    Version 2.30.0 Calendar fix for clipping broadcast events
    67 Posts 10 Posters 44.2k Views 10 Watching
      after installing Jan 1 2025 MM version, events broadcast to MMM-CalendarExt3 are clipped incorrectly
      apply this fix (til next release)
      git fetch origin pull/3679/head:_fix_clipping
      git switch _fix_clipping
      npm run install-mm
      # if you get an error error, rm package-lock.json
      # and repeat the git switch
      restart MM
      this fix has been accepted and added to the next release
      you can use that package instead
      see https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
      to get the develop branch
      #NOTE: using develop requires a new
      npm run install-mm
      absolutely my fault… BUT
      this release has been stable and in test since October… but clearly not enough tested it.
      bugsounetB M D 3 Replies Last reply Reply Quote 1
      • S sdetweil pinned this topic on
        angeliKITTYx @sdetweil
        @sdetweil not sure what happened, but I added events to the calendars that weren’t showing up to try and troubleshoot, and now they’re all populated properly… Thanks for all your help with this. Now it’s on to fixing the weather widget.
        • bugsounetB Offline
          bugsounet Banned @sdetweil
          @sdetweil maybe hotfix needed ?
            sdetweil @bugsounet
            @bugsounet lets get thru this first… (this IS a hotfix)
            only have one feedback so far
            bugsounetB 1 Reply Last reply Reply Quote 0
              @sdetweil ok,… If you think that is an hot fix, not me :/
              I just wish users good luck for the next update.
              why ?
              just because they lost master branch
              bugsounet@PC-Bugsounet:~/MagicMirror$ git branch
              * _fix_clipping
                develop
                master
              so they NEVER have MM v2.31.0, git pull will not works (detached head) :/
              That’s why … maybe hotfix needed (v2.30.1)
                sdetweil @bugsounet
                @bugsounet my script puts it back on the master before the fetch…
                easy man…
                lets work thru the issue first…
                confirm it works
                and then work on how to deploy it
                its not fatal…
                only been a few hours…
                hotfix - provide a way repeatable for customer to get around the problem
                  djkleric
                  Hello, I am new to this. I am not getting my Google calendar to populate in this Module. It is populating in the default calendar.
                  I have tried the above but when I try the switch, terminal gives an error. Your local changes to the files would be overwritten by checkout. Package-lock.json
                  Please commit your changes or stash them before you switch branches. Sorry for the newb inquiry.
                    sdetweil @djkleric
                    @djkleric erase
                    rm package-lock.sjon
                      MDWEBB @sdetweil
                      @sdetweil I have tried to apply your fix as mentioned however i am still not getting events to populate in the MMM-CalendarExt3 module.
                      I have also uninstalled and reinstalled the module entirely hoping that would help. Below is my config file and the launch window if that is of any assistance.
                      Any insight would be greatly appreciated.
                      mdwebb@raspberrypi:~/MagicMirror $ npm start
                      > magicmirror@2.30.0 start
                      > npm run start:x11
                      > magicmirror@2.30.0 start:x11
                      [2025-01-07 22:00:29.574] [LOG]   Starting MagicMirror: v2.30.0
                      [2025-01-07 22:00:29.602] [LOG]   Loading config ...
                      [2025-01-07 22:00:29.604] [LOG]   config template file not exists, no envsubst
                      [2025-01-07 22:00:30.136] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
                      [2025-01-07 22:00:30.241] [INFO]  Your configuration file doesn't contain syntax errors :)
                      [2025-01-07 22:00:30.242] [INFO]  Checking modules structure configuration ...
                      [2025-01-07 22:00:30.369] [ERROR] This module configuration contains errors:
                      {}must have required property 'module'
                      [2025-01-07 22:00:30.372] [WARN]  No module name found for this configuration:
                      [2025-01-07 22:00:30.373] [WARN]  No module name found for this configuration:
                      [2025-01-07 22:00:30.374] [WARN]  No module name found for this configuration:
                      [2025-01-07 22:00:30.375] [LOG]   Loading module helpers ...
                      [2025-01-07 22:00:30.382] [LOG]   Initializing new module helper ...
