    Cannot Find Module ‘ansis’
    6 Posts 2 Posters 1.9k Views 2 Watching
      Splashed
      I have been having some issues with my newsfeed module, so I thought I’d try to update it. That threw an error, so I essentially gave up and just tried to restart my screen.
      Now it won’t start either due to :
      Error: Cannot find module ‘ansis’
      I tried to install a module called ‘ANSIS’ and I get a whole new set of errors:
      Npm err! Code ebadengine
      Nom err! Engine unsupported engine
      Also more about being not compatible with my version
      I have never had or heard of a module called ansis, so I’m pretty stumped on how to fix this issue.
      Google-fu didnt provide any helpful answers, so I come here for guidance.
        sdetweil @Splashed
        @Splashed if you read the page, upgrade is 2 part, two links provided
        part 1
        test, do nothing. find trouble before it happens
        part 2
        DO the upgrade, same command, but has a parameter added at the end
        that parm is
        apply
        BUT , by default, apply will NOT upgrade over the SAME version, trying to prevent you from messing up your system
        so, there is another option in this case,
        change the parm apply to force
        to allow upgrade OVER the same version
          sdetweil @Splashed
          @Splashed you need to have node 20.18.1 or any version 22 and up
          if you run my upgrade script, it will upgrade node too.
          see
          now, because you have pilled the latest code, you need to use the parm
          force
          instead of apply
            Splashed @sdetweil
            I appreciate the speedy help.
            I ran the upgrade script, but Im confused about the second part of your suggestion.
            Can you please elaborate on “you need your use the parm force instead of apply”
            Thanks.
              sdetweil @Splashed
              part 1
              part 2
              that parm is
              apply
                Splashed @sdetweil
                Worked perfectly, thanks for clarifying.
                Can you comment on why me trying to update a module would cause this error to present itself?
                If not, that’s fine too. I appreciate the help.
                  sdetweil @Splashed
                  @Splashed no idea. unless you didn’t get into the module folder before the git pull
                  cd ~/MagicMirror/modules/module_name
