MagicMirror not working after upgrade
17 Posts 4 Posters 1.7k Views 4 Watching
  • P Offline
    pat59
    j ai fait la mise a niveau par smartphone RemoteControl.
    patrick@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” forcer
    update log will be in /home/patrick/MagicMirror/installers/upgrade.log
    doing test run = false
    Node currently installed. Checking version number.
    Minimum Node version: v20.18.1
    Installed Node version: v20.9.0
    installing correct version of node and npm, please wait
    Check current Node installation …
    Installed Node version: v20.18.1
    No Node.js upgrade necessary.
    Check current NPM installation …
    NPM currently installed. Checking version number.
    Minimum npm version: V10.8.2
    Installed npm version: V10.8.2
    No npm upgrade necessary.
    saving custom.css
    upgrading from version 2.30.0 to 2.30.0
    fetching latest revisions
    updating MagicMirror runtime, please wait
    magicmirror@2.30.0 postinstall
    npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
    magicmirror@2.30.0 install-vendor
    echo "Installing vendor files …
    " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
    added 1 package, and changed 2 packages in 12s
    magicmirror@2.30.0 install-fonts
    echo "Installing fonts …
    " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
    Installing fonts …
    changed 2 packages in 7s
    magicmirror@2.30.0 prepare
    [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
    no husky installed.
    added 479 packages in 3m
    126 packages are looking for funding
    run npm fund for details
    Checking for modules with removed libraries
    updating dependencies for active modules with package.json files
    processing for module MMM-Remote-Control please wait
    added 49 packages, and audited 50 packages in 9s
    13 packages are looking for funding
    found 0 vulnerabilities
    processing complete for module MMM-Remote-Control
    processing for module MMM-Saint please wait
    astuce: Tirer sans spécifier comment réconcilier les branches divergentes
    astuce: est découragé. Vous pouvez éliminer ce message en lançant une des
    astuce: commandes suivantes avant votre prochain tirage :
    astuce:
    astuce: git config pull.rebase false # fusion (stratégie par défaut)
    astuce: git config pull.rebase true # rebasage
    astuce: git config pull.ff only # avance rapide seulement
    astuce:
    astuce: Vous pouvez remplacer “git config” par “git config --global” pour que
    astuce: ce soit l’option par défaut pour tous les dépôts. Vous pouvez aussi
    astuce: passer --rebase, --no-rebase ou --ff-only sur la ligne de commande pour
    astuce: remplacer à l’invocation la valeur par défaut configurée.
    processing complete for module MMM-Saint
    processing for module MMM-network-signal please wait
    added 1 package, and audited 2 packages in 3s
    processing complete for module MMM-network-signal
    processing for module MMM-FlipClock please wait
    added 1 package, and audited 2 packages in 4s
    processing complete for module MMM-FlipClock
    processing for module MMM-BME280 please wait
    added 1 package, and audited 2 packages in 7s
    processing complete for module MMM-BME280
    processing for module MMM-PrixCarburants please wait
    astuce:
    astuce:
    processing complete for module MMM-PrixCarburants
    processing for module MMM-MeteoFrance please wait
    astuce:
    astuce:
    processing complete for module MMM-MeteoFrance
    processing for module MMM-FranceInfo please wait
    astuce:
    astuce:
    processing complete for module MMM-FranceInfo
    processing for module MMM-SnowEffect please wait
    up to date, audited 1 package in 2s
    processing complete for module MMM-SnowEffect
    restoring custom.css
    S 1 Reply Last reply Jan 22, 2025, 5:27 PM Reply Quote 0
    • S Away
      sdetweil @pat59
      @pat59 bien … vous devriez pouvoir redémarrer MagicMirror maintenant
      cela aurait dû apparaître lors du test
      traitement pour le module MMM-Saint veuillez patienter
      astuce : Tirer sans comment réconcilier les branches divergentes
      Je ne sais pas pourquoi ils ne l’ont pas fait. je vais regarder ça
      Je ne « mets pas à jour » les modules, seulement le MM de base
      S 1 Reply Last reply Jan 22, 2025, 5:33 PM Reply Quote 0
      • S Away
        @pat59 ok, ces erreurs viennent du processus de mise à jour du module, il faudra que l’auteur les regarde
        @bugsounet
        pouvez-vous examiner pourquoi il a eu ces erreurs même si vous avez effectué la réinitialisation matérielle de git ?
        ma mise à niveau appelée npm run update
        bugsounetB 1 Reply Last reply Jan 25, 2025, 10:15 AM Reply Quote 0
        • P Offline
          pat59
          Wahoou je ne sais comment vous remercier cela fonctionne super content encore merci pour votre patience et gentillesse.
          je sais faire la mise a jour d’ un module grace a votre contribution
          mais ne sais pas faire quand il me demande la mise a jour de MagicMirror ?
          je fait par Remote-Control mais je plante toujours le systeme
          en vous remerciant encore pour tout
          S 1 Reply Last reply Jan 22, 2025, 5:50 PM Reply Quote 0
          • S Away
            sdetweil @pat59
            @pat59 >mais je ne sais pas quoi faire quand il me demande de mettre à jour MagicMirror ?
            Je le fais par télécommande mais je plante toujours le système
            exécutez toujours mon script.
            Heureusement que la télécommande vous permet de faire ça.
            sinon vous devrez vous connecter au système MM (ssh ou vnc) pour obtenir une fenêtre de terminal permettant de faire le même copier/coller de ma commande de script de mise à niveau
            vous sauvegardez votre système, n’est-ce pas ?
            sinon voir mes scripts de sauvegarde/restauration
            nous mettons à jour MagicMirror tous les 3 mois. vous n’êtes PAS obligé de prendre ces mises à jour.
            mais il semble que le message disparaisse, vous devez désactiver le module de notification de mise à jour
            ajouter
            désactivé : vrai,
            après l’entrée du nom de son module dans config.js
            • bugsounetB Offline
              bugsounet Banned @sdetweil
              @sdetweil said in MagicMirror not working after upgrade:
              @bugsounet
              Tous mes modules ont été retiré de la liste des modules tiers, et vont être supprimé de mon compte github.
              Je suis désolé @pat59, il donc faudra trouver un/des modules équivalent.
              Comme vous venez de comprendre, je me retire donc du projet MagicMirror² complètement.
              Bonne continuation,
              @bugsounet
              M 1 Reply Last reply Jan 25, 2025, 7:08 PM Reply Quote 0
                margouya @bugsounet
                @bugsounet said in MagicMirror not working after upgrade:
                @bugsounet
                Bonne continuation,
                @bugsounet
                C’est avec regret que j’apprends l’arrêt de votre projet
                J’avais quasi terminé ( tous était installé et presque terminé il me restait juste le token de Google assistant et tout était parfait)a une semaine près sa aurais été fini.
                Pourquoi ne pas avoir laissé les liens github sur le site ?
                C’est bien dommage mais vous avez fait un travail extraordinaire
                Merci encore
                2 / 2
