    iFrame module not showing content
    4 Posts 3 Posters 3.4k Views 3 Watching
    • F Offline
      fox
      @desertblade I’ve created on my second raspi an container called iframe.html (He takes temperature data from pool with 1-wire sensors)
      alt text
      and indexsmall.html is:
      http://pastebin.com/KjhxUpYZ
      But it does not work.
      Only a white line:
      alt text
      Code in MM is:
                              module: "MMM-iFrameReload",
                              header: "",
                                      url: "http://192.168.188.30/iframe.html",
                                      width: "100%",
                                      height: "200px"
      Who can help me?
      • F Offline
        fox
        i got it:
        the module is buggy!!
        https://forum.magicmirror.builders/post/17419
        • O Offline
          ooskay
          does it solved or still problematic?
          I would like to use Iframe on my setup to display an html or xml output taken from my local app?
          what do you suggest?
          • ? Offline
            A Former User @ooskay
            @ooskay How about using this?
            [card:eouia/MMM-HTMLBox]
            You can put your iframe tag into the content or external file.
