527:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.710657:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.710755:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.710925:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.711002:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.711120:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.711194:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.711311:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.711381:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.711495:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.711566:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93585:0111/132221.711682:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93585:0111/132221.711753:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [2025-01-11 13:22:22.891] [INFO]  System information:
                              ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.31+rpt-rpi-v8
                              ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                              [2025-01-11 13:22:24.539] [LOG]   MMM-OnThisDayWikiApi node helper received a socket notification: ONTHISDAY_FETCH - Payload: [object Object]
                              [2025-01-11 13:22:24.541] [LOG]   https://api.wikimedia.org/feed/v1/wikipedia/en/onthisday/selected/01/11
                              [2025-01-11 13:22:24.645] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics - Interval: 100000
                              [2025-01-11 13:22:24.651] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics - Interval: 100000
                              [2025-01-11 13:22:24.654] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics - Interval: 100000
                              [2025-01-11 13:22:24.657] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics - Interval: 100000
                              [2025-01-11 13:22:24.660] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics - Interval: 100000
                              [2025-01-11 13:22:24.663] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics - Interval: 100000
                              [2025-01-11 13:22:24.670] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics - Interval: 100000
                              [2025-01-11 13:22:25.240] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                              [2025-01-11 13:22:25.359] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                              [2025-01-11 13:22:25.482] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                              [2025-01-11 13:22:26.506] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                              [2025-01-11 13:22:26.716] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                              [2025-01-11 13:22:26.881] [LOG]   OnThisDay-Fetcher: Broadcasting 17 items.
                              [2025-01-11 13:22:27.087] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                              [2025-01-11 13:22:30.191] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                              [2025-01-11 13:24:05.593] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                              [2025-01-11 13:24:05.647] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                              [2025-01-11 13:24:05.878] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                              [2025-01-11 13:24:07.544] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                              [2025-01-11 13:24:07.870] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                              [2025-01-11 13:24:07.981] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                              [2025-01-11 13:24:14.258] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                              [2025-01-11 13:25:46.035] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                              [2025-01-11 13:25:46.181] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                              [2025-01-11 13:25:46.337] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                              [2025-01-11 13:25:48.631] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                              [2025-01-11 13:25:48.952] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                              [2025-01-11 13:25:49.061] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                              [2025-01-11 13:25:58.216] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                              [2025-01-11 13:27:26.321] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                              [2025-01-11 13:27:26.473] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                              [2025-01-11 13:27:26.572] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                              [2025-01-11 13:27:29.648] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                              [2025-01-11 13:27:29.976] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                              [2025-01-11 13:27:30.093] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                              [2025-01-11 13:27:42.234] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                              [2025-01-11 13:28:49.689] [LOG]   Shutting down server...
                              [2025-01-11 13:28:49.690] [LOG]   Stopping module helper: updatenotification
                              [2025-01-11 13:28:49.690] [LOG]   Stopping module helper: MMM-OnThisDayWikiApi
                              [2025-01-11 13:28:49.691] [LOG]   Stopping module helper: calendar
                              [2025-01-11 13:28:49.691] [LOG]   Node_helpers stopped ...
                              > npm run start:x11
                              [2025-01-11 13:33:21.858] [LOG]   Starting MagicMirror: v2.31.0-develop
                              [2025-01-11 13:33:21.895] [LOG]   Loading config ...
                              [2025-01-11 13:33:21.898] [LOG]   config template file not exists, no envsubst
                              [2025-01-11 13:33:22.431] [INFO]  Checking config file /home/burgess/MagicMirror/config/config.js ...
                              [2025-01-11 13:33:22.540] [INFO]  Your configuration file doesn't contain syntax errors :)
                              [2025-01-11 13:33:22.541] [INFO]  Checking modules structure configuration ...
                              [2025-01-11 13:33:22.671] [INFO]  Your modules structure configuration doesn't contain errors :)
                              [2025-01-11 13:33:22.674] [LOG]   Loading module helpers ...
