    MagicMirror not working after upgrade
    17 Posts 4 Posters 4.9k Views 4 Watching
      pat59
      patrick@raspberrypi:~ $ cd ~/install.log
      bash: cd: /home/patrick/install.log: N’est pas un dossier
        pat59
        patrick@raspberrypi:~ $ cd ~/MagicMirror/installers/upgrade.log
        bash: cd: /home/patrick/MagicMirror/installers/upgrade.log: N’est pas un dossier
          pat59
          patrick@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
          $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
          $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
          $$$$$$ $$ | _
          $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
          $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
          $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
          _
          | _
          | _
          | _
          $$ |_| _
          |_| _|_|_| __| _
          / _| _______|
          _
          ____/
          install log being saved to /home/patrick/install.log
          Updating packages …
          Installing helper tools …
          Check current Node installation …
          Minimum Node version: v20.18.1
          Installed Node version: v20.9.0
          Node should be upgraded.
          A Node process is currently running. Can’t upgrade.
          Please quit all Node processes and restart the installer.
          patrick 1987 1972 0 16:19 ? 00:00:00 sh -c DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js patrick 1988 1987 0 16:19 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js patrick 1998 1988 0 16:19 ? 00:00:04 /home/patrick/MagicMirror/node_modules/electron/dist/electron js/electron.js patrick 2001 1998 0 16:19 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox patrick 2002 1998 0 16:19 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote patrick 2004 2002 0 16:19 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote patrick 2040 2001 0 16:19 ? 00:00:01 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=3d6a43f6-4bcd-43f9-87e0-3874dce0da58,no_channel --user-data-dir=/home/patrick/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --shared-files --field-trial-handle=0,i,12195679081471275551,8574617561069742386,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version patrick 2046 1998 0 16:19 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=3d6a43f6-4bcd-43f9-87e0-3874dce0da58,no_channel --user-data-dir=/home/patrick/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,12195679081471275551,8574617561069742386,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version patrick 2070 2040 0 16:20 ? 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=broker patrick 2082 2060 0 16:20 pts/0 00:00:00 sh -c DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js patrick 2083 2082 0 16:20 pts/0 00:00:00 node ./node_modules/.bin/electron js/electron.js patrick 2093 2083 0 16:20 pts/0 00:00:03 /home/patrick/MagicMirror/node_modules/electron/dist/electron js/electron.js patrick 2096 2093 0 16:20 pts/0 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox patrick 2097 2093 0 16:20 pts/0 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote patrick 2099 2097 0 16:20 pts/0 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=zygote patrick 2129 2096 0 16:20 pts/0 00:00:01 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=3d6a43f6-4bcd-43f9-87e0-3874dce0da58,no_channel --user-data-dir=/home/patrick/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --shared-files --field-trial-handle=0,i,3246569436277859428,16865193471212064356,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version patrick 2131 2093 0 16:20 pts/0 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=3d6a43f6-4bcd-43f9-87e0-3874dce0da58,no_channel --user-data-dir=/home/patrick/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,3246569436277859428,16865193471212064356,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version patrick 2138 2129 0 16:20 pts/0 00:00:00 /home/patrick/MagicMirror/node_modules/electron/dist/electron --type=broker
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
          update log will be in /home/patrick/MagicMirror/installers/upgrade.log
          MagicMirror running under control of PM2, stopping
            sdetweil @pat59
            @pat59 said in electron:
            ok, you have install.log (not cd, cat to dump out contents, or nano to edit and view contents)
            you DIDN’T have upgrade.log as you hadn’t run upgrade yet
            things to know
            1. install WILL NOT install OVER an existing MM system… you do NOT need me to screw up your setup
            2. upgrade is dangerous, so I provide TWO paths
              a . test for anything dangerous, lose files, lose changes, whatever … BUT DO NOT CHANGE ANYTHING
              b. EXECUTE the upgrade, make changes,
              the script for 2 (upgrade) is the same for and and b, but no parameters for test, and apply parameter for execute
              (I provide 2 links so you don’t have to remember)
            but, I still don’t know how you got the code installed…
            did you do the manual upgrade attempt first
               git pull && npm run install-mm
            and it failed (cause you don’t have the right version of nodejs installed…)
            SO, there is ONE more step
            copy/paste the execute link
            BUT change the word
            apply
            to
            force
            I don’t document this one as I don’t want people using it accidentally
            now, please excuse my rudeness here… I see french is your native language…, you DO know you can TRANSLATE my module readme page, in the browser, right?