                      [2025-01-07 22:00:30.383] [LOG]   Module helper loaded: updatenotification
                      [2025-01-07 22:00:30.384] [LOG]   No helper found for module: clock.
                      [2025-01-07 22:00:30.519] [LOG]   Initializing new module helper ...
                      [2025-01-07 22:00:30.520] [LOG]   Module helper loaded: calendar
                      [2025-01-07 22:00:30.521] [LOG]   No helper found for module: MMM-CalendarExt3.
                      [2025-01-07 22:00:30.728] [LOG]   Initializing new module helper ...
                      [2025-01-07 22:00:30.729] [LOG]   Module helper loaded: MMM-ImagesPhotos
                      [2025-01-07 22:00:30.745] [LOG]   Initializing new module helper ...
                      [2025-01-07 22:00:30.745] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                      [2025-01-07 22:00:30.746] [LOG]   All module helpers loaded.
                      [2025-01-07 22:00:30.755] [LOG]   Starting server on port 8080 ...
                      [2025-01-07 22:00:31.931] [LOG]   Server started ...
                      [2025-01-07 22:00:31.933] [LOG]   Connecting socket for: updatenotification
                      [2025-01-07 22:00:31.935] [LOG]   Starting module helper: updatenotification
                      [2025-01-07 22:00:31.936] [LOG]   Connecting socket for: calendar
                      [2025-01-07 22:00:31.937] [LOG]   Starting node helper for: calendar
                      [2025-01-07 22:00:31.938] [LOG]   Connecting socket for: MMM-ImagesPhotos
                      [2025-01-07 22:00:31.939] [LOG]   Starting node helper for: MMM-ImagesPhotos
                      [2025-01-07 22:00:31.940] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                      [2025-01-07 22:00:31.941] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
                      [2025-01-07 22:00:31.942] [LOG]   Sockets connected & modules started ...
                      [2025-01-07 22:00:32.295] [LOG]   Launching application.
                      [2025-01-07 22:00:33.385] [INFO]  System information:
                      ### SYSTEM:   manufacturer: ; model: ; virtual: false
                      ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
                      ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                      ### OTHER:    timeZone: Australia/Melbourne; ELECTRON_ENABLE_GPU: undefined
                      [27507:0107/220033.757928:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.758396:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.758713:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.758828:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.759036:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.759137:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.759325:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.759425:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.759614:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.759757:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.759944:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.760042:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.760230:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.760324:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.761815:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.761940:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.762133:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.762305:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.762519:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.762618:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.762804:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.762901:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.763080:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.763176:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.763360:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.763453:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [27507:0107/220033.763639:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                      [27507:0107/220033.763743:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [2025-01-07 22:00:34.946] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics - Interval: 3600000
                      [2025-01-07 22:00:35.004] [LOG]   Config based debug=module_4_MMM-ImagesPhotos
                      [2025-01-07 22:00:35.017] [INFO]  updatenotification: Updater Class Loaded!
                      [2025-01-07 22:00:35.018] [INFO]  updatenotification: Checking PM2 using...
                      [2025-01-07 22:00:35.019] [INFO]  updatenotification: [PM2] You are not using pm2
                      [2025-01-07 22:00:35.020] [INFO]  Checking git for module: MMM-CalendarExt3
                      [2025-01-07 22:00:35.061] [INFO]  Checking git for module: MMM-ImagesPhotos
                      [2025-01-07 22:00:35.094] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                      [2025-01-07 22:00:35.121] [INFO]  Checking git for module: MagicMirror
                      [2025-01-07 22:00:41.687] [INFO]  Calendar-Fetcher: Broadcasting 948 events from https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics.
                      [2025-01-07 22:00:45.074] [LOG]   Shutting down server...
                      [2025-01-07 22:00:45.075] [LOG]   Stopping module helper: updatenotification
                      [2025-01-07 22:00:45.076] [LOG]   Stopping module helper: calendar
                      [2025-01-07 22:00:45.076] [LOG]   Stopping module helper: MMM-ImagesPhotos
                      [2025-01-07 22:00:45.076] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
                      [2025-01-07 22:00:45.077] [LOG]   Node_helpers stopped ...
