    installation of modules
    20 Posts 3 Posters 3.9k Views 3 Watching
      sdetweil @pat59
      @pat59 correct, if you do all this over ssh instead of vnc you can copy the text, instead of screen shot. very hard to read
      • P Offline
        pat59
        pi@raspberrypi:~ $ cd ~MagicMirror
        bash: cd: ~MagicMirror: Aucun fichier ou dossier de ce type
        pi@raspberrypi:~ $ cd ~/MagicMirror
        pi@raspberrypi:~/MagicMirror $ npm run config:check
        magicmirror@2.27.0 config:check
        node js/check_config.js
        [2025-02-11 17:59:29.192] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
        [2025-02-11 17:59:29.324] [ERROR] Your configuration file contains syntax errors :(
        [2025-02-11 17:59:29.329] [ERROR] Line 270 column 4: Parsing error: Unexpected token position
          sdetweil @pat59
          @pat59 yes, go to line 270, should say
          position
          as first thing
          look at the end of line 269
          does it have a trailing comma, means more to follow
            @pat59 have you tried my MMM-Config, so you dont have to edit config.js, after one last time
            https://github.com/sdetweil/MMM-Config
            • P Offline
              pat59
              non j ai pas essayé MMM-Config
              • P Offline
                pat59
                Bonsoir merci a vous ca fonctionne effectivement il manquait une virgule au module
                encore merci merci bonne soirée
                  sdetweil @pat59
                  @pat59 vous êtes les bienvenus. content que tu l’aies réparé
                  • P Offline
                    pat59
                    Good morning .
                    after having made my MagicMirror work again thanks to you.
                    I get this error message after installing MMM-Linky. My mirror works but not the MMM
                    unfortunately, this module is not compatible with your os try to update your os to the latest version raspbian .
                    what is the risk of updating to the latest raspbian version?
                    I definitely don’t want to break my mirror.
                    Sincerely
                      sdetweil @pat59
                      @pat59
                      there is no simple way to upgrade your os, or without impacts
                      best method is to make a new sd card
                      use my backup/restore scripts to save your MagicMirror environment, make sure you copy off the backup folder or use the github storage approach
                      then create a new sd card, and install MagicMirror using my install script,
                      Make sure it runs as basic install
                      then use my restore script to put back your MagicMirror environment
                      but this is not perfect as OS changes impact some modules
                      • P Offline
                        pat59
                        Thank you again I will leave it like this
                        thanking you too afraid of hurting
