    Version 2.30.0 Calendar fix for clipping broadcast events
    67 Posts 10 Posters 36.0k Views 10 Watching
    • bugsounetB Offline
      bugsounet Banned @sdetweil
      @sdetweil ok,… If you think that is an hot fix, not me :/
      I just wish users good luck for the next update.
      why ?
      just because they lost master branch
      bugsounet@PC-Bugsounet:~/MagicMirror$ git branch
      * _fix_clipping
        develop
        master
      so they NEVER have MM v2.31.0, git pull will not works (detached head) :/
      That’s why … maybe hotfix needed (v2.30.1)
        sdetweil @bugsounet
        @bugsounet my script puts it back on the master before the fetch…
        easy man…
        lets work thru the issue first…
        confirm it works
        and then work on how to deploy it
        its not fatal…
        only been a few hours…
        hotfix - provide a way repeatable for customer to get around the problem
          djkleric
          Hello, I am new to this. I am not getting my Google calendar to populate in this Module. It is populating in the default calendar.
          I have tried the above but when I try the switch, terminal gives an error. Your local changes to the files would be overwritten by checkout. Package-lock.json
          Please commit your changes or stash them before you switch branches. Sorry for the newb inquiry.
            sdetweil @djkleric
            @djkleric erase
            rm package-lock.sjon
              MDWEBB @sdetweil
              @sdetweil I have tried to apply your fix as mentioned however i am still not getting events to populate in the MMM-CalendarExt3 module.
              I have also uninstalled and reinstalled the module entirely hoping that would help. Below is my config file and the launch window if that is of any assistance.
              Any insight would be greatly appreciated.
              mdwebb@raspberrypi:~/MagicMirror $ npm start
              > magicmirror@2.30.0 start
              > npm run start:x11
              > magicmirror@2.30.0 start:x11
              [2025-01-07 22:00:29.574] [LOG]   Starting MagicMirror: v2.30.0
              [2025-01-07 22:00:29.602] [LOG]   Loading config ...
              [2025-01-07 22:00:29.604] [LOG]   config template file not exists, no envsubst
              [2025-01-07 22:00:30.136] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
              [2025-01-07 22:00:30.241] [INFO]  Your configuration file doesn't contain syntax errors :)
              [2025-01-07 22:00:30.242] [INFO]  Checking modules structure configuration ...
              [2025-01-07 22:00:30.369] [ERROR] This module configuration contains errors:
              {}must have required property 'module'
              [2025-01-07 22:00:30.372] [WARN]  No module name found for this configuration:
              [2025-01-07 22:00:30.373] [WARN]  No module name found for this configuration:
              [2025-01-07 22:00:30.374] [WARN]  No module name found for this configuration:
              [2025-01-07 22:00:30.375] [LOG]   Loading module helpers ...
              [2025-01-07 22:00:30.382] [LOG]   Initializing new module helper ...
              [2025-01-07 22:00:30.383] [LOG]   Module helper loaded: updatenotification
              [2025-01-07 22:00:30.384] [LOG]   No helper found for module: clock.
              [2025-01-07 22:00:30.519] [LOG]   Initializing new module helper ...
              [2025-01-07 22:00:30.520] [LOG]   Module helper loaded: calendar
              [2025-01-07 22:00:30.521] [LOG]   No helper found for module: MMM-CalendarExt3.
              [2025-01-07 22:00:30.728] [LOG]   Initializing new module helper ...
              [2025-01-07 22:00:30.729] [LOG]   Module helper loaded: MMM-ImagesPhotos
              [2025-01-07 22:00:30.745] [LOG]   Initializing new module helper ...
              [2025-01-07 22:00:30.745] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
              [2025-01-07 22:00:30.746] [LOG]   All module helpers loaded.
              [2025-01-07 22:00:30.755] [LOG]   Starting server on port 8080 ...
              [2025-01-07 22:00:31.931] [LOG]   Server started ...
              [2025-01-07 22:00:31.933] [LOG]   Connecting socket for: updatenotification
              [2025-01-07 22:00:31.935] [LOG]   Starting module helper: updatenotification
              [2025-01-07 22:00:31.936] [LOG]   Connecting socket for: calendar
              [2025-01-07 22:00:31.937] [LOG]   Starting node helper for: calendar
              [2025-01-07 22:00:31.938] [LOG]   Connecting socket for: MMM-ImagesPhotos
              [2025-01-07 22:00:31.939] [LOG]   Starting node helper for: MMM-ImagesPhotos
              [2025-01-07 22:00:31.940] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
              [2025-01-07 22:00:31.941] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
              [2025-01-07 22:00:31.942] [LOG]   Sockets connected & modules started ...
              [2025-01-07 22:00:32.295] [LOG]   Launching application.
              [2025-01-07 22:00:33.385] [INFO]  System information:
              ### SYSTEM:   manufacturer: ; model: ; virtual: false
              ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
              ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
              ### OTHER:    timeZone: Australia/Melbourne; ELECTRON_ENABLE_GPU: undefined
              [27507:0107/220033.757928:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.758396:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.758713:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.758828:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.759036:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.759137:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.759325:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.759425:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.759614:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.759757:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.759944:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.760042:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.760230:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.760324:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.761815:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.761940:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.762133:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.762305:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.762519:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.762618:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.762804:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.762901:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.763080:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.763176:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.763360:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.763453:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [27507:0107/220033.763639:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [27507:0107/220033.763743:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [2025-01-07 22:00:34.946] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics - Interval: 3600000
              [2025-01-07 22:00:35.004] [LOG]   Config based debug=module_4_MMM-ImagesPhotos
              [2025-01-07 22:00:35.017] [INFO]  updatenotification: Updater Class Loaded!