                          broadcastPastEvents: true, // <= IMPORTANT to see past events
                              url: "https://calendar.google.com/calendar/ical/",
                              name: "us_holiday", // <= RECOMMENDED to assign name
                              color: "red", // <= RECOMMENDED to assign color
                              defaultSymbolClassName: "",
                        module: "MMM-CalendarExt3",
                        position: "bottom_bar",
                        title: "",
                          mode: "week",
                          instanceId: "basicCalendar",
                          locale: 'en-US',
                          maxEventLines: 6,
                          firstDayOfWeek: 0,
                          calendarSet: [],
                          weekIndex: 0,
                          weeksInView: 4,
                          eventHeight: '15px',
                          useMarquee: true,
                          eventTransformer: (ev)=> {
                        if (ev.title.search('DINNER') > -1) ev.symbol	 = ['fluent-color:food-28']
                        if (ev.title.search('Arnold') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                        if (ev.title.search('Gus') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                        if (ev.title.search('Dogs') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                        if (ev.title.search('dogs') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                        if (ev.title.search('Marcus') > -1) ev.symbol	 = ['noto:pretzel']
                        if (ev.title.search('Pretzel') > -1) ev.symbol	 = ['noto:pretzel']
                        if (ev.title.search('Recycle Bin') > -1) ev.symbol	 = ['game-icons:soda-bottle']
                        if (ev.title.search('Green Waste bins') > -1) ev.symbol	 = ['streamline-emojis:leaf-fluttering-in-wind']
                        if (ev.title.search('Cleaning Day') > -1) ev.symbol	 = ['openmoji:broom']
                        if (ev.title.search('Swimming') > -1) ev.symbol	 = ['fxemoji:swimming']
                        if (ev.title.search('Phils') > -1) ev.symbol	 = ['twemoji:baby-angel-light-skin-tone']
                        if (ev.title.search('Phyllis') > -1) ev.symbol	 = ['twemoji:baby-angel-light-skin-tone']
                        if (ev.title.search('Birthday') > -1) ev.symbol	 = ['emojione:birthday-cake']
                        if (ev.title.search('birthday') > -1) ev.symbol	 = ['emojione:birthday-cake']
                        if (ev.title.search('Hugo') > -1) ev.symbol	 = ['cryptocurrency-color:hight']
                        if (ev.title.search('Maggie') > -1) ev.symbol	 = ['cryptocurrency-color:xmy']
                        if (ev.title.search('Lucas') > -1) ev.symbol	 = ['openmoji:man-judge-light-skin-tone']
                        if (ev.title.search('Hudge') > -1) ev.symbol	 = ['twemoji:gemini']
                        if (ev.title.search('Danielle') > -1) ev.symbol	 = ['twemoji:gemini']
                        return ev
                      			module: "weather",
                      				weatherProvider: "openmeteo",
                      				type: "current",
                      				lat: 40.776676,
                      				lon: -73.971321
                      			module: "weather",
                      			header: "Weather Forecast",
                      				type: "forecast",
                      				lat: 40.776676,
                      				lon: -73.971321
                       module: "MMM-ImagesPhotos",
                       position: "top_center",
                        opacity: 0.9,
                        animationSpeed: 1000,
                        updateInterval: 5000,
                        maxHeight: "500px",
                        maxWidth:"500px",
                        sequential: false  // process the image list randomly
                            module: "MMM-OpenWeatherMapForecast",
                            header: "Weather",
                            classes: "default everyone",
                              apikey: "cfb4187b9743b212915c5438d685f778",
                              latitude: "-38.314560",
                              longitude: "146.419373",
                              iconset: "4c",
                              concise: false,
                              forecastLayout: "table",
                              showDailyForecast: true,
                              maxDailiesToShow: 5,
                              showHourlyForecast: false,
                              showWind: false
                      			module: "newsfeed",
                      				feeds: [
                      						title: "New York Times",
                      						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                      				showSourceTitle: true,
                      				showPublishDate: true,
                      				broadcastNewsFeeds: true,
                      				broadcastNewsUpdates: true
                        sdetweil @MDWEBB
                        @MDWEBB ok
                        two things
                        if you comment out a module in config. js with block comment markrrs /* */ then must get the opening and closing braces too
                        a better way is just to add
                        disabled: true,
                        after the module:… line
                        chsnge back to false to re-enable the module
                        second
                        can you show me the output of
                        git branch
                          MDWEBB @sdetweil
                          @sdetweil thanks for the repy, i will make the changes to the commenting out the modules using your advice. output for git branch below
                          mdwebb@raspberrypi:~ $ cd ~/MagicMirror
                          git branch
                            _fix_clipping
                            develop
                          * master
                            sdetweil @MDWEBB
                            @MDWEBB said in Version 2.30.0 Calendar fix for clipping broadcast events:
                            _fix_clipping
                            you need to be on _fix_clipping
                            do
                            if you get package-lock.json would be overwritten
                            do
                            the do the switch again
                            and then
                            npm run install-mm
                            B M 2 Replies Last reply Reply Quote 1
                              bruces2 @sdetweil
                              update worked for me…
                                MDWEBB @sdetweil
                                @sdetweil Hi Sam,
                                Performed checks and changes as requested ensured i was on _fix_clipping then ran the install and still am not getting the events data. See log of each step below. Also included updated config file just in case. Sorry to pester just really like the module.
