    installation of modules
    20 Posts 3 Posters 5.3k Views 3 Watching
      @BKeyport unfortunately because the config is broken, we cannot use any ok it
        pat59
        Good morning
        I don’t really understand what I should do?
          sdetweil @pat59
          @pat59
          npm run config:check
          find the line number and look at the lines of config.js
          around there for the error
            pat59
            thank you, this is what it gives cordially
              sdetweil @pat59
              @pat59 youve got a space between config and check
              config:check
              in package.json script section are all the npm commands MagicMirror suppports
                pat59
                merci if I understand I have to look at line 270 and a syntax error20250211_163840.jpg image.jpg
                  sdetweil @pat59
                  @pat59 correct, if you do all this over ssh instead of vnc you can copy the text, instead of screen shot. very hard to read
                    pat59
                    pi@raspberrypi:~ $ cd ~MagicMirror
                    bash: cd: ~MagicMirror: Aucun fichier ou dossier de ce type
                    pi@raspberrypi:~/MagicMirror $ npm run config:check
                    magicmirror@2.27.0 config:check
                    node js/check_config.js
                    [2025-02-11 17:59:29.192] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
                    [2025-02-11 17:59:29.324] [ERROR] Your configuration file contains syntax errors :(
                    [2025-02-11 17:59:29.329] [ERROR] Line 270 column 4: Parsing error: Unexpected token position
                      sdetweil @pat59
                      @pat59 yes, go to line 270, should say
                      position
                      as first thing
                      look at the end of line 269
                      does it have a trailing comma, means more to follow
                        @pat59 have you tried my MMM-Config, so you dont have to edit config.js, after one last time
                        https://github.com/sdetweil/MMM-Config
                          pat59
                          non j ai pas essayé MMM-Config
                            pat59
                            Bonsoir merci a vous ca fonctionne effectivement il manquait une virgule au module
                            encore merci merci bonne soirée
                              sdetweil @pat59
                              @pat59 vous êtes les bienvenus. content que tu l’aies réparé
                                pat59
                                Good morning .
                                after having made my MagicMirror work again thanks to you.
                                I get this error message after installing MMM-Linky. My mirror works but not the MMM
                                unfortunately, this module is not compatible with your os try to update your os to the latest version raspbian .
                                what is the risk of updating to the latest raspbian version?
                                I definitely don’t want to break my mirror.
                                Sincerely
                                  sdetweil @pat59
                                  @pat59
                                  there is no simple way to upgrade your os, or without impacts
                                  best method is to make a new sd card
                                  use my backup/restore scripts to save your MagicMirror environment, make sure you copy off the backup folder or use the github storage approach
                                  https://github.com/sdetweil/MagicMirror-backup-restore
                                  then create a new sd card, and install MagicMirror using my install script,
                                  Make sure it runs as basic install
                                  then use my restore script to put back your MagicMirror environment
                                  but this is not perfect as OS changes impact some modules
                                    pat59
                                    Thank you again I will leave it like this
                                    thanking you too afraid of hurting
