    openweathermap not working
    11 Posts 2 Posters 2.7k Views 2 Watching
      Sam 0
      I can’t get the module to work. I entered the free API key but no data is provided. I suspect a typo or setting that I am not doing correctly. I would appreciate your help with possible working examples. Thank you in advance for your efforts.
      config:
                      weatherProvider: 'openweathermap',
                      weatherEndpoint: '/onecall',
                      apiKey: '57657657576',
                      apiVersion: '3.0',
                      type: 'forecast',
                      colored: true,
                      fade: false,
                      maxNumberOfDays: 3,
                      degreeLabel: 'true',
                      showWindDirectionAsArrow: 'true',
                      decimalSymbol: ','
      S S 2 Replies Last reply Reply Quote 0
        sdetweil @Sam 0
        @Sam-0 see https://forum.magicmirror.builders/topic/19323/version-2-30-0-weather-module-stuck-loading-worked-fine-before-upgrade
          Sam 0 @Sam 0
          @Sam-0 I read your post but I can’t figure it out. Does the entire option not work or did I make a mistake somewhere?
            @dontronics
            dont need provider, endpoint, or apiversion as those are the defaults
            the apiKey is the one backed by credit card, right?
              Sam 0 @sdetweil
              I didn’t have to give a credit card, I don’t have one either, so it won’t work at all? Is the location option correct? Thanks for the effort and answering the questions
                sdetweil @Sam 0
                @Sam-0 read the top of the linked post.
                  Sam 0 @Sam 0
                  @Sam-0 I have made some changes and now I get a different message, this is what I have in my config now, can anyone help me with what still needs to be done? config:
                  // See ‘Configuration options’ for more information.
                  weatherProvider: “openweathermap”,
                  apiKey: “drtdgrdgfgfdgdfgfdgfdtestmmmmmmm”,
                  lat: 52.0575,
                  lon: 4.4931,
                  apiBase:‘https://api.openweathermap.org/data/’,
                  weatherEndpoint:‘/onecall’,
                  message on mm invalid that NAN
                    Sam 0 @sdetweil
                    @sdetweil I read the topic maybe my English is not so good that I do not understand it well can you indicate what I am doing wrong I have now adjusted the following
                    disabled: false,
                    module: “weather”,
                    position: “top_right”,
                    header: “Weather Forecast”,
                    config:
                    apiKey: “ghgjhgjhgjghjgjfghchghf”,
                    lat: 52.0575,
                    lon: 4.4931,
                      Sam 0 @sdetweil
                      @sdetweil ok I continued searching and now have the following config which seems to work at the moment disabled: false,
                      module: “weather”,
                              config:
                      	apiKey: "fnotmyapikey sampletestttghfhghfhfghfhghh",
                      	lat: 52.0575,
                      	lon: 4.4931,
                      apiVersion: ‘2.5’,
                      weatherEndpoint: “/weather”,
                        Sam 0
                        module: “weather”,
                                config:
                        	lat: 52.0575,
                        	lon: 4.4931,
                        apiVersion: ‘2.5’,
                        I added
                        the following values
                        apiVersion:
                        ‘2.5’,
                          sdetweil @Sam 0
                          @Sam-0 you finally got it
                          as your native language is not english, have the browser translate the page
