    installation of modules
    20 Posts 3 Posters 3.9k Views 3 Watching
      pat59
      Good evening
      I installed the MMM-Linky module after startup, I got this error message, what should I do?
        sdetweil @pat59
        @pat59 yes, go to line 270, should say
        position
        as first thing
        look at the end of line 269
        does it have a trailing comma, means more to follow
          sdetweil @pat59
          @pat59 in the MagicMirror folder
          npm run config:check
          in 2.30 the config check function runs on every start and MagicMirror will fail to start now if there is a problem
          • BKeyportB Offline
            @sdetweil indeed it does that, but I believe this may be the wrong approach.
            No matter what, MM should start, IMO. In the case of config error, could we get an error screen like above, except for have it show the output of config checker?
            This would help in server/client environments like mine, or PM2 or any number of scenarios where the logs may not be in the right spot.
              sdetweil @BKeyport
              @BKeyport we decided that starting with the wrong config is not helpful,
              and best practice says you would use manual start, after making changes, to validate the change, before restarting w pm2
                @BKeyport unfortunately because the config is broken, we cannot use any ok it
                  pat59
                  Good morning
                  I don’t really understand what I should do?
                    sdetweil @pat59
                    @pat59
                    find the line number and look at the lines of config.js
                    around there for the error
                      pat59
                      thank you, this is what it gives cordially
                        sdetweil @pat59
                        @pat59 youve got a space between config and check
                        config:check
                        in package.json script section are all the npm commands MagicMirror suppports
                          pat59
                          merci if I understand I have to look at line 270 and a syntax error20250211_163840.jpg image.jpg