              [2025-01-07 22:00:35.018] [INFO]  updatenotification: Checking PM2 using...
              [2025-01-07 22:00:35.019] [INFO]  updatenotification: [PM2] You are not using pm2
              [2025-01-07 22:00:35.020] [INFO]  Checking git for module: MMM-CalendarExt3
              [2025-01-07 22:00:35.061] [INFO]  Checking git for module: MMM-ImagesPhotos
              [2025-01-07 22:00:35.094] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
              [2025-01-07 22:00:35.121] [INFO]  Checking git for module: MagicMirror
              [2025-01-07 22:00:41.687] [INFO]  Calendar-Fetcher: Broadcasting 948 events from https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics.
              [2025-01-07 22:00:45.074] [LOG]   Shutting down server...
              [2025-01-07 22:00:45.075] [LOG]   Stopping module helper: updatenotification
              [2025-01-07 22:00:45.076] [LOG]   Stopping module helper: calendar
              [2025-01-07 22:00:45.076] [LOG]   Stopping module helper: MMM-ImagesPhotos
              [2025-01-07 22:00:45.076] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
              [2025-01-07 22:00:45.077] [LOG]   Node_helpers stopped ...
                  broadcastPastEvents: true, // <= IMPORTANT to see past events
                      url: "https://calendar.google.com/calendar/ical/",
                      name: "us_holiday", // <= RECOMMENDED to assign name
                      color: "red", // <= RECOMMENDED to assign color
                      defaultSymbolClassName: "",
                module: "MMM-CalendarExt3",
                position: "bottom_bar",
                title: "",
                  mode: "week",
                  instanceId: "basicCalendar",
                  locale: 'en-US',
                  maxEventLines: 6,
                  firstDayOfWeek: 0,
                  calendarSet: [],
                  weekIndex: 0,
                  weeksInView: 4,
                  eventHeight: '15px',
                  useMarquee: true,
                  eventTransformer: (ev)=> {
                if (ev.title.search('DINNER') > -1) ev.symbol	 = ['fluent-color:food-28']
                if (ev.title.search('Arnold') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                if (ev.title.search('Gus') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                if (ev.title.search('Dogs') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                if (ev.title.search('dogs') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                if (ev.title.search('Marcus') > -1) ev.symbol	 = ['noto:pretzel']
                if (ev.title.search('Pretzel') > -1) ev.symbol	 = ['noto:pretzel']
                if (ev.title.search('Recycle Bin') > -1) ev.symbol	 = ['game-icons:soda-bottle']
                if (ev.title.search('Green Waste bins') > -1) ev.symbol	 = ['streamline-emojis:leaf-fluttering-in-wind']
                if (ev.title.search('Cleaning Day') > -1) ev.symbol	 = ['openmoji:broom']
                if (ev.title.search('Swimming') > -1) ev.symbol	 = ['fxemoji:swimming']
                if (ev.title.search('Phils') > -1) ev.symbol	 = ['twemoji:baby-angel-light-skin-tone']
                if (ev.title.search('Phyllis') > -1) ev.symbol	 = ['twemoji:baby-angel-light-skin-tone']
                if (ev.title.search('Birthday') > -1) ev.symbol	 = ['emojione:birthday-cake']
                if (ev.title.search('birthday') > -1) ev.symbol	 = ['emojione:birthday-cake']
                if (ev.title.search('Hugo') > -1) ev.symbol	 = ['cryptocurrency-color:hight']
                if (ev.title.search('Maggie') > -1) ev.symbol	 = ['cryptocurrency-color:xmy']
                if (ev.title.search('Lucas') > -1) ev.symbol	 = ['openmoji:man-judge-light-skin-tone']
                if (ev.title.search('Hudge') > -1) ev.symbol	 = ['twemoji:gemini']
                if (ev.title.search('Danielle') > -1) ev.symbol	 = ['twemoji:gemini']
                return ev
              			module: "weather",
              				weatherProvider: "openmeteo",
              				type: "current",
              				lat: 40.776676,
              				lon: -73.971321
              			module: "weather",
              			header: "Weather Forecast",
              				type: "forecast",
              				lat: 40.776676,
              				lon: -73.971321
               module: "MMM-ImagesPhotos",
               position: "top_center",
                opacity: 0.9,
                animationSpeed: 1000,
                updateInterval: 5000,
                maxHeight: "500px",
                maxWidth:"500px",
                sequential: false  // process the image list randomly
                    module: "MMM-OpenWeatherMapForecast",
                    header: "Weather",
                    classes: "default everyone",
                      apikey: "cfb4187b9743b212915c5438d685f778",
                      latitude: "-38.314560",
                      longitude: "146.419373",
                      iconset: "4c",
                      concise: false,
                      forecastLayout: "table",
                      showDailyForecast: true,
                      maxDailiesToShow: 5,
                      showHourlyForecast: false,
                      showWind: false
              			module: "newsfeed",
              				feeds: [
              						title: "New York Times",
              						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
              				showSourceTitle: true,
              				showPublishDate: true,
              				broadcastNewsFeeds: true,
              				broadcastNewsUpdates: true
                sdetweil @MDWEBB
                @MDWEBB ok
                two things
                if you comment out a module in config. js with block comment markrrs /* */ then must get the opening and closing braces too
                a better way is just to add
                disabled: true,
                after the module:… line
                chsnge back to false to re-enable the module
                second
                can you show me the output of
                git branch
                  MDWEBB @sdetweil
                  @sdetweil thanks for the repy, i will make the changes to the commenting out the modules using your advice. output for git branch below
                  mdwebb@raspberrypi:~ $ cd ~/MagicMirror
                  git branch
                    _fix_clipping
                    develop
                  * master
                    sdetweil @MDWEBB
                    @MDWEBB said in Version 2.30.0 Calendar fix for clipping broadcast events:
                    _fix_clipping
                    you need to be on _fix_clipping
                    do
                    git switch _fix_clipping
                    if you get package-lock.json would be overwritten
                    do
                    rm package-lock.json
                    the do the switch again
                    and then
                    npm run install-mm
                    B M 2 Replies Last reply Reply Quote 1
                      bruces2 @sdetweil
                      update worked for me…
                        MDWEBB @sdetweil
                        @sdetweil Hi Sam,
                        Performed checks and changes as requested ensured i was on _fix_clipping then ran the install and still am not getting the events data. See log of each step below. Also included updated config file just in case. Sorry to pester just really like the module.