                                mdwebb@raspberrypi:~/MagicMirror $ git switch _fix_clipping
                                M	css/main.css
                                Already on '_fix_clipping'
                                mdwebb@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
                                npm run install-mm
                                > magicmirror@2.31.0-develop install-mm
                                > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                                > magicmirror@2.31.0-develop postinstall
                                > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                                > magicmirror@2.31.0-develop install-vendor
                                > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                up to date in 1s
                                > magicmirror@2.31.0-develop install-fonts
                                > echo "Installing fonts ...
                                > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                up to date in 1s
                                > magicmirror@2.31.0-develop prepare
                                > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                                no husky installed.
                                up to date in 9s
                                > magicmirror@2.31.0-develop start
                                > npm run start:x11
                                > magicmirror@2.31.0-develop start:x11
                                [2025-01-08 19:56:04.602] [LOG]   Starting MagicMirror: v2.31.0-develop
                                [2025-01-08 19:56:04.630] [LOG]   Loading config ...
                                [2025-01-08 19:56:04.632] [LOG]   config template file not exists, no envsubst
                                [2025-01-08 19:56:05.150] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
                                [2025-01-08 19:56:05.263] [INFO]  Your configuration file doesn't contain syntax errors :)
                                [2025-01-08 19:56:05.264] [INFO]  Checking modules structure configuration ...
                                [2025-01-08 19:56:05.380] [ERROR] This module configuration contains errors:
                                [2025-01-08 19:56:05.382] [WARN]  No module name found for this configuration:
                                [2025-01-08 19:56:05.383] [WARN]  No module name found for this configuration:
                                [2025-01-08 19:56:05.384] [LOG]   Loading module helpers ...
                                [2025-01-08 19:56:05.391] [LOG]   Initializing new module helper ...
                                [2025-01-08 19:56:05.392] [LOG]   Module helper loaded: updatenotification
                                [2025-01-08 19:56:05.393] [LOG]   No helper found for module: clock.
                                [2025-01-08 19:56:05.527] [LOG]   Initializing new module helper ...
                                [2025-01-08 19:56:05.527] [LOG]   Module helper loaded: calendar
                                [2025-01-08 19:56:05.529] [LOG]   No helper found for module: MMM-CalendarExt3.
                                [2025-01-08 19:56:05.726] [LOG]   Initializing new module helper ...
                                [2025-01-08 19:56:05.727] [LOG]   Module helper loaded: MMM-ImagesPhotos
                                [2025-01-08 19:56:05.743] [LOG]   Initializing new module helper ...
                                [2025-01-08 19:56:05.744] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                                [2025-01-08 19:56:05.744] [LOG]   All module helpers loaded.
                                [2025-01-08 19:56:05.754] [LOG]   Starting server on port 8080 ...
                                [2025-01-08 19:56:06.763] [LOG]   Server started ...
