    Version 2.30.0 Calendar fix for clipping broadcast events
    67 Posts 10 Posters 32.0k Views 10 Watching
    • bugsounetB Offline
      bugsounet Banned @sdetweil
      @sdetweil maybe hotfix needed ?
        sdetweil @bugsounet
        @bugsounet lets get thru this first… (this IS a hotfix)
        only have one feedback so far
        bugsounetB 1 Reply Last reply Reply Quote 0
          @sdetweil ok,… If you think that is an hot fix, not me :/
          I just wish users good luck for the next update.
          why ?
          just because they lost master branch
          bugsounet@PC-Bugsounet:~/MagicMirror$ git branch
          * _fix_clipping
            develop
            master
          so they NEVER have MM v2.31.0, git pull will not works (detached head) :/
          That’s why … maybe hotfix needed (v2.30.1)
            sdetweil @bugsounet
            @bugsounet my script puts it back on the master before the fetch…
            easy man…
            lets work thru the issue first…
            confirm it works
            and then work on how to deploy it
            its not fatal…
            only been a few hours…
            hotfix - provide a way repeatable for customer to get around the problem
              djkleric
              Hello, I am new to this. I am not getting my Google calendar to populate in this Module. It is populating in the default calendar.
              I have tried the above but when I try the switch, terminal gives an error. Your local changes to the files would be overwritten by checkout. Package-lock.json
              Please commit your changes or stash them before you switch branches. Sorry for the newb inquiry.
                sdetweil @djkleric
                @djkleric erase
                rm package-lock.sjon
                  MDWEBB @sdetweil
                  @sdetweil I have tried to apply your fix as mentioned however i am still not getting events to populate in the MMM-CalendarExt3 module.
                  I have also uninstalled and reinstalled the module entirely hoping that would help. Below is my config file and the launch window if that is of any assistance.
                  Any insight would be greatly appreciated.
                  mdwebb@raspberrypi:~/MagicMirror $ npm start
                  > magicmirror@2.30.0 start
                  > npm run start:x11
                  > magicmirror@2.30.0 start:x11
                  [2025-01-07 22:00:29.574] [LOG]   Starting MagicMirror: v2.30.0
                  [2025-01-07 22:00:29.602] [LOG]   Loading config ...
                  [2025-01-07 22:00:29.604] [LOG]   config template file not exists, no envsubst
                  [2025-01-07 22:00:30.136] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
                  [2025-01-07 22:00:30.241] [INFO]  Your configuration file doesn't contain syntax errors :)
                  [2025-01-07 22:00:30.242] [INFO]  Checking modules structure configuration ...
                  [2025-01-07 22:00:30.369] [ERROR] This module configuration contains errors:
                  {}must have required property 'module'
                  [2025-01-07 22:00:30.372] [WARN]  No module name found for this configuration:
                  [2025-01-07 22:00:30.373] [WARN]  No module name found for this configuration:
                  [2025-01-07 22:00:30.374] [WARN]  No module name found for this configuration:
                  [2025-01-07 22:00:30.375] [LOG]   Loading module helpers ...
                  [2025-01-07 22:00:30.382] [LOG]   Initializing new module helper ...
                  [2025-01-07 22:00:30.383] [LOG]   Module helper loaded: updatenotification
                  [2025-01-07 22:00:30.384] [LOG]   No helper found for module: clock.
                  [2025-01-07 22:00:30.519] [LOG]   Initializing new module helper ...
                  [2025-01-07 22:00:30.520] [LOG]   Module helper loaded: calendar
                  [2025-01-07 22:00:30.521] [LOG]   No helper found for module: MMM-CalendarExt3.
                  [2025-01-07 22:00:30.728] [LOG]   Initializing new module helper ...
                  [2025-01-07 22:00:30.729] [LOG]   Module helper loaded: MMM-ImagesPhotos
                  [2025-01-07 22:00:30.745] [LOG]   Initializing new module helper ...
                  [2025-01-07 22:00:30.745] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                  [2025-01-07 22:00:30.746] [LOG]   All module helpers loaded.
                  [2025-01-07 22:00:30.755] [LOG]   Starting server on port 8080 ...
                  [2025-01-07 22:00:31.931] [LOG]   Server started ...