                        mdwebb@raspberrypi:~/MagicMirror $ git switch _fix_clipping
                        M	css/main.css
                        Already on '_fix_clipping'
                        mdwebb@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
                        npm run install-mm
                        > magicmirror@2.31.0-develop install-mm
                        > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                        > magicmirror@2.31.0-develop postinstall
                        > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                        > magicmirror@2.31.0-develop install-vendor
                        > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                        up to date in 1s
                        > magicmirror@2.31.0-develop install-fonts
                        > echo "Installing fonts ...
                        > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                        up to date in 1s
                        > magicmirror@2.31.0-develop prepare
                        > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                        no husky installed.
                        up to date in 9s
                        > magicmirror@2.31.0-develop start
                        > npm run start:x11
                        > magicmirror@2.31.0-develop start:x11
                        [2025-01-08 19:56:04.602] [LOG]   Starting MagicMirror: v2.31.0-develop
                        [2025-01-08 19:56:04.630] [LOG]   Loading config ...
                        [2025-01-08 19:56:04.632] [LOG]   config template file not exists, no envsubst
                        [2025-01-08 19:56:05.150] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
                        [2025-01-08 19:56:05.263] [INFO]  Your configuration file doesn't contain syntax errors :)
                        [2025-01-08 19:56:05.264] [INFO]  Checking modules structure configuration ...
                        [2025-01-08 19:56:05.380] [ERROR] This module configuration contains errors:
                        [2025-01-08 19:56:05.382] [WARN]  No module name found for this configuration:
                        [2025-01-08 19:56:05.383] [WARN]  No module name found for this configuration:
                        [2025-01-08 19:56:05.384] [LOG]   Loading module helpers ...
                        [2025-01-08 19:56:05.391] [LOG]   Initializing new module helper ...
                        [2025-01-08 19:56:05.392] [LOG]   Module helper loaded: updatenotification
                        [2025-01-08 19:56:05.393] [LOG]   No helper found for module: clock.
                        [2025-01-08 19:56:05.527] [LOG]   Initializing new module helper ...
                        [2025-01-08 19:56:05.527] [LOG]   Module helper loaded: calendar
                        [2025-01-08 19:56:05.529] [LOG]   No helper found for module: MMM-CalendarExt3.
                        [2025-01-08 19:56:05.726] [LOG]   Initializing new module helper ...
                        [2025-01-08 19:56:05.727] [LOG]   Module helper loaded: MMM-ImagesPhotos
                        [2025-01-08 19:56:05.743] [LOG]   Initializing new module helper ...
                        [2025-01-08 19:56:05.744] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                        [2025-01-08 19:56:05.744] [LOG]   All module helpers loaded.
                        [2025-01-08 19:56:05.754] [LOG]   Starting server on port 8080 ...
                        [2025-01-08 19:56:06.763] [LOG]   Server started ...
                        [2025-01-08 19:56:06.764] [LOG]   Connecting socket for: updatenotification
                        [2025-01-08 19:56:06.766] [LOG]   Starting module helper: updatenotification
                        [2025-01-08 19:56:06.767] [LOG]   Connecting socket for: calendar
                        [2025-01-08 19:56:06.768] [LOG]   Starting node helper for: calendar
                        [2025-01-08 19:56:06.769] [LOG]   Connecting socket for: MMM-ImagesPhotos
                        [2025-01-08 19:56:06.771] [LOG]   Starting node helper for: MMM-ImagesPhotos
                        [2025-01-08 19:56:06.772] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                        [2025-01-08 19:56:06.777] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
                        [2025-01-08 19:56:06.778] [LOG]   Sockets connected & modules started ...
                        [2025-01-08 19:56:07.134] [LOG]   Launching application.