                                [2025-01-08 19:56:06.764] [LOG]   Connecting socket for: updatenotification
                                [2025-01-08 19:56:06.766] [LOG]   Starting module helper: updatenotification
                                [2025-01-08 19:56:06.767] [LOG]   Connecting socket for: calendar
                                [2025-01-08 19:56:06.768] [LOG]   Starting node helper for: calendar
                                [2025-01-08 19:56:06.769] [LOG]   Connecting socket for: MMM-ImagesPhotos
                                [2025-01-08 19:56:06.771] [LOG]   Starting node helper for: MMM-ImagesPhotos
                                [2025-01-08 19:56:06.772] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                                [2025-01-08 19:56:06.777] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
                                [2025-01-08 19:56:06.778] [LOG]   Sockets connected & modules started ...
                                [2025-01-08 19:56:07.134] [LOG]   Launching application.
                                [2025-01-08 19:56:08.242] [INFO]  System information:
                                [2957:0108/195608.659832:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.660229:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.660540:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.660650:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.660812:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.660910:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.661069:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.661161:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.661311:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.661411:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.661563:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.661654:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.661802:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.661894:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.663097:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.663239:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.663417:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.663539:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.663700:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.663793:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.663943:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.664034:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.664181:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.664271:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.664418:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.664510:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2957:0108/195608.664658:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                [2957:0108/195608.664748:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                [2025-01-08 19:56:09.808] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics - Interval: 3600000
                                [2025-01-08 19:56:09.886] [LOG]   Config based debug=module_6_MMM-ImagesPhotos
                                [2025-01-08 19:56:09.894] [INFO]  updatenotification: Updater Class Loaded!
                                [2025-01-08 19:56:09.895] [INFO]  updatenotification: Checking PM2 using...
                                [2025-01-08 19:56:09.895] [INFO]  updatenotification: [PM2] You are not using pm2
                                [2025-01-08 19:56:09.896] [INFO]  Checking git for module: MMM-CalendarExt3
                                [2025-01-08 19:56:09.919] [INFO]  Checking git for module: MMM-ImagesPhotos
                                [2025-01-08 19:56:09.939] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                                [2025-01-08 19:56:09.970] [INFO]  Checking git for module: MagicMirror
                                [2025-01-08 19:56:16.687] [INFO]  Calendar-Fetcher: Broadcasting 951 events from https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics.
                                [2025-01-08 19:56:24.651] [LOG]   Shutting down server...
                                [2025-01-08 19:56:24.653] [LOG]   Stopping module helper: updatenotification
                                [2025-01-08 19:56:24.656] [LOG]   Stopping module helper: calendar
                                [2025-01-08 19:56:24.657] [LOG]   Stopping module helper: MMM-ImagesPhotos
                                [2025-01-08 19:56:24.658] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
                                [2025-01-08 19:56:24.659] [LOG]   Node_helpers stopped ...
                                let config = {
                                	address: "localhost",	// Address to listen on, can be:
                                	port: 8080,
                                	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
                                	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
                                	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                                	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                                	language: "en",
                                	locale: "en-US",
                                	timeFormat: 24,
                                	units: "metric",
                                			module: "alert",
                                			module: "updatenotification",
                                			position: "top_bar"
                                			module: "clock",
                                			position: "top_left"
                                			header: "Webb's",
                                			//position: "top_left",
                                						symbol: "calendar-check",
                                						url: "https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/public/basic.ics"
                                        url: "https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics",
                                  title: "",
                                    mode: "week",
                                    locale: 'en-US',
                                    maxEventLines: 6,
                                    firstDayOfWeek: 0,
                                    calendarSet: [],
                                    weekIndex: 0,
                                    weeksInView: 4,
                                    useMarquee: true,
                                  return ev
                                			module: "weather",
                                			disabled: true,
                                				type: "current",
                                				lat: 40.776676,
                                				lon: -73.971321
                                			module: "weather",
                                			disabled: true,
                                				type: "forecast",
                                				lat: 40.776676,
                                				lon: -73.971321
                                  opacity: 0.9,
                                  maxHeight: "500px",
                                  maxWidth:"500px",
                                      header: "Weather",
                                        iconset: "4c",
                                        concise: false,
                                        showWind: false
                                			module: "newsfeed",
                                			disabled: true,
                                				feeds: [
                                  djkleric @sdetweil
                                  @sdetweil Thank you, after a few things I was able to get it working. I was not able to get it to work on the rp 3b but was able to get it working on the rp5. Appreciate you.
