    Real Time Clock add on
    4 Posts 2 Posters 1.8k Views 2 Watching
    • plainbrokeP
      plainbroke
      Would a Real Time Clock add on for the Raspberry pi 4 fix the time stopping for a couple minutes and then catching up??? It acts to me like it looses the time notification from the network. I do not know what else to call it…
        sdetweil @plainbroke
        @plainbroke some modules can consume enough cycles to prevent the node thread switch
        never seen on a pi4
        plainbrokeP 1 Reply Last reply Reply Quote 0
        • plainbrokeP
          plainbroke @sdetweil
          You have to remember I run 40 modules using your pages module.
          So maybe I am running more than the pi4 8gb ram wants to handle???
            @plainbroke
            look at
            free -m
            i dont think you are using all the memory
            its cpu cycles, the mode engine is single threaded, with all kinds of ‘hacks’ to make it more like multi-threaded. but a cou bound task can still block others