                        [2025-01-08 19:56:08.242] [INFO]  System information:
                        [2957:0108/195608.659832:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.660229:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.660540:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.660650:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.660812:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.660910:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.661069:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.661161:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.661311:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.661411:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.661563:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.661654:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.661802:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.661894:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.663097:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.663239:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.663417:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.663539:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.663700:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.663793:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.663943:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.664034:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.664181:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.664271:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.664418:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.664510:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2957:0108/195608.664658:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                        [2957:0108/195608.664748:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                        [2025-01-08 19:56:09.808] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics - Interval: 3600000
                        [2025-01-08 19:56:09.886] [LOG]   Config based debug=module_6_MMM-ImagesPhotos
                        [2025-01-08 19:56:09.894] [INFO]  updatenotification: Updater Class Loaded!
                        [2025-01-08 19:56:09.895] [INFO]  updatenotification: Checking PM2 using...
                        [2025-01-08 19:56:09.895] [INFO]  updatenotification: [PM2] You are not using pm2
                        [2025-01-08 19:56:09.896] [INFO]  Checking git for module: MMM-CalendarExt3
                        [2025-01-08 19:56:09.919] [INFO]  Checking git for module: MMM-ImagesPhotos
                        [2025-01-08 19:56:09.939] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                        [2025-01-08 19:56:09.970] [INFO]  Checking git for module: MagicMirror
                        [2025-01-08 19:56:16.687] [INFO]  Calendar-Fetcher: Broadcasting 951 events from https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics.
                        [2025-01-08 19:56:24.651] [LOG]   Shutting down server...
                        [2025-01-08 19:56:24.653] [LOG]   Stopping module helper: updatenotification
                        [2025-01-08 19:56:24.656] [LOG]   Stopping module helper: calendar
                        [2025-01-08 19:56:24.657] [LOG]   Stopping module helper: MMM-ImagesPhotos
                        [2025-01-08 19:56:24.658] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
                        [2025-01-08 19:56:24.659] [LOG]   Node_helpers stopped ...
                        let config = {
                        	address: "localhost",	// Address to listen on, can be:
                        	port: 8080,
                        	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
                        	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
                        	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                        	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                        	language: "en",
                        	locale: "en-US",
                        	timeFormat: 24,
                        	units: "metric",
                        			module: "alert",
                        			module: "updatenotification",
                        			position: "top_bar"
                        			module: "clock",
                        			position: "top_left"
                        			header: "Webb's",
                        			//position: "top_left",
                        						symbol: "calendar-check",
                        						url: "https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/public/basic.ics"
                                url: "https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics",
                          title: "",
                            mode: "week",
                            locale: 'en-US',
                            maxEventLines: 6,
                            firstDayOfWeek: 0,
                            calendarSet: [],
                            weekIndex: 0,
                            weeksInView: 4,
                            useMarquee: true,
                          return ev
                        			module: "weather",
                        			disabled: true,
                        				type: "current",
                        				lat: 40.776676,
                        				lon: -73.971321
                        			module: "weather",
                        			disabled: true,
                        				type: "forecast",
                        				lat: 40.776676,
                        				lon: -73.971321
                          opacity: 0.9,
                          maxHeight: "500px",
                          maxWidth:"500px",
                              header: "Weather",
                                iconset: "4c",
                                concise: false,
                                showWind: false
                        			module: "newsfeed",
                        			disabled: true,
                        				feeds: [
                          djkleric @sdetweil
                          @sdetweil Thank you, after a few things I was able to get it working. I was not able to get it to work on the rp 3b but was able to get it working on the rp5. Appreciate you.
                            sdetweil @MDWEBB
                              	header: "Webb's",
                            this creates an empty module, why you got the
                            @MDWEBB said in [Version 2\.30\.0 Calendar fix for clipping broadcast events](/post/122771):
                            errors
                            what do you mean not working on pi 3?
                              MDWEBB @sdetweil
                              @sdetweil thanks removing this module has cleared the error on boot however still not having any lucky with events broadcasting for CalendarExt3
                              > npm run start:x11
                              [2025-01-09 08:18:52.543] [LOG]   Starting MagicMirror: v2.31.0-develop
                              [2025-01-09 08:18:52.572] [LOG]   Loading config ...
                              [2025-01-09 08:18:52.575] [LOG]   config template file not exists, no envsubst
                              [2025-01-09 08:18:53.097] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
                              [2025-01-09 08:18:53.206] [INFO]  Your configuration file doesn't contain syntax errors :)
                              [2025-01-09 08:18:53.208] [INFO]  Checking modules structure configuration ...
                              [2025-01-09 08:18:53.324] [INFO]  Your modules structure configuration doesn't contain errors :)
                              [2025-01-09 08:18:53.327] [LOG]   Loading module helpers ...
                              [2025-01-09 08:18:53.329] [LOG]   No helper found for module: alert.
                              [2025-01-09 08:18:53.336] [LOG]   Initializing new module helper ...
                              [2025-01-09 08:18:53.337] [LOG]   Module helper loaded: updatenotification
                              [2025-01-09 08:18:53.338] [LOG]   No helper found for module: clock.
                              [2025-01-09 08:18:53.474] [LOG]   Initializing new module helper ...
                              [2025-01-09 08:18:53.474] [LOG]   Module helper loaded: calendar
                              [2025-01-09 08:18:53.476] [LOG]   No helper found for module: MMM-CalendarExt3.
                              [2025-01-09 08:18:53.674] [LOG]   Initializing new module helper ...
                              [2025-01-09 08:18:53.675] [LOG]   Module helper loaded: MMM-ImagesPhotos
                              [2025-01-09 08:18:53.693] [LOG]   Initializing new module helper ...