                                    sdetweil @MDWEBB
                                      	header: "Webb's",
                                    this creates an empty module, why you got the
                                    @MDWEBB said in [Version 2\.30\.0 Calendar fix for clipping broadcast events](/post/122771):
                                    errors
                                    what do you mean not working on pi 3?
                                      MDWEBB @sdetweil
                                      @sdetweil thanks removing this module has cleared the error on boot however still not having any lucky with events broadcasting for CalendarExt3
                                      > npm run start:x11
                                      [2025-01-09 08:18:52.543] [LOG]   Starting MagicMirror: v2.31.0-develop
                                      [2025-01-09 08:18:52.572] [LOG]   Loading config ...
                                      [2025-01-09 08:18:52.575] [LOG]   config template file not exists, no envsubst
                                      [2025-01-09 08:18:53.097] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
                                      [2025-01-09 08:18:53.206] [INFO]  Your configuration file doesn't contain syntax errors :)
                                      [2025-01-09 08:18:53.208] [INFO]  Checking modules structure configuration ...
                                      [2025-01-09 08:18:53.324] [INFO]  Your modules structure configuration doesn't contain errors :)
                                      [2025-01-09 08:18:53.327] [LOG]   Loading module helpers ...
                                      [2025-01-09 08:18:53.329] [LOG]   No helper found for module: alert.
                                      [2025-01-09 08:18:53.336] [LOG]   Initializing new module helper ...
                                      [2025-01-09 08:18:53.337] [LOG]   Module helper loaded: updatenotification
                                      [2025-01-09 08:18:53.338] [LOG]   No helper found for module: clock.
                                      [2025-01-09 08:18:53.474] [LOG]   Initializing new module helper ...
                                      [2025-01-09 08:18:53.474] [LOG]   Module helper loaded: calendar
                                      [2025-01-09 08:18:53.476] [LOG]   No helper found for module: MMM-CalendarExt3.
                                      [2025-01-09 08:18:53.674] [LOG]   Initializing new module helper ...
                                      [2025-01-09 08:18:53.675] [LOG]   Module helper loaded: MMM-ImagesPhotos
                                      [2025-01-09 08:18:53.693] [LOG]   Initializing new module helper ...
                                      [2025-01-09 08:18:53.694] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                                      [2025-01-09 08:18:53.694] [LOG]   All module helpers loaded.
                                      [2025-01-09 08:18:53.704] [LOG]   Starting server on port 8080 ...
                                      [2025-01-09 08:18:54.652] [LOG]   Server started ...
                                      [2025-01-09 08:18:54.653] [LOG]   Connecting socket for: updatenotification
                                      [2025-01-09 08:18:54.655] [LOG]   Starting module helper: updatenotification
                                      [2025-01-09 08:18:54.656] [LOG]   Connecting socket for: calendar
                                      [2025-01-09 08:18:54.657] [LOG]   Starting node helper for: calendar
                                      [2025-01-09 08:18:54.658] [LOG]   Connecting socket for: MMM-ImagesPhotos
                                      [2025-01-09 08:18:54.659] [LOG]   Starting node helper for: MMM-ImagesPhotos
                                      [2025-01-09 08:18:54.660] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                                      [2025-01-09 08:18:54.661] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
                                      [2025-01-09 08:18:54.662] [LOG]   Sockets connected & modules started ...
                                      [2025-01-09 08:18:55.059] [LOG]   Launching application.
                                      [2025-01-09 08:18:56.218] [INFO]  System information:
                                      [5307:0109/081856.487945:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.488320:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.488591:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.488693:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.488880:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.488963:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.489136:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.489218:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.489384:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.489472:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.489641:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.489720:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.489884:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.489962:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.491709:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.491833:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.492011:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.492121:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.492294:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.492377:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.492540:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.492619:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.492789:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.492880:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.493063:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.493142:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [5307:0109/081856.493306:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [5307:0109/081856.493385:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [2025-01-09 08:18:57.750] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics - Interval: 3600000
                                      [2025-01-09 08:18:57.799] [LOG]   Config based debug=module_7_MMM-ImagesPhotos
                                      [2025-01-09 08:18:57.807] [INFO]  updatenotification: Updater Class Loaded!
