    SampleCode for Module to read a specific Information from a webpage
    19 Posts 4 Posters 5.2k Views 3 Watching
    • N Offline
      newbi
      Hello,
      i want to create a easy module that only reads a specific Information from a web page.
      Can someone provide me a simple sample how to do this?
      No formating just reading an writing on the MM screen.
      I do now basics in programming, but do not want to learn it all from the beginning. I can learn by samples that will help me, in a more better way.
      If someone can show me the code that i have to put into the .js file will help me a lot.
      Thanks in advance
        sdetweil @newbi
        @newbi describe more, reading specific info
          sdetweil @newbi
          @newbi
          you can fetch the page html and then
          use the cheerio lib to extract the html part of the page
          • N Offline
            newbi
            @sdetweil, well on a webpage of a gym, there is an information how many people are in the gym. I want to show this Information on my MagicMirror. Thats all.
            Can you provide me a sample code?
            I am not firm with programming in javascript an libs. My programming experience is business based.
            Or is there a module i can use?
            How to fetch a html-Page?
            How to extract? I thougt i can search the page for a keyword, where the wanted value is nearby. Dirty but hopfuly worky ;)
            S C 3 Replies Last reply Reply Quote 0
              sdetweil @newbi
              @newbi well, compliments does fetch, helloworld is a simple module
              my sample module is full function, but you wont need a node_helper as fetch works browser
              https://github.com/sdetweil/SampleModule
              cheerio is a nodejs lib you can find in npmjs , and will require the node_helper, so best to combine fetch and cheerio there
              the module development doc is here
              https://docs.magicmirror.builders/development/introduction.html
                sdetweil @newbi
                @newbi we will help you if you get stuck making it work, but wont write it for you
                • N Offline
                  newbi
                  @sdetweil, ok, thanks so far, i will try to get firm with the basics.
                  As i am working on my Windows Laptop, having a MagicMirror on a Raspy 3, can i develope on my Laptop or do i need to create a developement environment on my raspy (or on my Windows Laptop)?
                  S R 2 Replies Last reply Reply Quote 0
                  • C Offline
                    chrisfr1976 @newbi
                    @newbi
                    If you want to display how crowded yor gym is, use HTML Snippet or SmartWebDisplay. Cheerio is more for static pages useful. If yor gym does not block iframes thi is the easiest way imho.
                    Regards, Chris.
                      sdetweil @newbi
                      @newbi MagicMirror runs on windows
                      need to follow the install instructions
                      need nodejs (20.18.1, or 22 up)
                      git
                      there is a separate start script for windows
                      npm run start:windows
                      also see
                      https://forum.magicmirror.builders/post/121672
                        rkorell Module Developer @newbi
                        @newbi asked
                        Dear @newbi ,
                        neither, nor :-)
                        You can “develop” physically on your laptop but the files (should) remain on the Raspi.
                        On the Raspi therefore you do not need a “development” environment.
                        You need a FTP Browser - connect this one via SFTP to the Raspi (SSH should be enabled on the Raspi - then SFTP works inherently).
                        Than you click right on the remote (Raspi) File(s) you need to modify and open the file(s) with a (Laptop) local editor of your choice.
                        When changes are done, save the file and restart the mirror - then you see the changes.
                        At least this is the way as I do those things - currently NOT programming but changing custom.css and config.js.
                        I am on a Windows laptop in most cases and I use BitVize for FTP and SSH and Sublime as Editor (which is for “programmers” because several “languages” are marked up nicely).
                        For a quick view on the result I use VNC-Viewer which gives me a better view because I have my display in portrait format which isn’t displayed nicely in Webbrowser).
                        HTH
                        Regards,
                        Ralf
                        • N Offline
                          newbi
                          @chrisfr1976 thanks for giving me the two modules :)
                          The first one seems to be promising. But I struggle to get the page been shown.
                          Is it possible to show a page?
                          And is it possible just to show the content of
                          with a class name thats locatet somehere on the page?
                          If not, i will stopp my effords and enjoy what i got so far, but it would be nice to get this information on the screen.
                          @rkorell, well newbi to programming or confuguring a mirror. Not now to programming at all, but i do it in a completele different environment (more old school).
                          I do nothing with webpages, nopthing with javascript, no libraries.
                          My Configuration does work well, i do it wie ssh. not the best way, but the result is good.
                            sdetweil @newbi
                            @newbi if you use the iframe approach it is complete page only
                            thst didnt sound like what you wanted. as mentioned if you install one of the windows tools, you will get ssh window to pi, AND a windows file manager that adds drag/drop and double click to edit
                            i use notepad++ on windows as my editor, or sometimes visual studio
                            you can slso use a browser on windows to view the page, and debug the browser side of the module
                              @newbi actually I now remember a new module
                              see https://forum.magicmirror.builders/topic/19057/mmm-scrapey-i-made-something-that-could-be-useful?page=1
                              • N Offline
                                newbi
                                no, an iframe is not exactly waht i wanted, but better than nothing. I struggle a bit to get the iframe to the correct position. Well if i can manage to scroll to the desired position, it would be helpfull, but i did not made it.
                                @sdetweil , i will chekc the module thanks. It is so much to find out, to test, a big cosmos on its own :)
                                  sdetweil @newbi
                                  @newbi yes, LOTS of info
                                  i think scrapey will do what you want
                                  • N Offline
                                    newbi
                                    Thanks a lot.
                                    I will try the suggested Modules. We will see where i will get.
                                    So this topic is solved for me.
                                      sdetweil @newbi
                                      @newbi did you get it working like you wanted?
                                      • N Offline
                                        newbi
                                        Thanks for your question. No, i quit the issue for now. Maybe i will come back to it in a few months. And maybe i will ask some questions again :)
                                          sdetweil @newbi
                                          @newbi ok.
