    Magic Mirror minus the mirror
    28 Posts 10 Posters 32.1k Views 15 Watching
    • C Offline
      cyberphox
      i use Wunderground weather…why can i not get these fabulous weather icons!
      going to compare your CSS and config files! thanks
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @cyberphox
        @cyberphox coloricon: true
        C 1 Reply Last reply Reply Quote 1
        • C Offline
          cyberphox @strawberry 3.141
          @strawberry-3.141 definitely have that set in my config file. cleared out everything in my custom.css so nothing would interfere…maybe my location doesn’t get pretty realistic icons…sigh
          • Y Offline
            yawns Moderator @cyberphox
            @cyberphox
            Please share your config file
            • C Offline
              cyberphox
              Actually I have solved the issue! Anyone else having this problem - I solved it with two words - git pull.
              Yup…I i was using an older version of the MMM-WunderGround module…doh!
              • P Offline
                pflodo @billp100
                @billp100 The photo shows your Calendar module with a header that matches your calendar colours, like a legend, which is great. But how did you do that? It is not reflected in the config you posted, unless I am missing something.
                  strawberry 3.141 Project Sponsor Module Developer @pflodo
                  @pflodo https://forum.magicmirror.builders/topic/1692/calendar-heading-changes
                    misterfrei @billp100
                    @billp100 ![alt text]ttps://forum.magicmirror.builders/assets/uploads/files/1488818811433-infodisplay4.jpeg0_1511171562750_1488818811433-infodisplay4.jpeg
                    Hallo zusammen
                    wie kann ich bei den angezeigten objekten , die farbe ändern? wie hier dargestellt?
                    kann man auch das grosse icon verschieben? zum beispiel in die mitte des display und es auch grösser machen?
                    Hello everybody
                    how can I change the color of the displayed objects? as shown here?
                    is it possible to move the big icon? for example, in the middle of the display and make it bigger too?