                                      [2025-01-09 08:18:57.808] [INFO]  updatenotification: Checking PM2 using...
                                      [2025-01-09 08:18:57.809] [INFO]  updatenotification: [PM2] You are not using pm2
                                      [2025-01-09 08:18:57.811] [INFO]  Checking git for module: MMM-CalendarExt3
                                      [2025-01-09 08:18:57.834] [INFO]  Checking git for module: MMM-ImagesPhotos
                                      [2025-01-09 08:18:57.857] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                                      [2025-01-09 08:18:57.889] [INFO]  Checking git for module: MagicMirror
                                      [2025-01-09 08:19:03.894] [INFO]  Calendar-Fetcher: Broadcasting 953 events from https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics.
                                      [2025-01-09 08:19:15.083] [LOG]   Shutting down server...
                                      [2025-01-09 08:19:15.084] [LOG]   Stopping module helper: updatenotification
                                      [2025-01-09 08:19:15.085] [LOG]   Stopping module helper: calendar
                                      [2025-01-09 08:19:15.086] [LOG]   Stopping module helper: MMM-ImagesPhotos
                                      [2025-01-09 08:19:15.087] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
                                      [2025-01-09 08:19:15.090] [LOG]   Node_helpers stopped ...
                                        sdetweil @MDWEBB
                                        @MDWEBB says it broadcast over 900 events
                                        there is an Ext3 function for seeing all the events, maybe check there to see if its called, dont see why not
                                          MDWEBB @sdetweil
                                          @sdetweil Thanks for all the help i was able to get it working. Removed the extra module and then it was actually only bringing events in after the first refresh interval of the module, which was odd as it usually brought them in upon start up but is operating fine now.
                                            sdetweil @MDWEBB
                                            @MDWEBB i think this is a timing thing
                                            you could try changing these two config parameters
                                            waitFetch and refreshInterval
                                              angeliKITTYx
                                              @sdetweil i ran the commands in your post, but now everything is totally broken…
                                              This is the beginning of what it gives me. I can’t even launch MM now. Do you know what I can do?
                                              burgess@raspberrypi:~/MagicMirror $ git fetch origin pull/3679/head:_fix_clipping
                                              burgess@raspberrypi:~/MagicMirror $ git switch _fix_clipping
                                              Switched to branch '_fix_clipping'
                                              burgess@raspberrypi:~/MagicMirror $ npm run start
                                              > npm run start:x11
                                              App threw an error during load
                                              Error: Cannot find module 'ansis'
                                              Require stack:
                                              - /home/burgess/MagicMirror/js/logger.js
                                              - /home/burgess/MagicMirror/js/app.js
                                              - /home/burgess/MagicMirror/js/electron.js
                                              - /home/burgess/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                                  at node:internal/modules/cjs/loader:1084:15
                                                  at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
                                                  at Module._resolveFilename (/home/burgess/MagicMirror/node_modules/module-alias/index.js:49:29)
                                                  at node:internal/modules/cjs/loader:929:27
                                                  at Function._load (node:electron/js2c/asar_bundle:2:13327)
                                                  at Module.require (node:internal/modules/cjs/loader:1150:19)
                                                  at require (node:internal/modules/cjs/helpers:121:18)
                                                  at /home/burgess/MagicMirror/js/logger.js:5:19
                                                  at Object.<anonymous> (/home/burgess/MagicMirror/js/logger.js:46:2)
                                                  at Module._compile (node:internal/modules/cjs/loader:1271:14)
                                                  at Object..js (node:internal/modules/cjs/loader:1326:10)
                                                  at Module.load (node:internal/modules/cjs/loader:1126:32)
                                                  at node:internal/modules/cjs/loader:967:12
                                              A JavaScript error occurred in the main process
                                              Uncaught Exception:
                                              Require stack:
                                              [21857:0111/103910.674526:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.675123:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.675382:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.675579:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.675720:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.675973:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.676145:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.677266:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.677469:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.677676:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.677856:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.677993:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.678216:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              [21857:0111/103910.678351:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                                              • 1 / 4