            and if you do so and still don’t understand what I wrote, I am happy to make corrections that would make things more clear. I appreciate your input, I want to make this safe and reliable and easy to use
            we can take that discussion offline. If you write to me in french I will translate and return my response in french
              pat59
              merci pour votre gentillesse je suis novice désolé de prendrez de votre temps encore merci
              voila ce que je viens de faire pour la mise a niveau.
              patrick@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
              Node.js upgrade defered, doing test run
              Check current NPM installation …
              Minimum npm version: V10.8.2
              Installed npm version: V10.1.0
              npm should be upgraded.
              npm upgrade defered, doing test run …
              saving custom.css
              (23) Failed writing body
              upgrading from version 2.30.0 to 2.30.0
              fetching latest revisions
              updating dependencies for active modules with package.json files
              processing for module MMM-Remote-Control please wait
              skipped processing for MMM-Remote-Control, doing test run
              processing complete for module MMM-Remote-Control
              processing for module MMM-Saint please wait
              skipped processing for MMM-Saint, doing test run
              processing complete for module MMM-Saint
              processing for module MMM-network-signal please wait
              skipped processing for MMM-network-signal, doing test run
              processing complete for module MMM-network-signal
              processing for module MMM-FlipClock please wait
              skipped processing for MMM-FlipClock, doing test run
              processing complete for module MMM-FlipClock
              processing for module MMM-BME280 please wait
              skipped processing for MMM-BME280, doing test run
              processing complete for module MMM-BME280
              processing for module MMM-PrixCarburants please wait
              skipped processing for MMM-PrixCarburants, doing test run
              processing complete for module MMM-PrixCarburants
              processing for module MMM-MeteoFrance please wait
              skipped processing for MMM-MeteoFrance, doing test run
              processing complete for module MMM-MeteoFrance
              processing for module MMM-FranceInfo please wait
              skipped processing for MMM-FranceInfo, doing test run
              processing complete for module MMM-FranceInfo
              processing for module MMM-SnowEffect please wait
              skipped processing for MMM-SnowEffect, doing test run
              processing complete for module MMM-SnowEffect
              restoring custom.css
                sdetweil @pat59
                @pat59 c’est à nouveau le test.
                — faire un test = true, AUCUNE mise à jour ne sera appliquée !—
                vous avez besoin de la deuxième URL avec le mot « postuler » à la fin
                et tu dois changer le mot
                ‘appliquer’
                à
                ‘forcer’
                veuillez utiliser les mots anglais ici, le traducteur ne m’a pas donné la possibilité de désactiver cela
                nous sommes tous novices dans beaucoup de choses dans notre vie, nous apprenons tous à notre rythme. J’espère que mes outils nous faciliteront la tâche.
                  pat59
                  j ai fait la mise a niveau par smartphone RemoteControl.
                  patrick@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” forcer
                  doing test run = false
                  installing correct version of node and npm, please wait
                  Installed Node version: v20.18.1
                  No Node.js upgrade necessary.
                  Installed npm version: V10.8.2
                  No npm upgrade necessary.
                  saving custom.css
                  magicmirror@2.30.0 postinstall
                  npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                  magicmirror@2.30.0 install-vendor
                  echo "Installing vendor files …
                  " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                  added 1 package, and changed 2 packages in 12s
                  magicmirror@2.30.0 install-fonts
                  echo "Installing fonts …
                  " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                  Installing fonts …
                  changed 2 packages in 7s
                  magicmirror@2.30.0 prepare
                  [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                  no husky installed.
