    Help with MMM-ModuleSchedule - not hiding
    11 Posts 2 Posters 3.0k Views 2 Watching
    • C Offline
      cheminge
      I recently tried to install MMM-ModuleScheduler trying to get this suggestion to work:
      seasonal characters
      I tried to follow the documentation online, but I can’t seem to get the MMM-EasyPix to hind until for now, and then show in March.
      This is what I have in my config file:
         {module: 'MMM-ModuleScheduler',
      	{module: "MMM-EasyPix",
      		pages: {"Main Calendar": "top_center"},
      		position: "top_center",
      		classes: "march",
      			module_schedule: {from: '* * 1 3 *', to: '* * * 4 *'}, /* march */
      			picName: "Leprechaun.png",
      			maxWidth: "75%",
      			updateInterval: 30 * 60 * 1000,
      Do I have the config file correct? or is there something else I am missing?
        sdetweil @cheminge
        @cheminge 1st thing is to get easypix to display your image in the right place
        • C Offline
          cheminge @sdetweil
          I did some digging, it seems I had the “classes:” wrong in the first one.
          It needs to be:
          classes: "scheduler",
          So more like this:
          		pages: {"Main Calendar": "bottom_right"},
          		position: "bottom_right",
          			module_schedule: {from: '0 0 1 3 *', to: '59 23 31 3 *'},
          			maxWidth: "75%",
          Now, I can’t get anything to show up unless I take out the “module_schedule” like the code below. when add it back in, nothing shows up.
          With today being January 30th, 2025 this should fall after “from” and before “to”.
          		pages: {"Main Calendar": "top_right"},
          			/*module_schedule: {from: '0 0 1 1 *', to: '59 23 31 1 *'},*/
          			picName: "Yeah_Mon.png",
          			maxWidth: "75%",
          Any suggestions on what else I am missing?
            sdetweil @cheminge
            @cheminge thats crontab type
            0 0 for hour minute means ONLY Then .not 1 min after midnight
            * * 1 1
            means anytime on 1/1
            we support crontab in compliments, and i recommend
            this site to get the 1st 5 tokens like needed here
            https://crontab-generator.org/
            • C Offline
              cheminge @sdetweil
              I have noticed something strange with this module.
              In my log I get this message :
              [2025-02-01 09:42:27.196] [LOG]   MMM-ModuleScheduler is scheduling MMM-EasyPix using "* * 1 1 *" and "59 23 31 1 *" with dim level undefined
              [2025-02-01 09:42:27.206] [WARN]  Month '1' is limited to '29' days.
              February has “29” days. Not January.
              So the month in my config file that I use from “https://crontab.guru/” doesn’t match what you would expect from this scheduler.
              In the documentation it say
              “Months 0-11 (Jan-Dec)”
              I have updated to use this as a key:
              Month
              1 = February
              2= March
              3 = April
              4 = May
              5 = June
              6 = July
              7 = August
              8 = September
              9 = October
              10 = November
              11 = December
              I noticed month “0” doesn’t work for January.
              Now that we are in February, it seems to be working after I set what I want to see in February as the month to be “1”
                sdetweil @cheminge
                @cheminge yes cron uses 0-11 for month
                • C Offline
                  cheminge @sdetweil
                  I’m just saying that’s not what crontab.guru says:
                  it makes it confusing.
                    sdetweil @cheminge
                    @cheminge yes, you are correct.
                    The Gen I linked to also uses 1 for January
                    Weird
                    • C Offline
                      cheminge @sdetweil
                      I have updated my months to be words instead of numbers, and at first it was working, but now it is not hiding the second example module:
                      1st Example
                      module_schedule: {from: '* * * FEB *', to: '59 23 28 FEB *', dimLevel: '100'},
                      For March I am using:
                      2nd Example
                      module_schedule: {from: '* * * MAR *', to: '59 23 30 MAR *', dimLevel: '100'},
                      I would expect as of today (February 23rd, 2025) , the FEB would show, and it does. I don’t expect to see the MAR module, but it continues to show.
                      For now I have it committed it out, but How can I get this to hide for now, and start showing March 1st?
                        sdetweil @cheminge
                        @cheminge i think dimlevel 0 is hidden
                        100 is shown
                          sdetweil @cheminge
                          @cheminge also, what is the default behavior if the module(s) are not in the ‘current’ timeframe? or not in any schedule?