                              [2025-01-11 13:33:22.675] [LOG]   No helper found for module: alert.
                              [2025-01-11 13:33:22.683] [LOG]   Initializing new module helper ...
                              [2025-01-11 13:33:22.684] [LOG]   Module helper loaded: updatenotification
                              [2025-01-11 13:33:22.685] [LOG]   No helper found for module: clock.
                              [2025-01-11 13:33:22.686] [LOG]   No helper found for module: weather.
                              [2025-01-11 13:33:22.691] [LOG]   Initializing new module helper ...
                              [2025-01-11 13:33:22.692] [LOG]   Module helper loaded: MMM-OnThisDayWikiApi
                              [2025-01-11 13:33:22.837] [LOG]   Initializing new module helper ...
                              [2025-01-11 13:33:22.837] [LOG]   Module helper loaded: calendar
                              [2025-01-11 13:33:22.839] [LOG]   No helper found for module: MMM-CalendarExt3.
                              [2025-01-11 13:33:23.047] [LOG]   Initializing new module helper ...
                              [2025-01-11 13:33:23.047] [LOG]   Module helper loaded: MMM-GooglePhotos
                              [2025-01-11 13:33:23.049] [ERROR] Error when loading MMM-GoogleTasks: Cannot find module 'googleapis'
                              Require stack:
                              [2025-01-11 13:33:23.050] [LOG]   All module helpers loaded.
                              [2025-01-11 13:33:23.060] [LOG]   Starting server on port 8080 ...
                              [2025-01-11 13:33:24.093] [LOG]   Server started ...
                              [2025-01-11 13:33:24.095] [LOG]   Connecting socket for: updatenotification
                              [2025-01-11 13:33:24.097] [LOG]   Starting module helper: updatenotification
                              [2025-01-11 13:33:24.098] [LOG]   Connecting socket for: MMM-OnThisDayWikiApi
                              [2025-01-11 13:33:24.099] [LOG]   Started node_helper.js for MMM-OnThisDayWikiApi.
                              [2025-01-11 13:33:24.100] [LOG]   Connecting socket for: calendar
                              [2025-01-11 13:33:24.102] [LOG]   Starting node helper for: calendar
                              [2025-01-11 13:33:24.103] [LOG]   Connecting socket for: MMM-GooglePhotos
                              [2025-01-11 13:33:24.105] [LOG]   Sockets connected & modules started ...
                              [2025-01-11 13:33:24.460] [LOG]   Launching application.
                              [2025-01-11 13:33:25.918] [INFO]  System information:
                              [93838:0111/133325.993897:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.994339:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.994652:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.994820:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.995048:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.995175:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.995380:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.995501:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.995702:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.995827:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.996014:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.996128:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.996323:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.996435:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.997768:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.997947:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.998173:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.998331:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.998552:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.998671:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.998903:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.999041:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.999233:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.999339:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.999524:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.999633:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [93838:0111/133325.999822:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [93838:0111/133325.999936:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [2025-01-11 13:33:27.852] [LOG]   MMM-OnThisDayWikiApi node helper received a socket notification: ONTHISDAY_FETCH - Payload: [object Object]
                              [2025-01-11 13:33:27.853] [LOG]   https://api.wikimedia.org/feed/v1/wikipedia/en/onthisday/selected/01/11
                              [2025-01-11 13:33:27.930] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics - Interval: 100000
                              [2025-01-11 13:33:27.939] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics - Interval: 100000
                              [2025-01-11 13:33:27.946] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics - Interval: 100000
                              [2025-01-11 13:33:27.951] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics - Interval: 100000
                              [2025-01-11 13:33:27.954] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics - Interval: 100000
                              [2025-01-11 13:33:27.956] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics - Interval: 100000
                              [2025-01-11 13:33:27.959] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics - Interval: 100000
                              [2025-01-11 13:33:28.317] [LOG]   OnThisDay-Fetcher: Broadcasting 17 items.