                              [2025-01-09 08:18:53.694] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                              [2025-01-09 08:18:53.694] [LOG]   All module helpers loaded.
                              [2025-01-09 08:18:53.704] [LOG]   Starting server on port 8080 ...
                              [2025-01-09 08:18:54.652] [LOG]   Server started ...
                              [2025-01-09 08:18:54.653] [LOG]   Connecting socket for: updatenotification
                              [2025-01-09 08:18:54.655] [LOG]   Starting module helper: updatenotification
                              [2025-01-09 08:18:54.656] [LOG]   Connecting socket for: calendar
                              [2025-01-09 08:18:54.657] [LOG]   Starting node helper for: calendar
                              [2025-01-09 08:18:54.658] [LOG]   Connecting socket for: MMM-ImagesPhotos
                              [2025-01-09 08:18:54.659] [LOG]   Starting node helper for: MMM-ImagesPhotos
                              [2025-01-09 08:18:54.660] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                              [2025-01-09 08:18:54.661] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
                              [2025-01-09 08:18:54.662] [LOG]   Sockets connected & modules started ...
                              [2025-01-09 08:18:55.059] [LOG]   Launching application.
                              [2025-01-09 08:18:56.218] [INFO]  System information:
                              [5307:0109/081856.487945:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.488320:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.488591:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.488693:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.488880:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.488963:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.489136:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.489218:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.489384:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.489472:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.489641:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.489720:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.489884:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.489962:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.491709:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.491833:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.492011:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.492121:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.492294:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.492377:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.492540:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.492619:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.492789:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.492880:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.493063:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.493142:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [5307:0109/081856.493306:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                              [5307:0109/081856.493385:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                              [2025-01-09 08:18:57.750] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics - Interval: 3600000
                              [2025-01-09 08:18:57.799] [LOG]   Config based debug=module_7_MMM-ImagesPhotos
                              [2025-01-09 08:18:57.807] [INFO]  updatenotification: Updater Class Loaded!
                              [2025-01-09 08:18:57.808] [INFO]  updatenotification: Checking PM2 using...
                              [2025-01-09 08:18:57.809] [INFO]  updatenotification: [PM2] You are not using pm2
                              [2025-01-09 08:18:57.811] [INFO]  Checking git for module: MMM-CalendarExt3
                              [2025-01-09 08:18:57.834] [INFO]  Checking git for module: MMM-ImagesPhotos
                              [2025-01-09 08:18:57.857] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                              [2025-01-09 08:18:57.889] [INFO]  Checking git for module: MagicMirror
                              [2025-01-09 08:19:03.894] [INFO]  Calendar-Fetcher: Broadcasting 953 events from https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics.
                              [2025-01-09 08:19:15.083] [LOG]   Shutting down server...
                              [2025-01-09 08:19:15.084] [LOG]   Stopping module helper: updatenotification
                              [2025-01-09 08:19:15.085] [LOG]   Stopping module helper: calendar
                              [2025-01-09 08:19:15.086] [LOG]   Stopping module helper: MMM-ImagesPhotos
                              [2025-01-09 08:19:15.087] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
                              [2025-01-09 08:19:15.090] [LOG]   Node_helpers stopped ...
                                sdetweil @MDWEBB
                                @MDWEBB says it broadcast over 900 events
                                there is an Ext3 function for seeing all the events, maybe check there to see if its called, dont see why not
                                  MDWEBB @sdetweil
                                  @sdetweil Thanks for all the help i was able to get it working. Removed the extra module and then it was actually only bringing events in after the first refresh interval of the module, which was odd as it usually brought them in upon start up but is operating fine now.
                                    sdetweil @MDWEBB
                                    @MDWEBB i think this is a timing thing
                                    you could try changing these two config parameters
                                    waitFetch and refreshInterval
                                      angeliKITTYx
                                      @sdetweil i ran the commands in your post, but now everything is totally broken…
                                      This is the beginning of what it gives me. I can’t even launch MM now. Do you know what I can do?
                                      burgess@raspberrypi:~/MagicMirror $ git fetch origin pull/3679/head:_fix_clipping
                                      burgess@raspberrypi:~/MagicMirror $ git switch _fix_clipping
                                      Switched to branch '_fix_clipping'
                                      burgess@raspberrypi:~/MagicMirror $ npm run start
                                      > npm run start:x11
                                      App threw an error during load
                                      Error: Cannot find module 'ansis'
                                      Require stack:
                                      - /home/burgess/MagicMirror/js/logger.js
                                      - /home/burgess/MagicMirror/js/app.js
                                      - /home/burgess/MagicMirror/js/electron.js
                                      - /home/burgess/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                          at node:internal/modules/cjs/loader:1084:15
                                          at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
                                          at Module._resolveFilename (/home/burgess/MagicMirror/node_modules/module-alias/index.js:49:29)
                                          at node:internal/modules/cjs/loader:929:27
                                          at Function._load (node:electron/js2c/asar_bundle:2:13327)
                                          at Module.require (node:internal/modules/cjs/loader:1150:19)
                                          at require (node:internal/modules/cjs/helpers:121:18)
                                          at /home/burgess/MagicMirror/js/logger.js:5:19
                                          at Object.<anonymous> (/home/burgess/MagicMirror/js/logger.js:46:2)
                                          at Module._compile (node:internal/modules/cjs/loader:1271:14)
                                          at Object..js (node:internal/modules/cjs/loader:1326:10)
                                          at Module.load (node:internal/modules/cjs/loader:1126:32)
                                          at node:internal/modules/cjs/loader:967:12
                                      A JavaScript error occurred in the main process
                                      Uncaught Exception:
                                      Require stack:
                                      [21857:0111/103910.674526:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.675123:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.675382:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.675579:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.675720:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.675973:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.676145:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.677266:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.677469:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.677676:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.677856:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.677993:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.678216:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [21857:0111/103910.678351:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                        sdetweil @angeliKITTYx
                                        @angeliKITTYx you missed a step
                                        npm run install-mm
                                          sdetweil @MDWEBB
                                          @MDWEBB ok, you didn’t switch to the new branch
                                            angeliKITTYx @sdetweil
                                            @sdetweil Okay, I got MM to launch, but now other modules are broken and the calendar is still a mess. 3 of 7 are showing, and “all day” events are starting at 5AM and go into the next day. The command window says it’s populating x number of events from all 7 calendars, but they’re not showing up.