                  added 479 packages in 3m
                  126 packages are looking for funding
                  run npm fund for details
                  added 49 packages, and audited 50 packages in 9s
                  13 packages are looking for funding
                  found 0 vulnerabilities
                  astuce: Tirer sans spécifier comment réconcilier les branches divergentes
                  astuce: est découragé. Vous pouvez éliminer ce message en lançant une des
                  astuce: commandes suivantes avant votre prochain tirage :
                  astuce:
                  astuce: git config pull.rebase false # fusion (stratégie par défaut)
                  astuce: git config pull.rebase true # rebasage
                  astuce: git config pull.ff only # avance rapide seulement
                  astuce:
                  astuce: Vous pouvez remplacer “git config” par “git config --global” pour que
                  astuce: ce soit l’option par défaut pour tous les dépôts. Vous pouvez aussi
                  astuce: passer --rebase, --no-rebase ou --ff-only sur la ligne de commande pour
                  astuce: remplacer à l’invocation la valeur par défaut configurée.
                  added 1 package, and audited 2 packages in 3s
                  added 1 package, and audited 2 packages in 4s
                  added 1 package, and audited 2 packages in 7s
                  astuce:
                  astuce:
                  astuce:
                  astuce:
                  astuce:
                  astuce:
                  up to date, audited 1 package in 2s
                    sdetweil @pat59
                    @pat59 bien … vous devriez pouvoir redémarrer MagicMirror maintenant
                    cela aurait dû apparaître lors du test
                    traitement pour le module MMM-Saint veuillez patienter
                    astuce : Tirer sans comment réconcilier les branches divergentes
                    Je ne sais pas pourquoi ils ne l’ont pas fait. je vais regarder ça
                    Je ne « mets pas à jour » les modules, seulement le MM de base
                      @pat59 ok, ces erreurs viennent du processus de mise à jour du module, il faudra que l’auteur les regarde
                      @bugsounet
                      pouvez-vous examiner pourquoi il a eu ces erreurs même si vous avez effectué la réinitialisation matérielle de git ?
                      ma mise à niveau appelée npm run update
                      bugsounetB 1 Reply Last reply
                        pat59
                        Wahoou je ne sais comment vous remercier cela fonctionne super content encore merci pour votre patience et gentillesse.
                        je sais faire la mise a jour d’ un module grace a votre contribution
                        mais ne sais pas faire quand il me demande la mise a jour de MagicMirror ?
                        je fait par Remote-Control mais je plante toujours le systeme
                        en vous remerciant encore pour tout
                          sdetweil @pat59
                          @pat59 >mais je ne sais pas quoi faire quand il me demande de mettre à jour MagicMirror ?
                          Je le fais par télécommande mais je plante toujours le système
                          exécutez toujours mon script.
                          Heureusement que la télécommande vous permet de faire ça.
                          sinon vous devrez vous connecter au système MM (ssh ou vnc) pour obtenir une fenêtre de terminal permettant de faire le même copier/coller de ma commande de script de mise à niveau
                          vous sauvegardez votre système, n’est-ce pas ?
                          sinon voir mes scripts de sauvegarde/restauration
                          https://github.com/sdetweil/MagicMirror-backup-restore
                          nous mettons à jour MagicMirror tous les 3 mois. vous n’êtes PAS obligé de prendre ces mises à jour.
                          mais il semble que le message disparaisse, vous devez désactiver le module de notification de mise à jour
                          ajouter
                          désactivé : vrai,
                          après l’entrée du nom de son module dans config.js
                          • bugsounetB
                            bugsounet Banned @sdetweil
                            @sdetweil said in MagicMirror not working after upgrade:
                            @bugsounet
                            Tous mes modules ont été retiré de la liste des modules tiers, et vont être supprimé de mon compte github.
                            Je suis désolé @pat59, il donc faudra trouver un/des modules équivalent.
                            Comme vous venez de comprendre, je me retire donc du projet MagicMirror² complètement.
                            Bonne continuation,
                            @bugsounet
                            M 1 Reply Last reply
                              margouya @bugsounet
                              @bugsounet said in MagicMirror not working after upgrade:
                              @bugsounet
                              Bonne continuation,
                              @bugsounet
                              C’est avec regret que j’apprends l’arrêt de votre projet
                              J’avais quasi terminé ( tous était installé et presque terminé il me restait juste le token de Google assistant et tout était parfait)a une semaine près sa aurais été fini.
                              Pourquoi ne pas avoir laissé les liens github sur le site ?
                              C’est bien dommage mais vous avez fait un travail extraordinaire
                              Merci encore