                  [2025-01-07 22:00:31.933] [LOG]   Connecting socket for: updatenotification
                  [2025-01-07 22:00:31.935] [LOG]   Starting module helper: updatenotification
                  [2025-01-07 22:00:31.936] [LOG]   Connecting socket for: calendar
                  [2025-01-07 22:00:31.937] [LOG]   Starting node helper for: calendar
                  [2025-01-07 22:00:31.938] [LOG]   Connecting socket for: MMM-ImagesPhotos
                  [2025-01-07 22:00:31.939] [LOG]   Starting node helper for: MMM-ImagesPhotos
                  [2025-01-07 22:00:31.940] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                  [2025-01-07 22:00:31.941] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
                  [2025-01-07 22:00:31.942] [LOG]   Sockets connected & modules started ...
                  [2025-01-07 22:00:32.295] [LOG]   Launching application.
                  [2025-01-07 22:00:33.385] [INFO]  System information:
                  ### SYSTEM:   manufacturer: ; model: ; virtual: false
                  ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
                  ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                  ### OTHER:    timeZone: Australia/Melbourne; ELECTRON_ENABLE_GPU: undefined
                  [27507:0107/220033.757928:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.758396:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.758713:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.758828:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.759036:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.759137:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.759325:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.759425:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.759614:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.759757:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.759944:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.760042:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.760230:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.760324:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.761815:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.761940:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.762133:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.762305:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.762519:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.762618:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.762804:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.762901:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.763080:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.763176:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.763360:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.763453:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [27507:0107/220033.763639:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [27507:0107/220033.763743:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2025-01-07 22:00:34.946] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics - Interval: 3600000
                  [2025-01-07 22:00:35.004] [LOG]   Config based debug=module_4_MMM-ImagesPhotos
                  [2025-01-07 22:00:35.017] [INFO]  updatenotification: Updater Class Loaded!
                  [2025-01-07 22:00:35.018] [INFO]  updatenotification: Checking PM2 using...
                  [2025-01-07 22:00:35.019] [INFO]  updatenotification: [PM2] You are not using pm2
                  [2025-01-07 22:00:35.020] [INFO]  Checking git for module: MMM-CalendarExt3
                  [2025-01-07 22:00:35.061] [INFO]  Checking git for module: MMM-ImagesPhotos
                  [2025-01-07 22:00:35.094] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                  [2025-01-07 22:00:35.121] [INFO]  Checking git for module: MagicMirror
                  [2025-01-07 22:00:41.687] [INFO]  Calendar-Fetcher: Broadcasting 948 events from https://calendar.google.com/calendar/ical/4efbedad2784375c01feb3efdfc3af1c952bc6855f277cc0ff676a776cb246a2%40group.calendar.google.com/private-1a35a8867b2c1f528e0f8ac9f9fa15ab/basic.ics.
                  [2025-01-07 22:00:45.074] [LOG]   Shutting down server...
                  [2025-01-07 22:00:45.075] [LOG]   Stopping module helper: updatenotification
                  [2025-01-07 22:00:45.076] [LOG]   Stopping module helper: calendar
                  [2025-01-07 22:00:45.076] [LOG]   Stopping module helper: MMM-ImagesPhotos
                  [2025-01-07 22:00:45.076] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
                  [2025-01-07 22:00:45.077] [LOG]   Node_helpers stopped ...