                                            screenshot every event here is an “all day” event, and 4 of the calendars aren’t showing.
                                            > npm run start:x11
                                            [2025-01-11 13:22:17.187] [LOG]   Starting MagicMirror: v2.31.0-develop
                                            [2025-01-11 13:22:17.225] [LOG]   Loading config ...
                                            [2025-01-11 13:22:17.228] [LOG]   config template file not exists, no envsubst
                                            [2025-01-11 13:22:17.817] [INFO]  Checking config file /home/burgess/MagicMirror/config/config.js ...
                                            [2025-01-11 13:22:17.921] [INFO]  Your configuration file doesn't contain syntax errors :)
                                            [2025-01-11 13:22:17.923] [INFO]  Checking modules structure configuration ...
                                            [2025-01-11 13:22:18.059] [INFO]  Your modules structure configuration doesn't contain errors :)
                                            [2025-01-11 13:22:18.063] [LOG]   Loading module helpers ...
                                            [2025-01-11 13:22:18.064] [LOG]   No helper found for module: alert.
                                            [2025-01-11 13:22:18.076] [LOG]   Initializing new module helper ...
                                            [2025-01-11 13:22:18.077] [LOG]   Module helper loaded: updatenotification
                                            [2025-01-11 13:22:18.079] [LOG]   No helper found for module: clock.
                                            [2025-01-11 13:22:18.080] [LOG]   No helper found for module: weather.
                                            [2025-01-11 13:22:18.090] [LOG]   Initializing new module helper ...
                                            [2025-01-11 13:22:18.091] [LOG]   Module helper loaded: MMM-OnThisDayWikiApi
                                            [2025-01-11 13:22:18.255] [LOG]   Initializing new module helper ...
                                            [2025-01-11 13:22:18.256] [LOG]   Module helper loaded: calendar
                                            [2025-01-11 13:22:18.257] [LOG]   No helper found for module: MMM-CalendarExt3.
                                            [2025-01-11 13:22:18.628] [LOG]   Initializing new module helper ...
                                            [2025-01-11 13:22:18.628] [LOG]   Module helper loaded: MMM-GooglePhotos
                                            [2025-01-11 13:22:18.631] [ERROR] Error when loading MMM-GoogleTasks: Cannot find module 'googleapis'
                                            Require stack:
                                            - /home/burgess/MagicMirror/modules/MMM-GoogleTasks/node_helper.js
                                            [2025-01-11 13:22:18.632] [LOG]   All module helpers loaded.
                                            [2025-01-11 13:22:18.641] [LOG]   Starting server on port 8080 ...
                                            [2025-01-11 13:22:19.595] [LOG]   Server started ...
                                            [2025-01-11 13:22:19.597] [LOG]   Connecting socket for: updatenotification
                                            [2025-01-11 13:22:19.598] [LOG]   Starting module helper: updatenotification
                                            [2025-01-11 13:22:19.599] [LOG]   Connecting socket for: MMM-OnThisDayWikiApi
                                            [2025-01-11 13:22:19.600] [LOG]   Started node_helper.js for MMM-OnThisDayWikiApi.
                                            [2025-01-11 13:22:19.601] [LOG]   Connecting socket for: calendar
                                            [2025-01-11 13:22:19.603] [LOG]   Starting node helper for: calendar
                                            [2025-01-11 13:22:19.604] [LOG]   Connecting socket for: MMM-GooglePhotos
                                            [2025-01-11 13:22:19.607] [LOG]   Sockets connected & modules started ...
                                            [2025-01-11 13:22:19.983] [LOG]   Launching application.
