    installation of modules
    20 Posts 3 Posters 5.6k Views 3 Watching
      sdetweil @pat59
      @pat59 youve got a space between config and check
      config:check
      in package.json script section are all the npm commands MagicMirror suppports
        pat59
        merci if I understand I have to look at line 270 and a syntax error20250211_163840.jpg image.jpg
          sdetweil @pat59
          @pat59 correct, if you do all this over ssh instead of vnc you can copy the text, instead of screen shot. very hard to read
            pat59
            pi@raspberrypi:~ $ cd ~MagicMirror
            bash: cd: ~MagicMirror: Aucun fichier ou dossier de ce type
            pi@raspberrypi:~/MagicMirror $ npm run config:check
            magicmirror@2.27.0 config:check
            node js/check_config.js
            [2025-02-11 17:59:29.192] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
            [2025-02-11 17:59:29.324] [ERROR] Your configuration file contains syntax errors :(
            [2025-02-11 17:59:29.329] [ERROR] Line 270 column 4: Parsing error: Unexpected token position
              sdetweil @pat59
              @pat59 yes, go to line 270, should say
              position
              as first thing
              look at the end of line 269
              does it have a trailing comma, means more to follow
                @pat59 have you tried my MMM-Config, so you dont have to edit config.js, after one last time
                https://github.com/sdetweil/MMM-Config
                  pat59
                  non j ai pas essayé MMM-Config
                    pat59
                    Bonsoir merci a vous ca fonctionne effectivement il manquait une virgule au module
                    encore merci merci bonne soirée
                      sdetweil @pat59
                      @pat59 vous êtes les bienvenus. content que tu l’aies réparé
                        pat59
                        Good morning .
                        after having made my MagicMirror work again thanks to you.
                        I get this error message after installing MMM-Linky. My mirror works but not the MMM
                        unfortunately, this module is not compatible with your os try to update your os to the latest version raspbian .
                        what is the risk of updating to the latest raspbian version?
                        I definitely don’t want to break my mirror.
                        Sincerely
                          sdetweil @pat59
                          @pat59
                          there is no simple way to upgrade your os, or without impacts
                          best method is to make a new sd card
                          use my backup/restore scripts to save your MagicMirror environment, make sure you copy off the backup folder or use the github storage approach
                          https://github.com/sdetweil/MagicMirror-backup-restore
                          then create a new sd card, and install MagicMirror using my install script,
                          Make sure it runs as basic install
                          then use my restore script to put back your MagicMirror environment
                          but this is not perfect as OS changes impact some modules
                            pat59
                            Thank you again I will leave it like this
                            thanking you too afraid of hurting
