    Failed to get fd for plane and Failed to export buffer to dma_buf errors
    3 Posts 2 Posters 1.8k Views 2 Watching
    • D
      DDE12
      I am trying to get Magic Mirror set up on my new machine with Bookworm installed and am getting numerous errors. MM seems to be running okay with the few modules I have so far. I would appreciate some help correcting these errors if they are a problem. Thanks!
      > magicmirror@2.30.0 start:x11
      [2025-01-18 21:47:08.866] [LOG]   Starting MagicMirror: v2.30.0
      [2025-01-18 21:47:08.930] [LOG]   Loading config ...
      [2025-01-18 21:47:08.935] [LOG]   config template file not exists, no envsubst
      [2025-01-18 21:47:10.116] [INFO]  Checking config file /home/mmuser/MagicMirror/config/config.js ...
      [2025-01-18 21:47:10.390] [INFO]  Your configuration file doesn't contain syntax errors :)
      [2025-01-18 21:47:10.392] [INFO]  Checking modules structure configuration ...
      [2025-01-18 21:47:10.680] [INFO]  Your modules structure configuration doesn't contain errors :)
      [2025-01-18 21:47:10.686] [LOG]   Loading module helpers ...
      [2025-01-18 21:47:14.006] [LOG]   Launching application.
      [24016:0118/214715.118683:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.120260:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.121045:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.121691:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.122798:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.123836:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.124929:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.126185:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.127230:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.128281:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.129560:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.137125:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.138330:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.139359:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.144838:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.147648:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.148735:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.149965:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.151057:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.152118:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.153159:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.154235:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.155276:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.156286:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.157239:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.163090:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [24016:0118/214715.164534:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [24016:0118/214715.166261:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [2025-01-18 21:47:16.078] [INFO]  System information:
      ### SYSTEM:   manufacturer: libre-computer; model: aml-s905x-cc-v2; virtual: false
      ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.1.64-11810-g69b1ffe8ef6c
      ### VERSIONS: electron: 32.2.8; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
      ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
        sdetweil @DDE12
        @DDE12 yes, those are errors put out by the Electron browser library we use… they are just noise, no harmful effects, but we cannot suppress them, or turn them off
        • D
          DDE12
          Thank you! I will try to not lose too much sleep over it. :)
          • D DDE12 has marked this topic as solved on