                                            [93585:0111/132221.707589:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.707977:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.708192:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.708280:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.708416:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.708498:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.708623:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.708695:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.708813:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.708894:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.709014:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.709087:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.709205:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.709278:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.710430:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.710527:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.710657:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.710755:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.710925:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.711002:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.711120:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.711194:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.711311:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.711381:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.711495:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.711566:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93585:0111/132221.711682:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93585:0111/132221.711753:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [2025-01-11 13:22:22.891] [INFO]  System information:
                                            ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.31+rpt-rpi-v8
                                            ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                                            [2025-01-11 13:22:24.539] [LOG]   MMM-OnThisDayWikiApi node helper received a socket notification: ONTHISDAY_FETCH - Payload: [object Object]
                                            [2025-01-11 13:22:24.541] [LOG]   https://api.wikimedia.org/feed/v1/wikipedia/en/onthisday/selected/01/11
                                            [2025-01-11 13:22:24.645] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics - Interval: 100000
                                            [2025-01-11 13:22:24.651] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics - Interval: 100000
                                            [2025-01-11 13:22:24.654] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics - Interval: 100000
                                            [2025-01-11 13:22:24.657] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics - Interval: 100000
                                            [2025-01-11 13:22:24.660] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics - Interval: 100000
                                            [2025-01-11 13:22:24.663] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics - Interval: 100000
                                            [2025-01-11 13:22:24.670] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics - Interval: 100000
                                            [2025-01-11 13:22:25.240] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                                            [2025-01-11 13:22:25.359] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                                            [2025-01-11 13:22:25.482] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                                            [2025-01-11 13:22:26.506] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                                            [2025-01-11 13:22:26.716] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                                            [2025-01-11 13:22:26.881] [LOG]   OnThisDay-Fetcher: Broadcasting 17 items.
                                            [2025-01-11 13:22:27.087] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                                            [2025-01-11 13:22:30.191] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                                            [2025-01-11 13:24:05.593] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                                            [2025-01-11 13:24:05.647] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                                            [2025-01-11 13:24:05.878] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                                            [2025-01-11 13:24:07.544] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                                            [2025-01-11 13:24:07.870] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                                            [2025-01-11 13:24:07.981] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                                            [2025-01-11 13:24:14.258] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                                            [2025-01-11 13:25:46.035] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                                            [2025-01-11 13:25:46.181] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                                            [2025-01-11 13:25:46.337] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                                            [2025-01-11 13:25:48.631] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                                            [2025-01-11 13:25:48.952] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                                            [2025-01-11 13:25:49.061] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                                            [2025-01-11 13:25:58.216] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                                            [2025-01-11 13:27:26.321] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                                            [2025-01-11 13:27:26.473] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                                            [2025-01-11 13:27:26.572] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                                            [2025-01-11 13:27:29.648] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                                            [2025-01-11 13:27:29.976] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                                            [2025-01-11 13:27:30.093] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                                            [2025-01-11 13:27:42.234] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                                            [2025-01-11 13:28:49.689] [LOG]   Shutting down server...
                                            [2025-01-11 13:28:49.690] [LOG]   Stopping module helper: updatenotification
                                            [2025-01-11 13:28:49.690] [LOG]   Stopping module helper: MMM-OnThisDayWikiApi
                                            [2025-01-11 13:28:49.691] [LOG]   Stopping module helper: calendar
                                            [2025-01-11 13:28:49.691] [LOG]   Node_helpers stopped ...
                                            > npm run start:x11
                                            [2025-01-11 13:33:21.858] [LOG]   Starting MagicMirror: v2.31.0-develop
                                            [2025-01-11 13:33:21.895] [LOG]   Loading config ...
                                            [2025-01-11 13:33:21.898] [LOG]   config template file not exists, no envsubst
                                            [2025-01-11 13:33:22.431] [INFO]  Checking config file /home/burgess/MagicMirror/config/config.js ...
                                            [2025-01-11 13:33:22.540] [INFO]  Your configuration file doesn't contain syntax errors :)
                                            [2025-01-11 13:33:22.541] [INFO]  Checking modules structure configuration ...
                                            [2025-01-11 13:33:22.671] [INFO]  Your modules structure configuration doesn't contain errors :)
                                            [2025-01-11 13:33:22.674] [LOG]   Loading module helpers ...
                                            [2025-01-11 13:33:22.675] [LOG]   No helper found for module: alert.
                                            [2025-01-11 13:33:22.683] [LOG]   Initializing new module helper ...
                                            [2025-01-11 13:33:22.684] [LOG]   Module helper loaded: updatenotification
                                            [2025-01-11 13:33:22.685] [LOG]   No helper found for module: clock.
                                            [2025-01-11 13:33:22.686] [LOG]   No helper found for module: weather.
                                            [2025-01-11 13:33:22.691] [LOG]   Initializing new module helper ...
                                            [2025-01-11 13:33:22.692] [LOG]   Module helper loaded: MMM-OnThisDayWikiApi
                                            [2025-01-11 13:33:22.837] [LOG]   Initializing new module helper ...
                                            [2025-01-11 13:33:22.837] [LOG]   Module helper loaded: calendar
                                            [2025-01-11 13:33:22.839] [LOG]   No helper found for module: MMM-CalendarExt3.
                                            [2025-01-11 13:33:23.047] [LOG]   Initializing new module helper ...
                                            [2025-01-11 13:33:23.047] [LOG]   Module helper loaded: MMM-GooglePhotos
                                            [2025-01-11 13:33:23.049] [ERROR] Error when loading MMM-GoogleTasks: Cannot find module 'googleapis'
                                            Require stack:
                                            [2025-01-11 13:33:23.050] [LOG]   All module helpers loaded.
                                            [2025-01-11 13:33:23.060] [LOG]   Starting server on port 8080 ...
                                            [2025-01-11 13:33:24.093] [LOG]   Server started ...