                      broadcastPastEvents: true, // <= IMPORTANT to see past events
                          url: "https://calendar.google.com/calendar/ical/",
                          name: "us_holiday", // <= RECOMMENDED to assign name
                          color: "red", // <= RECOMMENDED to assign color
                          defaultSymbolClassName: "",
                    module: "MMM-CalendarExt3",
                    position: "bottom_bar",
                    title: "",
                      mode: "week",
                      instanceId: "basicCalendar",
                      locale: 'en-US',
                      maxEventLines: 6,
                      firstDayOfWeek: 0,
                      calendarSet: [],
                      weekIndex: 0,
                      weeksInView: 4,
                      eventHeight: '15px',
                      useMarquee: true,
                      eventTransformer: (ev)=> {
                    if (ev.title.search('DINNER') > -1) ev.symbol	 = ['fluent-color:food-28']
                    if (ev.title.search('Arnold') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                    if (ev.title.search('Gus') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                    if (ev.title.search('Dogs') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                    if (ev.title.search('dogs') > -1) ev.symbol	 = ['fluent-emoji-flat:dog']
                    if (ev.title.search('Marcus') > -1) ev.symbol	 = ['noto:pretzel']
                    if (ev.title.search('Pretzel') > -1) ev.symbol	 = ['noto:pretzel']
                    if (ev.title.search('Recycle Bin') > -1) ev.symbol	 = ['game-icons:soda-bottle']
                    if (ev.title.search('Green Waste bins') > -1) ev.symbol	 = ['streamline-emojis:leaf-fluttering-in-wind']
                    if (ev.title.search('Cleaning Day') > -1) ev.symbol	 = ['openmoji:broom']
                    if (ev.title.search('Swimming') > -1) ev.symbol	 = ['fxemoji:swimming']
                    if (ev.title.search('Phils') > -1) ev.symbol	 = ['twemoji:baby-angel-light-skin-tone']
                    if (ev.title.search('Phyllis') > -1) ev.symbol	 = ['twemoji:baby-angel-light-skin-tone']
                    if (ev.title.search('Birthday') > -1) ev.symbol	 = ['emojione:birthday-cake']
                    if (ev.title.search('birthday') > -1) ev.symbol	 = ['emojione:birthday-cake']
                    if (ev.title.search('Hugo') > -1) ev.symbol	 = ['cryptocurrency-color:hight']
                    if (ev.title.search('Maggie') > -1) ev.symbol	 = ['cryptocurrency-color:xmy']
                    if (ev.title.search('Lucas') > -1) ev.symbol	 = ['openmoji:man-judge-light-skin-tone']
                    if (ev.title.search('Hudge') > -1) ev.symbol	 = ['twemoji:gemini']
                    if (ev.title.search('Danielle') > -1) ev.symbol	 = ['twemoji:gemini']
                    return ev
                  			module: "weather",
                  				weatherProvider: "openmeteo",
                  				type: "current",
                  				lat: 40.776676,
                  				lon: -73.971321
                  			module: "weather",
                  			header: "Weather Forecast",
                  				type: "forecast",
                  				lat: 40.776676,
                  				lon: -73.971321
                   module: "MMM-ImagesPhotos",
                   position: "top_center",
                    opacity: 0.9,
                    animationSpeed: 1000,
                    updateInterval: 5000,
                    maxHeight: "500px",
                    maxWidth:"500px",
                    sequential: false  // process the image list randomly
                        module: "MMM-OpenWeatherMapForecast",
                        header: "Weather",
                        classes: "default everyone",
                          apikey: "cfb4187b9743b212915c5438d685f778",
                          latitude: "-38.314560",
                          longitude: "146.419373",
                          iconset: "4c",
                          concise: false,
                          forecastLayout: "table",
                          showDailyForecast: true,
                          maxDailiesToShow: 5,
                          showHourlyForecast: false,
                          showWind: false
                  			module: "newsfeed",
                  				feeds: [
                  						title: "New York Times",
                  						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                  				showSourceTitle: true,
                  				showPublishDate: true,
                  				broadcastNewsFeeds: true,
                  				broadcastNewsUpdates: true
                    sdetweil @MDWEBB
                    @MDWEBB ok
                    two things
                    if you comment out a module in config. js with block comment markrrs /* */ then must get the opening and closing braces too
                    a better way is just to add
                    disabled: true,
                    after the module:… line
                    chsnge back to false to re-enable the module
                    second
                    can you show me the output of
                    git branch
                      MDWEBB @sdetweil
                      @sdetweil thanks for the repy, i will make the changes to the commenting out the modules using your advice. output for git branch below
                      mdwebb@raspberrypi:~ $ cd ~/MagicMirror
                      git branch
                        _fix_clipping
                        develop
                      * master
                        sdetweil @MDWEBB
                        @MDWEBB said in Version 2.30.0 Calendar fix for clipping broadcast events:
                        _fix_clipping
                        you need to be on _fix_clipping
                        do
                        git switch _fix_clipping
                        if you get package-lock.json would be overwritten
                        do
                        rm package-lock.json
                        the do the switch again
                        and then
                        npm run install-mm
                        B M 2 Replies Last reply Reply Quote 1
                        • 1 / 7
