    Help with MMM-ModuleSchedule - not hiding
    11 Posts 2 Posters 4.7k Views 2 Watching
      sdetweil @cheminge
      @cheminge 1st thing is to get easypix to display your image in the right place
        cheminge @sdetweil
        I did some digging, it seems I had the “classes:” wrong in the first one.
        It needs to be:
        classes: "scheduler",
        So more like this:
        	{module: "MMM-EasyPix",
        		pages: {"Main Calendar": "bottom_right"},
        		position: "bottom_right",
        			module_schedule: {from: '0 0 1 3 *', to: '59 23 31 3 *'},
        			picName: "Leprechaun.png",
        			maxWidth: "75%",
        			updateInterval: 30 * 60 * 1000,
        Now, I can’t get anything to show up unless I take out the “module_schedule” like the code below. when add it back in, nothing shows up.
        With today being January 30th, 2025 this should fall after “from” and before “to”.
        		pages: {"Main Calendar": "top_right"},
        			/*module_schedule: {from: '0 0 1 1 *', to: '59 23 31 1 *'},*/
        			picName: "Yeah_Mon.png",
        			maxWidth: "75%",
        Any suggestions on what else I am missing?
          sdetweil @cheminge
          @cheminge thats crontab type
          0 0 for hour minute means ONLY Then .not 1 min after midnight
          * * 1 1
          means anytime on 1/1
          we support crontab in compliments, and i recommend
          this site to get the 1st 5 tokens like needed here
          https://crontab-generator.org/
            cheminge @sdetweil
            I have noticed something strange with this module.
            In my log I get this message :
            [2025-02-01 09:42:27.196] [LOG]   MMM-ModuleScheduler is scheduling MMM-EasyPix using "* * 1 1 *" and "59 23 31 1 *" with dim level undefined
            [2025-02-01 09:42:27.206] [WARN]  Month '1' is limited to '29' days.
            February has “29” days. Not January.
            So the month in my config file that I use from “https://crontab.guru/” doesn’t match what you would expect from this scheduler.
            In the documentation it say
            “Months 0-11 (Jan-Dec)”
            I have updated to use this as a key:
            Month
            1 = February
            2= March
            3 = April
            4 = May
            5 = June
            6 = July
            7 = August
            8 = September
            9 = October
            10 = November
            11 = December
            I noticed month “0” doesn’t work for January.
            Now that we are in February, it seems to be working after I set what I want to see in February as the month to be “1”
              sdetweil @cheminge
              @cheminge yes cron uses 0-11 for month
                cheminge @sdetweil
                I’m just saying that’s not what crontab.guru says:
                it makes it confusing.
                  sdetweil @cheminge
                  @cheminge yes, you are correct.
                  The Gen I linked to also uses 1 for January
                  Weird
                    cheminge @sdetweil
                    I have updated my months to be words instead of numbers, and at first it was working, but now it is not hiding the second example module:
                    1st Example
                    module_schedule: {from: '* * * FEB *', to: '59 23 28 FEB *', dimLevel: '100'},
                    For March I am using:
                    2nd Example
                    module_schedule: {from: '* * * MAR *', to: '59 23 30 MAR *', dimLevel: '100'},
                    I would expect as of today (February 23rd, 2025) , the FEB would show, and it does. I don’t expect to see the MAR module, but it continues to show.
                    For now I have it committed it out, but How can I get this to hide for now, and start showing March 1st?
                      sdetweil @cheminge
                      @cheminge i think dimlevel 0 is hidden
                      100 is shown
                        sdetweil @cheminge
                        @cheminge also, what is the default behavior if the module(s) are not in the ‘current’ timeframe? or not in any schedule?