                              [2025-01-11 13:33:28.772] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                              [2025-01-11 13:33:28.996] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                              [2025-01-11 13:33:30.577] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                              [2025-01-11 13:33:30.690] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                              [2025-01-11 13:33:30.814] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                              [2025-01-11 13:33:30.938] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                              [2025-01-11 13:33:33.617] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                              [2025-01-11 13:35:09.183] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                              [2025-01-11 13:35:09.444] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                              [2025-01-11 13:35:11.698] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                              [2025-01-11 13:35:11.765] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                              [2025-01-11 13:35:11.973] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                              [2025-01-11 13:35:12.072] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                              [2025-01-11 13:35:17.541] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                              [2025-01-11 13:35:56.202] [LOG]   Shutting down server...
                              [2025-01-11 13:35:56.204] [LOG]   Stopping module helper: updatenotification
                              [2025-01-11 13:35:56.204] [LOG]   Stopping module helper: MMM-OnThisDayWikiApi
                              [2025-01-11 13:35:56.204] [LOG]   Stopping module helper: calendar
                              [2025-01-11 13:35:56.205] [LOG]   Node_helpers stopped ...
                                @angeliKITTYx said in Version 2.30.0 Calendar fix for clipping broadcast events:
                                MMM-GoogleTasks: Cannot find module ‘googleapis’
                                this sounds like a module install problem
                                go to the MMM-GoogleTasks module folder and do npm install
                                  @sdetweil the install command went through properly, but I’m still getting the same results when I launch MM.
                                    @angeliKITTYx there are events broadcast over almost 2 minutes. I think Ext3 tries to hold off updating exactly when events arrive
                                    there is a properties on Ext3
                                    waitFetch 5000 (ms) waiting the fetching of last calendar to prevent flickering view by too frequent fetching.
                                    refreshInterval 1800000 (ms) refresh view by force if you need it.
                                      @angeliKITTYx can you go to the MMM-GoogleTasks module folder and do
                                      ls node_modules/googleapis
                                      it should display something
                                      then
                                      rm-rf node_modules
                                      npm install
                                        @angeliKITTYx ok, the module has a problem
                                        it didn’t document NEEDING that library (it has no package.json file)
                                        so do the general fix for missing dependencies
                                        see here for the steps
                                        https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later?page=1
                                          @sdetweil that link fixed the module, thank you! Now just the issue of the calendar. Here’s my config file - did I add those parameters correctly? My Ext3 refreshinterval used to be 105000. Once I changed that and added the fetch, the “all day” events are still showing wrong and I’m down to 2 of 7 calendars showing.
                                          			header: "Family Calendar",
                                          			hiddenOnStartup: "true",
                                          				displaySymbol: false,
                                          				showEnd: false,
                                          				fetchInterval: 100000,
                                          						url: "https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics",
                                          						color: "mediumpurple"
                                          						url: "https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics",
                                          						color: "darkgrey"
                                          						url: "https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics",
                                          						color: "cyan"
                                          						url: "https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics",
                                          						color: "black"
                                          						url: "https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics",
                                          						color: "palevioletred"
                                          						url: "https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics",
                                          						color: "blue"
                                          						url: "https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics",
                                          						color: "green"
                                          					mode: "week",
                                          					useSymbol: false,
                                          					showMore: true,
                                          					refreshInterval: "1800000",
                                          					waitFetch: "5000",
                                          					weekIndex: "0",
                                          					fontSize: "22px",
                                          					maxEventLines: 5,
                                          					firstDayOfWeek: 7,
                                          					calendarSet: ['family_cal', 'alecwork_cal', 'alec_cal', 'days_off', 'birthdays', 'Recycling', 'Trash'],
                                            @angeliKITTYx i think the refreshInterval you set is 30 minutes
                                            just for grins , try
                                             3*60*1000
                                            as your initial load is under that
                                            • 1 / 4