                                            [2025-01-11 13:33:24.095] [LOG]   Connecting socket for: updatenotification
                                            [2025-01-11 13:33:24.097] [LOG]   Starting module helper: updatenotification
                                            [2025-01-11 13:33:24.098] [LOG]   Connecting socket for: MMM-OnThisDayWikiApi
                                            [2025-01-11 13:33:24.099] [LOG]   Started node_helper.js for MMM-OnThisDayWikiApi.
                                            [2025-01-11 13:33:24.100] [LOG]   Connecting socket for: calendar
                                            [2025-01-11 13:33:24.102] [LOG]   Starting node helper for: calendar
                                            [2025-01-11 13:33:24.103] [LOG]   Connecting socket for: MMM-GooglePhotos
                                            [2025-01-11 13:33:24.105] [LOG]   Sockets connected & modules started ...
                                            [2025-01-11 13:33:24.460] [LOG]   Launching application.
                                            [2025-01-11 13:33:25.918] [INFO]  System information:
                                            [93838:0111/133325.993897:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.994339:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.994652:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.994820:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.995048:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.995175:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.995380:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.995501:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.995702:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.995827:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.996014:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.996128:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.996323:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.996435:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.997768:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.997947:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.998173:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.998331:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.998552:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.998671:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.998903:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.999041:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.999233:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.999339:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.999524:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.999633:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [93838:0111/133325.999822:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                            [93838:0111/133325.999936:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                            [2025-01-11 13:33:27.852] [LOG]   MMM-OnThisDayWikiApi node helper received a socket notification: ONTHISDAY_FETCH - Payload: [object Object]
                                            [2025-01-11 13:33:27.853] [LOG]   https://api.wikimedia.org/feed/v1/wikipedia/en/onthisday/selected/01/11
                                            [2025-01-11 13:33:27.930] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics - Interval: 100000
                                            [2025-01-11 13:33:27.939] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics - Interval: 100000
                                            [2025-01-11 13:33:27.946] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics - Interval: 100000
                                            [2025-01-11 13:33:27.951] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics - Interval: 100000
                                            [2025-01-11 13:33:27.954] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics - Interval: 100000
                                            [2025-01-11 13:33:27.956] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics - Interval: 100000
                                            [2025-01-11 13:33:27.959] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics - Interval: 100000
                                            [2025-01-11 13:33:28.317] [LOG]   OnThisDay-Fetcher: Broadcasting 17 items.
                                            [2025-01-11 13:33:28.772] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                                            [2025-01-11 13:33:28.996] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                                            [2025-01-11 13:33:30.577] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                                            [2025-01-11 13:33:30.690] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                                            [2025-01-11 13:33:30.814] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                                            [2025-01-11 13:33:30.938] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                                            [2025-01-11 13:33:33.617] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                                            [2025-01-11 13:35:09.183] [INFO]  Calendar-Fetcher: Broadcasting 45 events from https://calendar.google.com/calendar/ical/1edbd1beaf928e2704be3df763e9b319577876e1bcb207b7904a9c4f06ffb943%40group.calendar.google.com/private-76c28d9a0ee7ab9f1b64a9d566a850ed/basic.ics.
                                            [2025-01-11 13:35:09.444] [INFO]  Calendar-Fetcher: Broadcasting 17 events from https://calendar.google.com/calendar/ical/f66c575019a70fc8b261642986e5db02b70a923eaa2c24ce3cef72adc9f500c2%40group.calendar.google.com/private-22e483fee9be4ff5c366069093ee2445/basic.ics.
                                            [2025-01-11 13:35:11.698] [INFO]  Calendar-Fetcher: Broadcasting 266 events from https://calendar.google.com/calendar/ical/omtoia6f8j37jran5mb17op4ds%40group.calendar.google.com/private-16234c84cba91dcd115a1520c7d4a6d1/basic.ics.
                                            [2025-01-11 13:35:11.765] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/0b6c8d6f8c3228633df24f5a2e1a82ee6e26fb2f83149c1e7f23db663a1723fc%40group.calendar.google.com/private-b27c85d7ac15b1b3720cbc02b5dc379c/basic.ics.
                                            [2025-01-11 13:35:11.973] [INFO]  Calendar-Fetcher: Broadcasting 18 events from https://calendar.google.com/calendar/ical/0f7edded062436e88c439f02088314c458c640c02e562fb692933af418d0abc4%40group.calendar.google.com/private-e796d5dfb492112678768352ffc3fbb8/basic.ics.
                                            [2025-01-11 13:35:12.072] [INFO]  Calendar-Fetcher: Broadcasting 30 events from https://calendar.google.com/calendar/ical/alec.ricks%40gmail.com/private-1057e398b749e4a4bd8d89428196701d/basic.ics.
                                            [2025-01-11 13:35:17.541] [INFO]  Calendar-Fetcher: Broadcasting 167 events from https://calendar.google.com/calendar/ical/an.jusino%40gmail.com/private-74d08680c977c48e69171dadae3346d1/basic.ics.
                                            [2025-01-11 13:35:56.202] [LOG]   Shutting down server...
                                            [2025-01-11 13:35:56.204] [LOG]   Stopping module helper: updatenotification
                                            [2025-01-11 13:35:56.204] [LOG]   Stopping module helper: MMM-OnThisDayWikiApi
                                            [2025-01-11 13:35:56.204] [LOG]   Stopping module helper: calendar
                                            [2025-01-11 13:35:56.205] [LOG]   Node_helpers stopped ...
                                            • 1 / 4
