    installation of modules
    20 Posts 3 Posters 5.5k Views 3 Watching
      pat59
      merci if I understand I have to look at line 270 and a syntax error20250211_163840.jpg image.jpg
        sdetweil @pat59
        @pat59 correct, if you do all this over ssh instead of vnc you can copy the text, instead of screen shot. very hard to read
          pat59
          pi@raspberrypi:~ $ cd ~MagicMirror
          bash: cd: ~MagicMirror: Aucun fichier ou dossier de ce type
          pi@raspberrypi:~/MagicMirror $ npm run config:check
          magicmirror@2.27.0 config:check
          node js/check_config.js
          [2025-02-11 17:59:29.192] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
          [2025-02-11 17:59:29.324] [ERROR] Your configuration file contains syntax errors :(
          [2025-02-11 17:59:29.329] [ERROR] Line 270 column 4: Parsing error: Unexpected token position
            sdetweil @pat59
            @pat59 yes, go to line 270, should say
            position
            as first thing
            look at the end of line 269
            does it have a trailing comma, means more to follow
              @pat59 have you tried my MMM-Config, so you dont have to edit config.js, after one last time
              https://github.com/sdetweil/MMM-Config
                pat59
                non j ai pas essayé MMM-Config
                  pat59
                  Bonsoir merci a vous ca fonctionne effectivement il manquait une virgule au module
                  encore merci merci bonne soirée
                    sdetweil @pat59
                    @pat59 vous êtes les bienvenus. content que tu l’aies réparé
                      pat59
                      Good morning .
                      after having made my MagicMirror work again thanks to you.
                      I get this error message after installing MMM-Linky. My mirror works but not the MMM
                      unfortunately, this module is not compatible with your os try to update your os to the latest version raspbian .
                      what is the risk of updating to the latest raspbian version?
                      I definitely don’t want to break my mirror.
                      Sincerely
                        sdetweil @pat59
                        @pat59
                        there is no simple way to upgrade your os, or without impacts
                        best method is to make a new sd card
                        use my backup/restore scripts to save your MagicMirror environment, make sure you copy off the backup folder or use the github storage approach
                        https://github.com/sdetweil/MagicMirror-backup-restore
                        then create a new sd card, and install MagicMirror using my install script,
                        Make sure it runs as basic install
                        then use my restore script to put back your MagicMirror environment
                        but this is not perfect as OS changes impact some modules
                          pat59
                          Thank you again I will leave it like this
                          thanking you too afraid of hurting
