message Remote Control
18 Posts 2 Posters 2.1k Views 2 Watching
    sdetweil @pat59
    @pat59 said in message Remote Control:
    in the message it tells me https://github.com Username
    sorry, I don’t understand that text
    as I said, you have to disable the updateNotification module
      module: "updatenotification",
      disabled: true,
    OR
    you have to list the modules to ignore
       module:"updatenotification",
       position: whatever it is,
         ignoreModules:["MMM-Remote-Control"]
    these messages in the pm2 log
    [2025-03-14 20:51:34.981] [INFO]  Checking git for module: MMM-MealieMenu
    [2025-03-14 20:51:35.028] [INFO]  Checking git for module: MMM-pages
    [2025-03-14 20:51:35.070] [INFO]  Checking git for module: MMM-CurlToNotification
    are from the updateNotification module checking each module not ignored
    • P Offline
      pat59
      disabled :true,
      position: "top_center",
        ignoreModules:["MMM-Remote-Control"],
        updateAutorestart: true, // restart MagicMirror automaticaly after update
        updates: [
          // MMM-MeteoFrance rule
            "MMM-MeteoFrance": "npm run update"
      the message is still there , l don't know anymotre after several attempts to modify the js config
      S 1 Reply Last reply Mar 16, 2025, 1:41 PM Reply Quote 0
        sdetweil @pat59
        @pat59 and you restarted MagicMirror after changing config?
        can you show the screen again?
        are there multiple instances of updatenotification in the config.js?
        • P Offline
          pat59
          Yes, I systematically restart after each change in js.
          Well, you did find that there were indeed two update notifications in config.js.
          Something I would never have thought of after making the change in the second update notification in config.js. This one works, no more messages, even though I spent hours solving a lesson in restraint. Thanks again.
          S 1 Reply Last reply Mar 16, 2025, 2:29 PM Reply Quote 0
            sdetweil @pat59
            @pat59 great work…
            • P Offline
              pat59
              The excellent work is partly due to your patience, thank you for everything, I am so happy.
              S 1 Reply Last reply Mar 16, 2025, 5:16 PM Reply Quote 0
                sdetweil @pat59
                @pat59 I think you should try my MMM-Config module, as you continue to have problems with config.js
                https://github.com/sdetweil/MMM-Config
                this will present a form for the system and module properties.
                it will also support adding modules too…
                it will also show you when you have multiple instances…
                • S sdetweil has marked this topic as solved on Mar 17, 2025, 11:00 PM
                • P Offline
                  pat59
                  Hello
                  Thank you, I’ll try. Thank you. Have a nice day.
                  2 / 2
